Need help decing which shocks to buy.
Old May 9, 2002 | 06:04 PM
Greek to the Max's Avatar
Please people, I need help deciding which to buy. I have H&R's on stock, and well, I want a little stiffer ride. Not to many choices. Anything Im not thinking about?
Old May 9, 2002 | 06:51 PM
nissanmaximas's Avatar
Re: Need help decing which shocks to buy.
I have Eibachs & Tokicos right now. As far as i know, people on the .org have Tokicos, KYB AGX's Adjustables (4th gen modded for 5th gen), or GC's (GroundControl Coilovers). Hope that helps you.
Old May 10, 2002 | 05:26 AM
Alot of people have reported problems with the tokicos.
Old May 10, 2002 | 09:36 AM
[maxi-overdose]'s Avatar
a lot of ppl having problem with tokicos is because the spring they use is too stiff. tokico combo with near stock spring should be ok. IMO
Old May 10, 2002 | 12:17 PM
the paragon's Avatar
what's the part # for 5th Tokicos?
Old May 10, 2002 | 12:26 PM
zman187's Avatar
I have progress with tokico and thats probably the hardest spring they make... and i've had no problems so far.. It says on the package for tokico's that its made hard for very stiff springs so I doubt that is the problem.. poor installation might be the cause because if done right there should be no problems
z
Old May 10, 2002 | 12:38 PM
z
Progress Springs are not that stiff.
Tokico Shocks are not suited for truly stiff springs.
Eibach and Tokico Combo is good cause the first inch of travel is very forgiving since its a progressive rate spring, but if you hit enough bumps, you will blow the Tokicos, honestly it just can't handle it. Tires will also make a difference since I've noticed the wider the tire, the less abusive the ride.
-Peace
Old May 10, 2002 | 01:49 PM
TOKHB3188 front right
TOKHB3189 front left
TOKHU2943 rear
source : stillen
also on : http://www.tokicogasshocks.com/car/appguide.asp
Old May 10, 2002 | 07:36 PM
Deven2kStickMax's Avatar
TOKHU2943 rear
source : stillen
Tokicos HP shocks/struts with Eibach works great too. I had them before
Old May 10, 2002 | 08:22 PM
why u switch to AGX?
Old May 10, 2002 | 08:46 PM
Only because you can adjust to soft or hard ride. You can take the family out and give them a almost lincoln ride with the lowest settings and they would hardly feel a bump and when you wanna do you street ******** you can tight her up to a higher setting. After i got Tokicos from shox.com then cattman came out with the modded agx, otherwise i would have never bought Tokicos to begin with, but am not sayign that they are not good. they are damn good, it's just that you cannot adjust anything. i had tokicos on my x car also.
Old May 10, 2002 | 08:55 PM
U bought the AGX from Cattman....U think they are reliable?
Old May 10, 2002 | 09:11 PM
I paid $450 plus a few xtra bucks for the dust boots. They are ok, except i was ticked off that they didn't fully explained that the Eibachs would not fit correctly over the rear shocks and what you have to do, but i had called and they explained over the phone and i did and it worked. The front ones are modded and then they painted the bottom in black. I must say the price is kinda high, but it worth it on your max.
Old May 10, 2002 | 11:43 PM
ohboiya's Avatar
How did you get the front strut mount to fit?
Old May 11, 2002 | 12:23 AM
he prob bought the 4th gen strut mount as well...other wise u gotta do a lot of work on it.
Old May 11, 2002 | 02:58 AM
a33's Avatar
a33
if you dont mind it being stiff, kyb
Old May 11, 2002 | 05:03 PM
i did bought the 4th gen strut mount, but it didn't work and got busted on me making a knocking noise on my front strut(left), so i ordered from the dealer a pair of 5th gen ones and trim off half cm off the spindles and then i reinstall. i still have the original strut mounts, just in case i have to put on back factory if i ever wanna sell my car. about the ride? yeah it rides stiff if you tight it up all the way, but i like the lower settings like 2 in the front and 3 in the rear, feels nice for me, not too stiff or too soft.
Old May 11, 2002 | 06:23 PM
Ok, wait now, don't buy the 4 gen mounts? they wont work? What about the dust boots? How much are the 5th gen mounts? I want it to be reliable, and adjustable and well worth. On the softest setting, how soft is soft? I have H&R's.
Old May 11, 2002 | 06:35 PM
the 5th gen mounts from nissan is $70 bucks a pair, i paid that in my area. when i say soft handles the road smooth like a town car if you want or handles like a race car if you want. 8 settings in the rear and 4 in the front.
Old May 11, 2002 | 06:38 PM
wait, so thats just the mount and not the front shock?
Old May 11, 2002 | 06:41 PM
when i say mount, i'm talking about the part that you have to machine off half cm off on the spindle. the go on top of the strut. you can see them from in the hood of your car.
Old May 11, 2002 | 06:42 PM
Thats expensive. Cause, I dont want to kill my stock stuff. I most likely will go that way. How much trouble, if any will I have with my H&R's? I will most likley order at the end of this month. Does it matter whicg dust boots I use? How reliable for other cars are these Shocks?
Old May 11, 2002 | 06:44 PM
well you can use the dust booths made for the AGX or you can reuse the stock ones if they are good. Both fit different, so i stay with factory style and kept my factory boots. some people would take off one ring on each, but i didn't and have no prob so far.
Hey, come online with ICQ. So I can ask you a few questions.
Old May 11, 2002 | 07:46 PM
I think Im going to order them. Before I reck my stock ones.
Old May 11, 2002 | 11:58 PM
K Pazzo 6's Avatar
Stagnet04
Oct 11, 2015 08:16 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
Stagnet04
Sep 14, 2015 11:28 PM
