question: will this rim size fit?
Old May 14, 2002 | 08:05 PM
big h's Avatar
I am clueless to wheel specs, will this fit 2001 max?
18 X 8.5, 120mm bolt circle, 38mm Offset, 73mm
index
Old May 14, 2002 | 08:10 PM
big h's Avatar
before i get flamed i tried the search and i am sorry to say but what the heck is offset? and index?
Old May 14, 2002 | 08:31 PM
Newman's Avatar
maximas use a 114.3 bolt pattern so i dont think it will fit. offset is the # of MM that the lug portion of the rim are off center.
for example:
Old May 14, 2002 | 08:32 PM
Newman's Avatar
okay my art didnt work out like i planned. let me fix it.
Old May 14, 2002 | 08:35 PM
ssiperko's Avatar
Offset is the # of mm's from the center of the wheel, either positive 38mm (towards street) or negative -38mm (towards strut or "deep dish")I am not sure about index, sorry I did not take time to search it yet, maybe when you do you can tell me. A 120mm bolt pattern does not fit the max, a 5x114.3 - 5/4.5" does.
l8tr -- SS
Old May 14, 2002 | 09:14 PM
cobymoby's Avatar
Re: question: will this rim size fit?
index
The 73mm index is more commonly refered to as the center bore. On a Max, 4th and 5th gen, the center bore is 66.1mm. A 73mm is like a "universal" centerbore because it's BIG. Make sure to get hub rings to adapt that 73mm to a 66.1 or else you won't have a hub centric wheel. It can still be centered on the hub properly but sometimes it isn't done right. Oh yeah, but that 120mm will not fit. We are 5x114.3.
Old May 14, 2002 | 10:41 PM
big h's Avatar
Thanks guys!
RIPTIDER
Wheels/Tires
Jan 31, 2016 07:39 AM
Luigi623
Sep 21, 2015 01:42 PM
mikeymouse1995
Sep 18, 2015 06:42 AM
meccanj98
Sep 17, 2015 08:28 AM
0m3nc0w
Sep 11, 2015 05:21 PM
