NJ FS: 07.08 Exhaust Manifolds W/Cat's. AND Complete engine
Old May 21, 2012 | 08:17 AM
MarcL's Avatar
I have A set of exhaust manifolds pulled from a 20K car, with the catalytic converters. $200 for all of it (for pickup). I will ship at your cost. Looks like this will fit 06-08 Maxima..
The rest of the engine is on Ebay;
http://www.ebay.com/itm/300713940874
Old May 21, 2012 | 01:15 PM
L36's Avatar
L36
Why not try to fix this engine, besides the oil pump is mechanical. If all the seals leading from the oil pump are good and you actually had the proper lever of oil in there, i see no way of the engine having such low oil pressure unless the sensor/readout is faulty, less the oil pump visibly had issued in it.
Old May 21, 2012 | 01:48 PM
MarcL's Avatar
I tried to fix the last engine, (same problem) and had no luck. Maybe it could be fixed, I am just too frustrated to mess with it at this point.
Old May 29, 2012 | 08:00 PM
maximatogo's Avatar
I believe I have a similar issue and the problem is the o-rings that are between the block and inner timing chain cover. However, I've not yet torn down the engine.
Old May 29, 2012 | 10:42 PM
MarcL's Avatar
Either way, the engine and other parts are all still available.
Old Aug 3, 2012 | 08:31 AM
MarcL's Avatar
Everything is still for sale.. The engine did not sell on Ebay, so if no one wants a complete engine I will part it out.
Let me know what you need!
Old Aug 9, 2012 | 12:56 PM
2kayznmaxima's Avatar
how much for the engine?
Old Aug 9, 2012 | 07:44 PM
MarcL's Avatar
At this point, I'd consider any reasonable offer.
Old Aug 11, 2012 | 03:56 AM
VQ'rInWLA's Avatar
Subd in case you decide to part engine out.
Old Aug 11, 2012 | 03:58 AM
VQ'rInWLA's Avatar
Also, have pics of it? Wanna see what I can make use of.
Old Aug 11, 2012 | 05:18 AM
MarcL's Avatar
Old Aug 11, 2012 | 05:19 AM
VQ'rInWLA's Avatar
Not ready to part out yet right?
Old Aug 11, 2012 | 05:21 AM
MarcL's Avatar
I am just about ready to do that.. What do you need?
Old Aug 11, 2012 | 05:22 AM
VQ'rInWLA's Avatar
Front and rear valve covers. Also, can you snap a pic of the whole coolant log from different angles? And be sure to include both sensors on it pls. Still thinking of what else I can use...
Old Aug 11, 2012 | 05:25 AM
MarcL's Avatar
I will be at the shop today.. I may have some of those parts from a previous motor.
Coolant Log? I assume those are the solid pipes bolted to the engine? I will get some photos today of the other one I have (not on this engine).
Old Aug 11, 2012 | 05:27 AM
VQ'rInWLA's Avatar
Ok. Ill need em for an 04+. Looking for the replaceable guide tube seals unlike the first generation 3.5's
Old Aug 11, 2012 | 05:29 AM
VQ'rInWLA's Avatar
Coolant log and rail are the pipes on the front of the motor. Theres two sensors on the drivers side where the pipe runs right below the front valve cover.
Old Aug 12, 2012 | 05:44 AM
MarcL's Avatar
I have the coolant pipe that goes between the head.. is that what you are asking about? The other pipes that wrap around from the back of the engine to the front are on the complete engine I have, but I think I tossed out the other ones I had... but I don't see any sensors in those pipes, so I don't think that is what you are asking for?
If you want a photo of the pipe between the heads, I have that. PM me your direct email address and I can send it.
Old Aug 12, 2012 | 02:44 PM
VQ'rInWLA's Avatar
I just pulled them from a jy yesterday. But Im still very interested in the 6th gen valve covers. LMK as soon as you can
Old Jul 3, 2013 | 11:01 PM
Goodspeed91's Avatar
Still have the cats?
Old Jul 4, 2013 | 06:23 AM
MarcL's Avatar
Cats are gone, sorry..
Plenty of other engine parts though!
Old Jul 8, 2013 | 12:10 PM
justin2386's Avatar
EVAP purge valve!! need that asap!
bolted to side of intake..has a blue plug connected and two hoses, one goes to the intake elbow right behind the throttle body
Old Jul 9, 2013 | 06:13 AM
MarcL's Avatar
I will check and see if I have it this weekend.
Old Jul 9, 2013 | 07:56 AM
justin2386's Avatar
thanks
Old Jul 31, 2013 | 11:43 AM
MarcL's Avatar
What the heck, might as well bump this again.. Still have lots of parts.
Old Aug 1, 2013 | 10:35 AM
justin2386's Avatar
Check that part for me?
Old Aug 1, 2013 | 08:43 PM
MarcL's Avatar
Forgot all about it.. and I was just at the shop tonight. I will be back there this weekend and look for it. Not exactly sure what I am looking for though!
Old Aug 2, 2013 | 02:04 PM
justin2386's Avatar
i can text you a pic if youd like?
Old Aug 5, 2013 | 06:24 AM
MarcL's Avatar
I don't have MMS, but if you have a link to a photo that would be helpful.. I was going to look it up in the FSM.
Old Aug 12, 2013 | 12:22 PM
MarcL's Avatar
Old Aug 13, 2013 | 08:04 AM
justin2386's Avatar
In that picture how its oriented its at the top of the intake, just to the right of the throttle body, has the short hose with that little black canister thing attached to it..I just need that, don't need any of the hoses or anything that attach to it
Old Aug 13, 2013 | 08:05 AM
justin2386's Avatar
Might need the cats too..might have blown mine apart the other day, waiting to hear back from the shop now
Old Aug 13, 2013 | 09:37 AM
MarcL's Avatar
Cat's are gone.. Ended up selling them to a scrap metal place.
This engine came out of a 2007 or 2008 Maxima, and based on the Nissan parts manual this valve got a new part number in 2005.. Based on that, I would assume the one I have would work properly 2006+, and some 2005... (just making sure this will work for you).
Old Aug 14, 2013 | 07:01 AM
justin2386's Avatar
I have an 06
Matt93SE
May 24, 2019 02:58 PM
vingodine
45
May 21, 2016 12:46 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
george__
Aug 18, 2015 07:06 PM
