Tires and Wheel Well Gap Difference
Old Aug 23, 2003 | 05:28 PM
ocuihs's Avatar
Has anybody noticed that the front tires/wheel well has at least 2 inches more clearance than the rear tires/wheel well (less than an inch)? It must be the new redesign of the rear suspension than the front. Inputs? Comments?
Old Aug 23, 2003 | 05:37 PM
HydroPnik's Avatar
Same deal on my 5th gen. Must have something to do with the clearance needed when the front tires are turned so they don't hit the wheel wells.
Old Aug 23, 2003 | 06:28 PM
bluemaxx's Avatar
Moderator GT-R
...HydroPnik...hmm...I wonder if that's where the stolen HIDs are going?...
Old Aug 23, 2003 | 09:01 PM
MaxMaybe's Avatar
The extra two inches allows the Maxima to have that outstanding 40' turning radius.
Old Aug 24, 2003 | 10:56 PM
psteng19's Avatar
Most FWD cars have more space in the front wheel well than the rear.
Old Aug 25, 2003 | 10:41 PM
lightonthehill's Avatar
HydroPnik is on the button, and psteng19 is close.
Visualize a car hitting a bump (like a speed bump) that causes the tire and wheel to rise sharply about four inches. The rear tire is always alined straight front-to-rear, and rises INSIDE the fender. The front tire, however, may be turned at any angle, and stick partly OUTSIDE the fender, so needs a little extra vertical clearance.
This situation is also sometimes noticable on rear-drive cars, as it is more related to which wheels TURN than to which wheels DRIVE.
Some folks try to 'fill out' the fender by putting on much larger tires. This defeats the purpose of the gap, and can cause the tire to rub the frame on tight turns. I have even seen this cause fender damage when a car hit a bump while turning sharply.
MR2 T'd
Jul 9, 2021 05:06 AM
02nissmax
Sep 5, 2015 01:50 PM
homeyclaus
Sep 3, 2015 06:15 PM
maximusrising
Sep 2, 2015 09:55 AM
coasterswim
Sep 2, 2015 07:43 AM
