urgent: i need to know the bolt pattern and offset of the 5th gen maxima...
Old Jun 9, 2002 | 08:32 AM
a33's Avatar
a33
anyone???
thanx
Old Jun 9, 2002 | 09:15 AM
freeze2k2's Avatar
Re: urgent: i need to know the bolt pattern and offset of the 5th gen maxima...
Originally posted by a33
anyone???
thanx
5 on 114.3
stock offset on the 17 inch se wheels is 45 i believe.
Old Jun 9, 2002 | 11:40 AM
cobymoby's Avatar
The center bore of the hub is 66.1. Most wheels have a 73 center bore so you should (or need) to get hub rings.
cheers
Old Jun 10, 2002 | 12:02 AM
a33's Avatar
a33
i am planning to the 18x9 wheels and i think the offset is 35
will they fit??
Old Jun 10, 2002 | 12:11 AM
CIRCO's Avatar
will they fit??
I believe the offset of 50 is stock. Thats what I have heard. I am sure 18x9 will fit its just how much will they stick out with a 35mm offset. I think Matthew could tell you a thing or two about offsets
Old Jun 10, 2002 | 03:04 AM
Tony Fernandes's Avatar
Re: Re: urgent: i need to know the bolt pattern and offset of the 5th gen maxima...
Originally posted by freeze2k2
5 on 114.3
Or 5 on 4.5. Just another way of saying it I guess.
Tony
Old Jun 10, 2002 | 04:11 AM
Blu's Avatar
Blu
the tits
5 x 4.5 or 5 x 114.3 and 50 offset i think
Old Sep 10, 2002 | 01:27 PM
sil SE's Avatar
sorry to bring this back up, searching for "stock + offset" and stuff yields millions of results...
can someone confirm this 50 offset on the stock 17" wheels?
Old Sep 10, 2002 | 01:43 PM
UMD_MaxSE's Avatar
Got Bent?
I thought the offset on the stock wheels is 45.... you can go between 35 and 45 for your offset.
Old Sep 10, 2002 | 02:22 PM
sil SE's Avatar
im kinda thinking about getting a 300zx but saving the oe 17" from the max, dont know if itll go.
having a hard time finding the Z's acceptable offsets, and the offset on these wheels.
45?50?
Old Sep 10, 2002 | 08:29 PM
MAXRAY's Avatar
will they fit??
for 2k2's, on SE, the offset is 45. on GLE, offset is 40. if your car is lowered or plan to lower, an offset of 35 w/ 9" wide rims will most likely result in rubbing.
Old Nov 7, 2002 | 09:26 PM
Edward Lee's Avatar
I thinkk that the optimum offset is between +38 and +45. On an 8" wheel go with the +38 on a 8.5" wheel I would think that the 38+ would be the limit with an offset at around +40 to be a safer bet. Does anyone know how much room there is behind the wheels. Like would an offset of +45 on an 8.5 wheel rub suspension or inner fender wells?
lowpost99
Oct 26, 2025 06:53 PM
MAXSE5SPD
Sep 17, 2022 04:00 AM
I<3 A32's
Sep 10, 2015 11:07 AM
Violator
Sep 9, 2015 10:14 AM
Lowered_a33
Sep 1, 2015 07:49 PM
