Need quick help with R/T Cat install!!!
Old Jun 2, 2002 | 11:08 AM
Norm02SE's Avatar
Hello.Trying to install my RT cat and cant figure out which way it should go.there are no inlet or exit markings and both ends are exactly the same.The only markings are "with air tube" and "without air tube".Need some guidance please.Its for a 2k2 by the way.Thanks in advance
Old Jun 2, 2002 | 11:22 AM
y2kse's Avatar
Re: Need quick help with R/T Cat install!!!
As I remember, there's a BIG flow arrow on the cat itself. I didn't see it at first, but it's there. Keep looking.
Old Jun 2, 2002 | 11:35 AM
BigDogJonx's Avatar
Besides all of that, one of the ends are almost 15 degrees off from the other ends header style clamp. So in a sense, if you try to put it, it will really only go one way.
No need to be concered, if it dont fit one way, try it the other, it will fit only one way.
Dixit
Old Jun 3, 2002 | 05:34 AM
Max_Gator's Avatar
Ah, I troubled with that a bit myself since there was no arrow on mine.
The answer, I believe, is that your RT cat has no air tube (which from the diagram appears to be a piece that sticks out off of the cat) thus you should set it up according to the without air tube directions.
Mine was 2k but should be the same - unless you have an air tube sticking out of it.
Old Jun 3, 2002 | 06:27 AM
LeftCoast's Avatar
With your feet pointing toward the back of the car you should be able to read "Without air tube". Had to surf around the Random Technology web site for help.
-Left
JRod28
Dec 29, 2023 09:56 PM
Cotozic
Jun 28, 2017 08:01 PM
cruce91
Sep 20, 2015 10:23 AM
Johnny9595
Sep 3, 2015 05:18 AM
soloist3
29
Sep 1, 2015 03:47 PM
