KYB AGX Question
Old May 30, 2002 | 11:47 AM
MAX2000JP's Avatar
KYB AGX Question
Are the 5th gen rear AGX's the same as the 4th gen or are they Cattman Modified? My rear shocks are starting to go and I would like to replace them. My stock fronts are fine for now, has anyone tried this combo?
Old May 30, 2002 | 12:41 PM
[maxi-overdose]'s Avatar
Re: KYB AGX Question
cattman modified 4th gen to fit into 5th gen...need to purchase the strut mount or u can modify it urself.
Old May 30, 2002 | 12:42 PM
noflash's Avatar
4th gen Koni are sposed to be the same as 5th.
Old May 30, 2002 | 12:50 PM
Re: Re: KYB AGX Question
I think u have to do modification on the shocks.
Old May 30, 2002 | 01:00 PM
noflash's Avatar
Re: Re: Re: KYB AGX Question
Galo told me the rears were the same - perfect fit.
Old May 30, 2002 | 01:03 PM
jykishan's Avatar
Re: Re: Re: Re: KYB AGX Question
i've also heard this, the rear shocks are exactly the same with no modifying.
Old May 30, 2002 | 01:21 PM
oops I am so sorry guys....the entire thing was about rear shocks... my posts are about the front...my bad
Old May 30, 2002 | 01:59 PM
roastduck88's Avatar
I have the AGX's installed, we had to modify the fronts. It wasn't too bad, we just had to cut a metal part by a few mm shorter, after that the screw fit perfectly and it was fine.
Old May 30, 2002 | 03:15 PM
blkmax2001's Avatar
The AGX rear shocks are not exactly perfect fit for 5 gen but you can use them without modification.
Old May 31, 2002 | 04:45 AM
Jeff K's Avatar
Rears will fit..>
I'm running Tokico fronts and KYB(4th gen) rears and everything is working perfectly(also installed H&R springs). The rears will fit but the 2K spring will not sit perfectly flat on the shock perch. It teaters from side to side but after putting all the hardware back on it keeps everything in place. I have my rears set to 2 right now and it feels great. The rears shocks are the weak link in our suspension and by installing the KYBs it will make a world of difference. Bought my KYB rears from Shox.com for $80ea.
Unclejunebug
Apr 2, 2016 05:42 AM
maxima-junky
Oct 7, 2015 06:13 PM
Socalstillen
Sep 26, 2015 12:01 PM
