Ground Control Coilovers- I need help!
Old Jun 27, 2002 | 11:47 PM
asu174's Avatar
Clay Aiken has fancy genitals
I have the Ground Control coilovers with Eibach springs. They came on the car when I bought it so I haven't had the opportunity to play with them before they got mounted.
Okay, I am going to write this in lamens terms because I don't know the technical names.
Is the threaded red thing supposed to be able to turn? I can turn it AND the gold thing that you tighten on one side of my car, but on the other side of my car, I cannot turn the red thing- JUST the gold thing. I can screw the gold thing up and down the red thing, but the red thing won't budge.
I can also feel that there is about 3/4 inch of threaded red thing being wasted below the gold thing on the one I can't turn. I would like to utilize the extra drop.
Do I need to just give the one that won't turn some elbow grease? Or is supposed to be immobile like that and the one that IS able to turn is just loose?
Does that make ANY sense?
Old Jun 28, 2002 | 06:24 AM
srbarnes4ever's Avatar
Re: Ground Control Coilovers- I need help!
Oh my...I like your layman's terms! If I recall correctly...you should be able to turn the adjustment ring (gold thing that tightens with an allen wrench) and NOT the threaded body itself. It should remain stable and should not rotate at all. Someone please correct me if I'm wrong, but that's how it is on my Escort GC suspension. The only thing that should be able to move is the gold thing as you adjust the height higher or lower. Good luck amigo!
Old Jun 28, 2002 | 07:58 AM
asu174's Avatar
So basically on the side that DOES turn, something is horribly wrong then?
Old Jun 28, 2002 | 08:08 AM
As I recall on mine, the red portion was press into the bottom portion and could not move. You should call GCs tech. number directly and ask them wtf is up.
Old Jun 28, 2002 | 11:37 AM
Y2KevSE's Avatar
Rice Boy in Denial =)
For the rear red things, yes, they can be turned. For the front red things, no, they shouldn't turn.
The gold ring will not go all the way down on the front struts, but they should on the rear struts.
Old Jun 28, 2002 | 02:02 PM
asu174's Avatar
So am I going to die soon if the front drivers side DOES turn?
Old Jun 28, 2002 | 02:11 PM
Thanks for the clarification Kev...I was hoping someone with these on a Max would chime in. I don't recall even the rears turning on my Escort but they may have been able to as I wasn't using the minimal travel setting. Is there a functional reason why the rears turn?
Triple8Sol's Avatar
I miss the .org!
Asu: you got your rims quick!
Old Jun 28, 2002 | 02:20 PM
asu174's Avatar
Yeah, but one of them got bent by Fed Ex in transit- fukking morons. Awaiting the 4th wheel to come next week. Right now I'm rolling on 3 new ones and one old one. It is embarrassing.
Old Jun 28, 2002 | 02:39 PM
lcf's Avatar
lcf
tarun900
19
Dec 20, 2021 06:57 PM
tseng1023
Oct 15, 2015 08:30 AM
RealityCheck
Oct 2, 2015 06:34 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
