Racingbrake BBK 6th&5th GEN, Z&G
Old Sep 9, 2009 | 06:41 AM
Nietzsche's Avatar
NEW PRICE 500
13" two piece rotors, 4 piston caliper, black. Fits 6th & 5th gen, Z & G, altima L31.
500!
Awesome brakes for dirt cheap
Old Sep 9, 2009 | 07:54 PM
My-Body-Is-Ready's Avatar
weight of the 2 piece rotors? i might want to take those off you if your willing to sell
Old Sep 10, 2009 | 07:46 PM
Nietzsche's Avatar
14.4 according to racingbrake
Old Sep 11, 2009 | 12:11 AM
how much you want for them? shipped to ny
also will this fit on 6th gens with z32 calipers?
Old Sep 11, 2009 | 03:31 PM
Nietzsche's Avatar
I would say no, they are slightly taller than stock brakes.
Old Sep 12, 2009 | 02:01 PM
what do you mean i dont get it?
right now i have 13.1 inch brambo rotors on mine with z32 calipers.
what do you mean "they are slightly taller than stock brakes" whats "they"
Old Sep 12, 2009 | 11:43 PM
Nietzsche's Avatar
Sorry, was thinking of stock Max rotors which are 12.6" if I remember
Old Sep 17, 2009 | 08:02 PM
Nietzsche's Avatar
Anyone?
Old Sep 17, 2009 | 08:52 PM
NiZMo1o1's Avatar
your running the cobra brackets , so you should be good.
Old Sep 18, 2009 | 11:09 AM
Jeff92se's Avatar
I'm needing a caw
1000 OBO! Needs to go!
Although the 6th gens use the same sized oem rotors as the 05+ G/Zs, I don't think this kit is compatible with all the above. IMHO, it fits either just the 6th/5th (probably 4th and 3rd if that's true) or just the G/Z. Not both. FWD and RWD Nissan/Infinitis have traditionally different caliper mounting dimensions making swapping brake caliper inbetween the two impossible (unless you have a bbk bracket specifically made to do so)
Did you actually have this installed on your 6th gen?
Old Sep 18, 2009 | 12:57 PM
Nietzsche's Avatar
Yes I did, and I assure you it fits all of the above. The alignment is the same the only thing that is different is the spindles themselves.
Old Sep 26, 2009 | 12:57 AM
Nietzsche's Avatar
ttt
Old Sep 30, 2009 | 09:04 PM
Nietzsche's Avatar
NEW PRICE MUST GO!!!
Old Sep 30, 2009 | 09:11 PM
Corelventura's Avatar
Assuming these are front bbk?
Old Oct 1, 2009 | 06:54 AM
Nietzsche's Avatar
Yes, they are fronts
Old Oct 1, 2009 | 09:11 AM
Jeff92se's Avatar
I'm needing a caw
What's the model number of this kit again? Thanks for the info
Old Oct 1, 2009 | 05:46 PM
Nietzsche's Avatar
The current model is 2027-311-4111, I have the older CP4 series calipers though.
Old Oct 2, 2009 | 12:48 PM
the macedonian's Avatar
are these still available ?
if yes - PM me with price shipped to Canada M4H1P3 postal and how many k's have you put on them
Old Oct 2, 2009 | 06:40 PM
Nietzsche's Avatar
PM sent!
Old Oct 7, 2009 | 12:38 PM
Nietzsche's Avatar
Doesn't anyone want a BBK?
Old Oct 10, 2009 | 01:35 PM
Nietzsche's Avatar
600 NEED MONEY
Old Oct 14, 2009 | 10:15 AM
Nietzsche's Avatar
ttt
Old Oct 14, 2009 | 04:54 PM
Jeff92se's Avatar
I'm needing a caw
Where are the lines and how many miles on this setup?
Old Oct 14, 2009 | 06:01 PM
Nietzsche's Avatar
I do not have the lines any longer, not sure were they went. Brakes were on the car 6 months and about 5k miles.
Old Oct 21, 2009 | 07:41 PM
Nietzsche's Avatar
ttt
Old Oct 22, 2009 | 10:07 AM
Jeff92se's Avatar
I'm needing a caw
Can you detail what you did because in this post you said you had to space the caliper up 4.6mm I assume it was this kit you were referring to.
http://forums.maxima.org/6364589-post97.html
Did you modify the rotor or bracket in any way?
Old Oct 22, 2009 | 03:49 PM
Nietzsche's Avatar
The problem ended up being that the bracket was cocking and I didn't notice. Took a mill or two off and everything fit. No spacers or anything else, just me thinking to hard and not looking at the obvious. It's a bolt on affair with just the brackets and calipers.
Old Oct 22, 2009 | 11:04 PM
Jeff92se's Avatar
I'm needing a caw
You shaved the rotor down a few mm? Because I was thinking of putting back on a G/Z.
Old Oct 23, 2009 | 12:43 AM
Nietzsche's Avatar
No, I took it off the bracket. The rotors and calipers are untouched. I'll snap a pic sometime tomorrow.
Old Oct 23, 2009 | 08:40 AM
Jeff92se's Avatar
I'm needing a caw
I don't get it. How is shaving the bracket going to give you more room? i guess I need pics. But if you alterned the mounting dimensions, then it will no longer fit correctly on a Z or G. Which goes back to my original statement about the mounting differences inbetween the 6th gen and the G/Z.
Essentially, this is a 6th gen / Altima only bbk now right? Still a good deal though
Old Oct 23, 2009 | 05:25 PM
Nietzsche's Avatar
No, it still fits a Z/G. I didn't alter the mounting holes. I'll post a pic later tonight to clarify. Basically the inner edge of the bracket was barely touching the spindle which cocked it when fully tightened.
Old Oct 23, 2009 | 07:37 PM
Nietzsche's Avatar
The gray area in the first pic is the part that was removed. The second pic is a side view so you can see it doesn't effect alignment. The valley is just slightly deeper all the mounting holes are the same. It allows it to clear the slightly higher spindle on a Max/Altima.
Attached Thumbnails Racingbrake BBK 6th&5th GEN, Z&G-091023_212353.jpg   Racingbrake BBK 6th&5th GEN, Z&G-091023_212425.jpg
Old Oct 23, 2009 | 09:17 PM
tuko316's Avatar
how much is the replacement rotors for this?
Old Oct 24, 2009 | 06:46 AM
Nietzsche's Avatar
New rings are 212 a piece right now, but you shouldn't need them for a long time.
Old Oct 29, 2009 | 06:13 AM
Nietzsche's Avatar
ttt
Old Nov 6, 2009 | 09:57 AM
Nietzsche's Avatar
bump
Old Nov 12, 2009 | 02:30 PM
hijack784's Avatar
hi, how do you think my non-ABS brake master cylinder 05 altima will support these calipers?
Old Nov 13, 2009 | 07:57 PM
Nietzsche's Avatar
it would be fine for non abs
Old Nov 16, 2009 | 07:51 AM
Nietzsche's Avatar
500
Old Nov 16, 2009 | 10:20 AM
I VIK I's Avatar
If it means anything, I bought a whole bunch of suspension parts from this guy and they all came in nice and for a decent bargain, Easygoing good guy to deal with.
