2001 FSTB installation photos needed...
yes, I did search but I did not find one that shows a Courtesy or other 'non getto rigged' FSTB installed...I am looking specifically for photo's on the driver's side. The airbox bracket and some kind of connector/switch look like they might be in the way.
Re: 2001 FSTB installation photos needed...
the circular sensor is going to contact the bar which is bad if the bar is heated during driving. u can either relocate the sensor....or, if u have intake installed, get one of the rubber spacer from your stock airbox, along with the bolt, and install that to the bracket and the sensor so u will have an inch gap from the bar.
Re: Re: 2001 FSTB installation photos needed...
Re: Re: Re: 2001 FSTB installation photos needed...
I think Stillen FSTB already came with some spacer that was used for that.
On the 2002 SE when installing Stillen FSTB that spacer is not needed, if you live near Boston area, I can send that spacer to you.
Later.
Later.
