what PSI are our 18 inch tires sapose to be set at front and rears?
Aug 10, 2003 | 01:50 PM
i cant seem to find it anywhere?? and what should i set it at for the track?
Aug 10, 2003 | 02:38 PM
Look under the arm rest.
CM.
Aug 10, 2003 | 02:56 PM
Do not exceed the maximum inflation pressures shown on the sidewall of the tire which should be around 44psi (I will be taking delivery in a month).
-or- CanadianMoFo's suggestion under the armrest as stated in the owners manual
From tirerack.com......
The rule of thumb is for every 10° Fahrenheit change in air temperature, your tire's inflation pressure will change by about 1 psi (up with higher temperatures and down with lower).
In most parts of North America, the difference between average summer and winter temperatures is about -50° Fahrenheit...which results in a potential "loss" of about 5 psi as winter’s temperatures set in. And a 5 psi "loss" is enough to sacrifice handling, traction, and durability!
Additionally, the difference between cold nighttime temperatures and hot daytime temperatures in most parts of the country is about 20° Fahrenheit. This means that after setting tire pressures first thing in the morning, the vehicle’s tire pressures will be almost 2 psi higher when measured in the afternoon (if the vehicle was parked in the shade). While that is expected, the problem is when you set your vehicle’s tire pressures in the heat of the day, their cold pressures will probably be 2 psi low the following morning.
And finally, if the vehicle is parked in the sun, the sun’s radiant heat will artificially and temporarily increase tire pressures.
Aug 10, 2003 | 03:00 PM
im thinking like 33 psi all around?????
Aug 10, 2003 | 06:10 PM
[IT'S 32 PSI ALL AROUND QUOTE]Originally posted by specv
im thinking like 33 psi all around????? [/QUOTE]
Aug 11, 2003 | 09:08 AM
ok so its 33 psi all around?
Aug 11, 2003 | 09:15 AM
Sounds about right. I wouldn't go anymore than 40 PSI...
