19"-- 245 or 235 ? Will a 245 fit?
Old May 3, 2002 | 09:16 AM
asu174's Avatar
Clay Aiken has fancy genitals
I need help. The guys at Discount Tire aren't sure about this one. I have a 2000 Maxima and I am going to be putting 19" rims back on my car. Will a 245/35/R19 fit? Or should I stick with a 235? I really want the 245- any extra cushion for the pushin' will help.......
My rims are a 19 by 8. I have Ground Control coil overs with Eibach springs. The front set is all the way down and the rear set is almost all the way up. As far as exact measurements, I have no idea.
Any help? I know there is at least one guy out there who has tried this before.
Andy
Old May 3, 2002 | 09:20 AM
RussMaxManiac
Re: 19"-- 245 or 235 ? Will a 245 fit?
I suspect you are going to have 19s all around right? 245x35 will fit fine on a 19x8 rim and tire. Offset I had on a 17x8 with 245x45 was 35mm with momo arrows. I only had a slightly rub on the inner fender liner when turned all the way.
Andy
Old May 3, 2002 | 10:10 AM
max'n out's Avatar
Yes it fits...I suggest an offset with in 35-39, you can acually go with a 255 if you would like...turbo ran a 275 with minor rubbing and suggested a 265. I run a 245 and would like to go with a 255 when these wear out.
Old May 3, 2002 | 10:13 AM
asu174's Avatar
I just found out that the X-Factor has a 35mm offset. So I'm cool right? Even though it is lowered?
Old May 3, 2002 | 10:17 AM
max'n out's Avatar
yeh
Old May 3, 2002 | 12:19 PM
freeze2k2's Avatar
what tire company make a 245 35 19?
Old May 3, 2002 | 01:31 PM
max'n out's Avatar
Most do...Yokohama, Michelin, Toyo, Perrelli are a few...but you can get them in all most any company.
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
Pied
Sep 26, 2015 03:29 PM
