Doh! TSB part backordered.
Old Nov 29, 2000 | 12:03 PM
TX2KSE
I went just before Turkey day to get the TSB's for the TCU and the AC blower fan done. They had to order the parts. I called today. The TCU was in, but the fan casing for the blower has been backordered!
Makes me wonder how many people are getting that TSB done!?
Old Nov 29, 2000 | 04:38 PM
Wustylez
What is wrong with you AC blower fan???
does it have noise when putting at low speed, cuz i think mine does and wondering if that is normal or a TSB again...
Tim
Old Nov 29, 2000 | 05:26 PM
xydavid's Avatar
Tim [/I]
Mine just started making a chirping-like noise when the A/C fan is on low.
Old Nov 30, 2000 | 07:58 AM
TX2KSE
That's exactly the symptom. Actually, it makes the sound at all speeds. It's just more noticeable at the lowest setting.
Apparently Nissan sent out a lot of Maximas with this prob. The fan inside the casing is rubbing on part of the casing with every rotation, making a little chirping sound. Annoying!
Their solution, which has a TSB, is to replace the casing (apparently with a larger one, so that the fan doesn't hit it).
In my mind, I think they should have replaced the fan with one that is more round, or better centered, or whatever. Seems like their solution is similar to "if it doesn't fit, get a bigger hammer".
Oh well. As long as they fix the stupid thing to make it quiet again.
Old Nov 30, 2000 | 04:11 PM
Wustylez
Damn Nissan, do you happen to have the TSB number, I can only find TSB number corresponds to Cooling system, is that the one?
Tim
Old Dec 1, 2000 | 12:10 AM
xydavid's Avatar
yea does anyone have a copy of that TSB... i guess I'm going to need this one. I may need the TCU one too.. my car has a manufacture date of 4/99, but I haven't noticed any rough shifting between 1 & 2.. but might as well have them check it out if they're going to have it for a few hours.
Old Dec 1, 2000 | 01:54 PM
TX2KSE
http://www.nhtsa.dot.gov
Transmission Control Module TSB#: NTB00039
Blower motor ticking TSB#: NTB99017A
The blower motor ticking is listed under "Engine Cooling Systems" on the NHTSA site. But I think it's really talking about the AC blower fan.
derekinthez
Nov 13, 2022 04:00 PM
Mar 12, 2020 12:06 AM
SpeedCrazie
Sep 16, 2016 03:41 PM
Lowered_a33
Sep 10, 2015 09:41 PM
videomano
Sep 8, 2015 03:28 PM
