Shift Delay
Old May 24, 2002 | 07:55 AM
melteye's Avatar
Shift Delay
When I floor my Auto 2K2 there is a major delay... I am going with Don's VB Mod soon to fix the problem but was wondering if there is any other problem I should be aware of (so i can have nissan fix it before i void my warranty)
Old May 24, 2002 | 08:39 AM
[maxi-overdose]'s Avatar
I would consider that if VB recal can acutally solve this problem. There are few cases here with 2k2 auto tranny slippage problem.
Old May 24, 2002 | 09:16 AM
suds1's Avatar
Re: Shift Delay
Are you having any problems when you don't floor it? I just got a 2k2 and I am very impressed with how much smoother this transmission is compared to my 2k. But I haven't floored it yet obviously. Only 47 miles on it.
Old May 24, 2002 | 09:35 AM
Cumalot's Avatar
I have Don's VB in my 4th gen. The shifts are more firmer, but the delay/lag is still there. I would get this delay from time to time. Each time, it happens when I floor the gas. If I don't floor it immediately, but gradually increase pressure on the gas, I wouldn't get the delay. Odd. Maybe this is a better way to go. However, I guess I just got used to it, I can't help but floor the gas when I need to.
Old May 24, 2002 | 10:28 AM
soundmike's Avatar
Very sound, Mike
Re: Shift Delay
The Recal/VB mod only helps with the shifting of gears. Flooring it from a stop or while cruising doesn't really get helped much. If anything it's just the delay you experience while the ECU is thinking what to do.
Having an electronic (?) throttle control/drive by wire system doesn't help either. This is the same cause of hesitation that some 6spd owners are experiencing.
Old Jun 22, 2002 | 06:16 PM
slickrick's Avatar
i have a 2k2 se auto and i floored it 4 the 1st time, it has 2400 miles on it, and nothing happend so i let off a lil then it took off, i thought i didnt floor it, but i felt the floor. but hopefully it wont happen again.
Old Jun 22, 2002 | 06:46 PM
TimW's Avatar
The silent but deadly Moderator
hmmm
first, check your ATF level.
second, if you have any rise in RPM during the delay, then you have a problem and should have that fixed prior to the vb work.
Old Jun 22, 2002 | 07:30 PM
Neal728's Avatar
Actually, I have found that the shift delay is almost gone once I had my FrankenBerk on (Frankencar Midpipe, Berk Intake). Try that, it helped me out, actually the Berk by itself seemed to do the job....
Unclejunebug
Apr 2, 2016 05:42 AM
hayne
Oct 5, 2015 11:53 AM
ef9
Oct 4, 2015 08:43 AM
