2k Max 5 Speed vs 1990 SHO
Old Jul 2, 2002 | 10:46 AM
jarturo's Avatar
I used to own a 1990 Taurus SHO 5 speed in which I installed a Borla cat back exhaust and upgraded the mass air flow intake from a 55mm to 80mm. The SHO had a redline of 7200 rpm and from 4k to 6k on the tach, the engine came to life and really pulled. I now have a 2K SE 5 speed with an UDP and I'm waiting for the Warpspeed B and Y pipes.
Once the Max engine hits 4K, the engine doesn't behave as nearly as strong as the SHO. It seems like it is being exhaust flow restricted.
Will the addition of the Y and B pipe bring additional life to the Max engine in the 4K to 5.5 k range?
Old Jul 2, 2002 | 11:07 AM
hawkdog's Avatar
Re: 2k Max 5 Speed vs 1990 SHO
Will the addition of the Y and B pipe bring additional life to the Max engine in the 4K to 5.5 k range? [/B]
Yes it helps up high, but it will hurt you down low a little bit. And if you're taking it up to 5.5K you might as well be taking it all the way up to 6.6K and using all the power...and that's where you hear the cool "WHOOOOSH" sound with the y-pipe too.
Old Jul 2, 2002 | 11:25 AM
Matticus's Avatar
One of the biggest diffs in the engines is the switching of the intake runners, the SHO switched to the short fat runners about 1K RPMs soon, which enabled you to "feel" it through 3K RPMs. The Max has the same technology except it switches intake runners at like 5K RPMs which only gives you 1.5KRPMs to use until redline. We need to figure out a way to turn on the shorted intake runners at 4K RPM vs. 5K. The VQ would really pull then.
Old Jul 2, 2002 | 12:00 PM
Maximam's Avatar
Re: Re: 2k Max 5 Speed vs 1990 SHO
YUP!
I do remember the SHO as I had a 1990 SHO with a pro MAF, Y-pipe, etc..... That car was pretty damn fast. It was great on the highway but horrible from a stop. I also had the redline moved up to 7800 rpm!!!
Old Jul 7, 2002 | 11:58 AM
Toolman's Avatar
Does the Max actually switch from one set of runners to another, or does it just open the runners in addition to the ones that are always open? That is how the SHO works. You are always breathing through the long runners, but at 4k (on stock SHO's), the butterflies are actuated and you can now breathe through all runners.
Old Jul 7, 2002 | 01:42 PM
Maximam's Avatar
Re: Re: Re: 2k Max 5 Speed vs 1990 SHO
I knew you would show up!
All I know is the SHO is very nice on the highway!!
sctludwig
Sep 1, 2022 01:32 PM
captchaos
Mar 15, 2016 12:18 PM
Maxxx10
Sep 13, 2015 03:16 PM
MaxRPM6
Sep 11, 2015 06:56 PM
I<3 A32's
Sep 10, 2015 11:07 AM
