Need Some Help
Old May 25, 2002 | 03:50 PM
JohnnyMax01's Avatar
Need Some Help
Rims 17x7 Tires 205/40/17. If i put these size tires on the max will there be too much of a gap in the wheel well. the car has not been lowered so any information you guys can give or if anybody has pics you would be a huge help. thanks
Old May 25, 2002 | 04:23 PM
asu174's Avatar
Clay Aiken has fancy genitals
Re: Need Some Help
That will look abolutely ridiculous. Not only will your spedometer be off by quite a bit, it will look like crap. That is the fittament for a Honda Civic. Regardless of what kind of deal you are getting, DON'T DO IT!
Old May 25, 2002 | 04:37 PM
Young04's Avatar
Re: Need Some Help
sorry, dont have pics, but i experimented with 225/45/17 on a stock 2k2 GLE and it looked pretty bad. not atrocious, but doing the math, 225/45's were 3 cm smaller in total diameter than my stock wheels, and it looks like your setup would be 2 cm smaller than that. the 225/45/17 was really questionable. if you really wanna do the 205/40/17's, i would really suggest getting a set of rims/wheels from someone you know and put one wheel on and see if you can live with it (seeing it in person and seeing it in a pic can be different too).
Old May 25, 2002 | 04:51 PM
y2kse's Avatar
You folks seem to be overlooking one small detail. If JohnnyMax01 mounts 205/40R17 tires on his Maxima, he will probably
DIE!
The first person who can tell me why wins a lollipop.
(Assuming you'd like to find out the answer for yourself, JohnnyMax01, I'd refer to you the Frequently Asked Questions sticky at the top of this forum. Go through it and read everything you can find about tires. Then come back here and tell my why it's suicidal to put those tires on your Maxima.)
Old May 26, 2002 | 07:17 AM
Young04's Avatar
is it weight load??
DIE!
Old May 26, 2002 | 10:54 AM
asu174's Avatar
Originally posted by Young04
is it weight load??
It is definitely the weight load.
Old May 26, 2002 | 11:20 AM
Y2KMaxGXE-R's Avatar
Old May 26, 2002 | 03:23 PM
So then what is a good tire size then, i dont want it to be to thick, but i also dont want a huge gap in the wheel well. thanks
Old May 26, 2002 | 03:27 PM
KLOOGY's Avatar
L33t BMW Drivah
If its a 17X7 wheel.... 225/50 is the perfect tire. The gap wont be too big, and they're not 4X4 tires.... Look at my homepage pictures, before my Maxspeeds... This is the Stock Size Nissan uses on the SE .... Why would you even consider that tire size in the first place ??
Old May 26, 2002 | 03:52 PM
asu174's Avatar
225 is a little too beefy for my liking. Although that is the size I would go with on a 17", if I were really looking to rid some of the "fat", I'd go with a 215 50 17 at the VERY minimum.
Old May 26, 2002 | 11:02 PM
well here is the link for the wheels that i want, they are the Omni Avalanche, 17x7 if anyone is familar with this site does that seem like a good deal. thanks
Old May 26, 2002 | 11:07 PM
http://www.wheelmax.com/Wheels/Color/chrome.htm
Old May 26, 2002 | 11:11 PM
KLOOGY's Avatar
L33t BMW Drivah
215/50 ?? why would you want to lose thread ??? These arent Euro T/A's we're running on ... Most guys are having traction problems with the 225's... It would not help to go down in size...... By the way AZ.. thanks for the Whalen tire tip... I think I found my next wheels !
Old May 27, 2002 | 05:46 AM
asu174's Avatar
Well, a 215 50 is sure a lot better than a 205 40. I definitely wouldn't mount a 215 on the Max, but if Johnny was hell bent on not running 225s because of cosmetic issues, then the 215 is the way to go.
Kloogy- what wheels are you looking at? Your car looks tight as is......
By the way, here are your wheels. That site takes forever to load. They are very nice and I can understand why you wouldn't want a beefy sidewall on a deep dish lip. Unfortunately, the only way to REALLY get rid of the "fat" is to go with an 18".
Old May 27, 2002 | 05:52 AM
asu174's Avatar
Re: Need Some Help
After seeing the website, I am guessing that you want to 205 40 because that is the tire on special? Sometimes they can substitute other tires with an "upsizing" charge if I am not mistaken. Give tham a call and see what they say.
