stillen kit just installed...
Old Apr 26, 2002 | 06:10 AM
big h's Avatar
anyone use screws on their install (side pieces) or just double sided tape?
Old Apr 26, 2002 | 06:20 AM
2maxguy's Avatar
I used 1/8" black aluminum rivets just inside lower door edge, 3M acrylic foam tape with adhesive promoter and 5/32" stainless rivets on fender edges to hold on side spoilers.
Old Apr 26, 2002 | 06:23 AM
big h's Avatar
the reason I ask is that the body shop that installed it (they are a supposedly a good import tuner shop) used screws (4 of them on each side piece) Now i thought that it was just doulble sided tape and no screwing except at the fenders...anyone have some insight on this?
Old Apr 26, 2002 | 06:25 AM
big h's Avatar
so you had to drill into the metal right?
Old Apr 26, 2002 | 06:51 AM
2maxguy's Avatar
Yes, but if you use sealing rivets or dab a little RTV silicone in the rivet hole, water infiltration shouldn't be an issue. By the time any rust appears, I'll be on to my next car. The clearance is very tight between the bottom of the door and top of rocker panels, that's why I used rivet to hold it down tight.
Old Apr 26, 2002 | 08:18 AM
Dario's Avatar
not only that but for protection against thieves
Old Apr 26, 2002 | 09:52 AM
[maxi-overdose]'s Avatar
Re: stillen kit just installed...
depends on where u live....I wouldnt use double side tape if i live in seattle....I know it's going to come off on a raining day. I have seen body kits sitting on the side of our Bay Area freeways.
Fbana41
Aug 29, 2016 12:18 PM
05RLS2
Apr 14, 2016 11:49 AM
Nv2dmaxmd
Oct 19, 2015 05:37 PM
Pied
Sep 26, 2015 03:29 PM
