View Poll Results: Does Your 2004 Maxima Shimmy Or Shake?
No Definitely Not.
25.00%
No I Don’t Think So.
10.06%
What Does Shimmy Mean?
5.18%
Yes But Not Enough To Worry About.
10.06%
Yes It Did But It Has Been Repaired.
3.96%
Yes Between 45 and 55 MPH.
12.20%
Yes Between 50 and 65 MPH.
23.17%
Yes Other.
10.37%
Voters: 328. You may not vote on this poll
Does Your 2004 Maxima Shimmy?
Old Sep 30, 2003 | 05:20 PM
bluemaxx's Avatar
Moderator GT-R
If you don't already know...http://forums.maxima.org/showthread.php?t=218995
Old Sep 30, 2003 | 06:52 PM
lobewiper's Avatar
shimmy?
Originally Posted by bluemaxx
After Hunter 9700 balancing, with no road force variance adjustments because both front wheels showing only 2 pounds of variance: NO shimmy on smooth pavement. BUT, occasional and unmistakable shimmy on even moderately irregular surfaces. Conclusion: it ain't just the wheels that are causing all of this.
Old Sep 30, 2003 | 09:31 PM
04OnyxSL's Avatar
I bought my SL about 2 weeks ago and ride it smooth. Sometime I take my hands off so I can check for any shimmy pros.
Old Oct 1, 2003 | 08:07 AM
Sprint's Avatar
testing 123
Old Oct 1, 2003 | 02:34 PM
Glude's Avatar
Mine shimmys and does it when I brake also. My old car did this. It doesnt feel as hardcore in the maxima though, so I live with it.
Old Oct 1, 2003 | 03:17 PM
gmc74's Avatar
a shimmy while braking usually is the result of warped rotors, I wouldn't just live with it, I would have it fixed... that might get expensive in the long run
Old Oct 1, 2003 | 04:10 PM
Glude's Avatar
Well on my old car I replaced the rotors with new ones and guess what? It didnt change a thing. shook just as bad as before. I believe that if you brake hard with a slight shimmy its only gonna intensify when braking. I dunno though Im just stating from what my experiences have been.
Old Oct 1, 2003 | 11:36 PM
fixxxer's Avatar
while i was signing the final papers on my 04, i was asking about the shimmy problem and my dealer said they heard of it , and it was from maximas that sat on the lot too long, that the tires got a flat spot from staying in storage....
i dunno whether to beleive them or not, but whatever just thought id share what they told me.
mine btw doesnt shimmy/shake/vibrate, they were saying they never had a problem yet cuz they are the highest volume dealer in ny (which i think is true) so thier cars dont sit around....
Old Oct 2, 2003 | 12:02 PM
QuikSilver04's Avatar
That could be a possibility, since there are some members that took their car to a tire shop and they said that they were out of round, which is caused by them sitting in position for too long. When they replaced the tires and got it balanced correctly, it fixed the shimmy so that could definitely be a cause for the shimmy.
Old Oct 3, 2003 | 09:55 AM
lobewiper's Avatar
That wasn't the answer for my shimmy, since I took it home the day after it was delivered (a special order). BTW, my shimmy is not present on really good pavement.
Old Oct 3, 2003 | 10:51 AM
MaxMaybe's Avatar
No shimmy here, thank goodness!
Just picked up my '04 Max SE Auto yesterday. It arrived at the dealership Wednesday and had ten miles on it when I drove away.
I went out last night and took it up to 65 on a smooth stretch of four-lane highway. NO SHIMMY. There might be some vibration felt in the steering wheel, but no shimmy.
I'm elated because one of the test cars I drove in June definitely had a nasty shimmy around 50 mph. I found the same thing on an Audi A6 4.2 test drive a few years ago. The Audi might be attributed to the car having sat in the same place for quite a while. Don't know about the Max I drove.
Old Oct 5, 2003 | 11:47 AM
gmc74's Avatar
ummm, then you don't have a shimmy problem with your car, you just don't like the way it feels all of the misperfections in the road. If it goes away when the pavement changes, then it isn't a problem with the car.
Old Oct 5, 2003 | 12:01 PM
lobewiper's Avatar
Well, GMC, I agree with you but only up to a point. Tell me why a moderately irregular pavement can sometimes induce sustained, rhythmical shimmy? Wouldn't the probability of that phenomenon be caused solely by road surface be almost nil? And why does my Max do this but not my Escort and friend's BMW?
Old Oct 5, 2003 | 01:33 PM
SilverMax_04's Avatar
Have you ever driven any vehicle with rubber pneumatic tires across a bridge with a grate surface that allows rain water (and other things) to fall through? Most of these grates "grip" your tires and move the vehicle first to one side (slightly) and then back to the other side (slightly). The first time you drive on one of these bridges it's somewhat scary -- until you get used to the feeling.
When I first got my new Maxima SE, 6 months ago, I got a similar feeling every time I drove over grooved concrete pavement. I had not had this condition driving my previous car (Olds) or my truck (Dodge) over this groved concrete. The groves in the pavement acted like "a grate on a bridge" to the Maxima's tires. I now have over 8,000 miles on the Maxima and the effect on groved pavement has almost gone away.
When this first happened to me, I attributed it to the wide, low profile tires on the new Maxima. Given the widespread shimmy experience among new Maxima owners (16, including me, did not have it while 8 did in a survey on this site), I suspect that these 8 owners are experiencing more than the shimmy I experienced (only on groved pavement) when my Max was very low mileage. I can't venture to guess what is causing their shimmy. It may well be a combination of some or all of these forces: out of balance wheels, out of round tires, warper rotors, uneven road surfaces, out of balance drive trains.
Old Oct 5, 2003 | 04:03 PM
lobewiper's Avatar
My shimmy is absent on pretty smooth road. This would seem to rule out all the factors at the end of your post. My shimmy (when present) occurs on reasonably decent, ungrooved pavement. My guess: there is too much play in the steering system.
Old Oct 11, 2003 | 12:07 PM
04EliteSE's Avatar
I am getting the shimmy now when I am breaking... mostly from highway speeds. Thank God I am due for an oil change soon so they can check it out...
Old Oct 11, 2003 | 06:59 PM
KJSmitty's Avatar
True that is a shimmy but thats from what I would call hard breaking. Your front brake rotors are warped so you get a pulsating/shimmy when you brake - more noticeable braking from high speeds vs intown driving.
See if they will replace or "turn" your rotors.
Big picture though, this is not the shimmy others are experiencing.
Smitty
Old Oct 11, 2003 | 09:12 PM
04EliteSE's Avatar
Ah, but I still get a sporadic shimmy while driving around town as well...
Old Oct 11, 2003 | 09:53 PM
KJSmitty's Avatar
Clarification - if it happens only while braking, its warped/out of round rotors. If thats what you are experiencing be happy, that can easily be remedied. I have nothing until above 50 mph, gets worse as speed increases, braking has no effect. To me it just feels like a couple tires about 2 ounces out of balance, but after ruling that out numerous times the dealer has thrown in the towel. I have a "date" with a Nissan "plant technician" on Thur. I have my fingers crossed.
Good luck
Smitty
Old Oct 15, 2003 | 08:30 PM
anaximander's Avatar
They may have a faulty rotor adjustment issue like the ford/firestone type of fiasco.
Time for the recall.
Old Nov 7, 2003 | 07:59 PM
KJSmitty's Avatar
just checking the stats
Old Nov 8, 2003 | 08:04 PM
Mike_TX's Avatar
It seems to me the shimmy complaints are coming mainly from SL owners ... maybe the poll should have included the trim type - SE or SL - so we could determine if it's model-specific (?)
Mike
Old Nov 9, 2003 | 07:57 AM
MaxPilot's Avatar
Mike
Are you sure Mike? I think it is the other way around.
I agree it would be more helpful to know the model. My SL does not shimmy but does seem to feed-back road imperfections to the steering wheel a lot. I see a lot of SE guys complaining about warped rotors. In 28 years of driving I have never had a warped rotor (I'm on my second Maxima by the way). Could driving style be an issue here? I drive aggressive too! My neighbors think I'm crazy when they see me out using a torqe wrench on my lug nuts however. Make sure the lugs are torqued properly folks!
Old Nov 30, 2003 | 05:41 PM
GMAX04's Avatar
Shimmy
I've had my SL for about 4 months. It did the simmy @ 40 and allot at 72. After 3 new tires and one rim, it's now smooth as silk.
Old Nov 30, 2003 | 07:55 PM
bluemaxx's Avatar
Moderator GT-R
Poll Results
The poll has been up for 60 days. There are 75 votes so far but what does it mean?
The easy way:
Factor out the 7 'What does shimmy mean' replies and we are left with:
68 - votes
35 - no shimmy - 51%
33 - have/had the shakes - 49%
Take out votes from those whose profiles say that they own something other than an 04 Maxima:
68 - votes
31 - no shimmy - 46%
5 - what does shimmy mean - 7%
32 - shimmy - 47%
Kick out profiles that say other than 04 Maxima and profiles that don't specify what car they own:
59 - votes
26 - no shimmy - 44%
4 - what does shimmy mean - 7%
29 - shimmy - 49%
I'm tempted to give the 4 'What does shimmy mean' to the No vote:
30 - no shimmy - 51%
29 - shimmy - 49%
And what about ga2000 who has an 04 but doesn't say so in his profile?
(If the screen name had 04 in it I counted it even if the profile didn't specify.)
The Raw Data...As of 11/30/03
Profile doesn't say what kind of car owned.
Profile says something other than 04 Maxima.
Everybody else.
No Definitely Not. [ 27 ] 36.00%
04OnyxSL, BIGGUY, Blue04SEinIL, DansMax3, drwhiz, ednaz1, e_marston, fixxxer, flyboy216, ga2000, gmc74, I Hack 4 U, joaquink, Maxima04, MaximumMike, MaxMaybe, MAXSE-RIOUS, Memphoman, MikePSmith, Mike_TX, nick wolff, peetah, ramcon, RDM, Rob, Roswell_Maxima, SilverMax_04
No I Don’t Think So. [ 8 ] 10.67%
Blaxima, BLCKMAX, Burny, kb0uy, kiriakos, Redsand187, silver04max, tonywinsc
What Does Shimmy Mean? [ 7 ] 9.33%
CHASE_BXMW, Cool J, lobewiper, MattTheGatt, MaxPilot, Nightline, Tight_Whip
Yes But Not Enough To Worry About. [ 8 ] 10.67%
04SEelite, 98MAXNY, Asmitty, CSlam, hanzar, marmadogg, Mikiusmaximus, RayRey21
Yes It Did But It Has Been Repaired. [ 4 ] 5.33%
diggdyone, GMAX04, mattman2003, Maxmann
Yes Between 45 and 55 MPH. [ 10 ] 13.33%
04EliteSE, 98maxse, bluemaxx, HOTWHEELS, jacksprat01, Jessie D, Konicaman, stevel, texmax, XMan
Yes Between 50 and 65 MPH. [ 7 ] 9.33%
4drsleeper, 90SEBlack, jdc1203, kosd, Ledur, My5thMax, xterradave
Yes Other. [ 4 ] 5.33%
2004BlkMaxSL, Deven2kStickMax, KJSmitty, rburkart
Old Apr 1, 2004 | 07:14 AM
raja618's Avatar
i own an '04 SE and when i first got the max, i didn't have this shimmy/shake thing happening at all. But in the past month or so i noticed the steering wheel shaking when i hit 55-65 mph but as soon as i hit 70 or above the shake went away. I took it a nearby Nissan service center yesterday and told them the situation. Left the car for the day, come back to pick it up the guy tells me that the reason is that I my front right rim is bent. ??????????? How??? Not like I hit anything and caused damage to it without knowing. Well he tells me he put that Rim in the back and the shimmy isn't as significant. Tells me the only way to fix the problem is to buy a new rim (priced at $600). Dont know.. i feel like these guys are being somewhat shady about it. Mind you these are the same guys that couldnt figure out that an unplugged wire was causing my airbag light to flash, even after three seperate visits. Each time a new part was ordered and each time that wasn't the solution. I have an appointment with another dealer tomorrow so l'm going to wait and see what these guys have to say!
Old Apr 3, 2004 | 01:30 PM
Glude's Avatar
My shimmy is just like you said yours was. I also get a hard shake when I brake from highway speeds. Ive had my rotors turned once before by nissan and it fixed the problem for a very short period of time. I honestly think the shimmy I feel from 55-65 is what caused the rotors to warp. I know its not wheels or tires because im now running 19s instead of 18s. My dealership sucks though. I have yet to get a front and rear alignment though so that could be causing my problem. Im not to impressed with the 04 nissan rotors because they have warped twice on me and I dont have much time for the dealer because of work and school.
Old Apr 3, 2004 | 07:14 PM
2k3TitaniumSe's Avatar
Lots of shimmying.
Will different wheel sized help to prevent shimmying.
Old Jun 28, 2004 | 12:27 PM
lightonthehill's Avatar
A year ago, there were more shimmy complaints here for the SE. Now there seem to be more shimmy complaints for the SL.
My SL sometimes (less than half the time) shows a vibration in the steering wheel between 54 and 58 MPH, but is smooth as glass at other speeds. What puzzles me is that I haven't yet been able to tie this shimmy to any particular road surface or driving situation.
I am going to keep testing this, and, once I feel I know how to recreate it, I will take my service tech for a little ride.
I only hope it is a bad tire or wheel type thing, as I dread getting into the 'ultimate' solution; an adjustment of the tension on the steering rack. Unless a TSB has been released lately on this adjustment, the dealer will have to call the dealer in Nashville, TN who developed this fix.
Old Jun 28, 2004 | 02:12 PM
rnupetroop's Avatar
The only shimmy I get is from easing on the break from 55 to 40mph, besides that none other experienced.
At the present time I very rarely experience that since I took the advice of lightonthehill.
I have the 6sp so I use some of the engine along w/breaking and it's pretty smooth. I shouldn't have to do this but my warranty doesn't cover (16800) and eventually I plan on a brake kit swap.
Once again thanks for looking out on the peeling grille, I get mine replaced tommorrow
Oh yeh, only on breaking not riding along.
Old Jun 28, 2004 | 04:46 PM
Smoken04's Avatar
I have a shimmy in my 04 SE that I picked up in May. It's got a shimmy in the wheel at about 55 and above...flattens out around 70-75. It is annoying. It's not when I am braking either. Only problem I have with braking is it pulls to the right while braking sometimes. This shimmy is on my list along with my glove box door and headliner
Old Jun 29, 2004 | 05:43 AM
jrussell915's Avatar
I had a shimmy while braking after 11,000 miles
Dealer shaved rotors under warranty and does not do it anymore. Biding my time until it happens again in a few thousand miles and then I will buy aftermarket rotors.
Old Jun 30, 2004 | 01:47 PM
boondoxmax's Avatar
I get the shimmy when braking. Its strange because when i get my tires rotated and balance it goes away for about 4000 miles until its time to rotate and balance again so i don't think its warped rotors.........something else...
Old Jul 1, 2004 | 04:52 AM
lobewiper's Avatar
It's got to be the rotors. Have the dealer check the rotors for run-out with a micrometer while they are installed on your car (without the wheels, of course).
Old Aug 21, 2004 | 08:38 PM
PrinzII's Avatar
OG and counting...
Hmmmmm.......interesting.
Old Aug 28, 2004 | 02:34 AM
akaxmrxhammer's Avatar
i had my front rotors resurfaced twice already and still have the shimmy along with the infamous wheel shimmy. hopefully the nissan of buena park could fix this problem...
Old Sep 15, 2004 | 11:12 AM
ttbeam's Avatar
I'm glad I didn't vote earlier because it would have been a no, but now that I have had the car 6 weeks and put on 2000 miles it has developed the shimmy somewhere between 50 and 65 mph depending on the road. It's slight enough though that I'm hoping it will get a little worse by the time I take it in for it's first oil change. Need to have the gove box fixed too.
Old Sep 16, 2004 | 02:39 PM
Smoken'04's Avatar
I actually need to make another appointment for my car for the shimmy in the wheel. I am also getting a svibration when applying the brakes as well. The shimmy between 50-65 went away when they balanced the tires. At 6k miles I rotated them and the shimmy was back and now it is really bad. I think I am goin to tell them to balance the hell out of the tires and also do the TSB on the car. I am not goin back again for this.
Old Sep 16, 2004 | 07:42 PM
Thereal411's Avatar
Smoken,
Sounds like we have exactly the same car! glovebox misaligned, shimmy. I have had my tires replaced and the shimmy was worse, after balancing those tires it was much better. But now it has returned about 2 weeks later. Balancing seems it is just a temporary fix, I'm fed up with this car and the dealer's inability to fix it.
