DISadvantages of lighter wheels?
Old May 19, 2002 | 08:02 PM
mattattax's Avatar
the lighter wheels will obviously be easier to get moving off the line, but are there any drawbacks to getting 14 lb. rims? could I have less traction and more wheel hop? and will the ride quality be different at higher speeds?
thanks
Old May 19, 2002 | 08:15 PM
AznWontonboy's Avatar
Re: DISadvantages of lighter wheels?
thanks
Yes, your launch will be harder.
Old May 19, 2002 | 08:19 PM
soundmike's Avatar
Very sound, Mike
Isn't it also slightly harder to control the launch with lighter rims? (e.g. wheelspin)
Old May 19, 2002 | 09:01 PM
dmbmaxima2k2's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
yes just ask synki why he dragged with his chrome heavy wheels, he spun with his stock ones once he had the 100shot.
Old May 19, 2002 | 09:02 PM
jhans114's Avatar
I personally like my lighter rims,(Volks). It might be true that lighter rims are a little tougher of the line but once you get some grip your gone. Also a limited slip wouldn't hurt.
Old May 19, 2002 | 09:15 PM
GMAN01SE's Avatar
I would also immagine that durability would be an issue. The lighter wheels wouldn't take the abuse. Watch out for those pot holes!
Old May 19, 2002 | 09:35 PM
No. Some light wheels are very strong.
Old May 19, 2002 | 09:48 PM
lcf's Avatar
lcf
the answer depends on whether from a stop or roll. everyone seems to be talking about from a stop so far, but...
from a roll lighter wheels = rool
Old May 19, 2002 | 10:23 PM
annimax's Avatar
Correct. I guess it depends upon which metals were used to make them.
Old May 19, 2002 | 11:21 PM
La Jolla Max's Avatar
most are cast aluminum. But some exotics, like Volks, are made out of aluminum forged at extremely high pressures. This makes the metal very dense, meaning less material needs to be used for each wheel, making them strong yet extremely light.
Old May 20, 2002 | 06:36 AM
soundmike's Avatar
Very sound, Mike
So Forged is better than Cast then? (e.g. strength and weight)
Old May 20, 2002 | 07:45 AM
wdave's Avatar
thanks
Better acceleration, better handling, better gas mileage.
More road noise, more ride harshness.
Wheel hop could be a factor but shock and spring rates count more.
Old May 20, 2002 | 08:49 AM
Galo's Avatar
Maxima Pilot
What!?? Lighter wheels = MORE road noise
and harshness?? NO freaking way, it's exactly the inverse...lighter wheels = less unsprung weight = better ride and handling. It's simple physics so...no arguments, please
Old May 20, 2002 | 11:44 AM
wdave's Avatar
Re: What!?? Lighter wheels = MORE road noise
Yes, simple physics, the lighter unsprung weight follows irregularities in the road better, hence better handling, BUT, the lighter assembly also transmits these irregularities more efficiently to the suspension which might be designed well enough to handle the additional work, in the Max it means better noise and harshness transmission to the car as the suspension and bushings are marginal at best in the first place.
Old May 20, 2002 | 02:36 PM
Galo's Avatar
Maxima Pilot
Hmmnnnn...okay, Dave, I'll buy that, yes the
Maxima's NVH isolation leaves A LOT to be desired....the road noise in particular is really driving me up a wall and it seems that the more the OE Potenzas wear (only 6k miles) the more noise I have...
Old May 20, 2002 | 03:11 PM
soundmike's Avatar
Very sound, Mike
Re: Hmmnnnn...okay, Dave, I'll buy that, yes the
That i can account for
Old May 20, 2002 | 05:07 PM
Greek to the Max's Avatar
You get alot with the max, but what you dont get is why the car cost a little less then others in its class. Wind noise, soft suspension, s h i t tires are just some popular reasons. Car is simply powertrain, which means most to someone like myself.
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
Cipitiox
Wheels/Tires
Sep 30, 2015 06:16 PM
Andy29
Sep 29, 2015 05:32 AM
Garrettz459
Sep 28, 2015 02:50 PM
Redfox
Sep 28, 2015 10:41 AM
