Question about the heat/ac
Old Oct 23, 2003 | 09:42 PM
Leopor's Avatar
I live in Boston, and since it's starting to get cold out I guess I atcually have to use my heat. Used my heat for the first time today, cranked it up to 90 and just hit auto, but I noticed that when I did that, the "A/C" button turned on. So I switched it off, hit auto again, and it turned it back on. Why is that? The air seems to come out the same temp either way, so it's no big deal, but isn't the A/C button only supposed to activate when you want the air cold? Goofy question, I'm just curious.
Old Oct 23, 2003 | 09:48 PM
KJSmitty's Avatar
Originally Posted by Leopor
I live in Boston, and since it's starting to get cold out I guess I actually have to use my heat. Used my heat for the first time today, cranked it up to 90 and just hit auto, but I noticed that when I did that, the "A/C" button turned on. So I switched it off, hit auto again, and it turned it back on. Why is that? The air seems to come out the same temp either way, so it's no big deal, but isn't the A/C button only supposed to activate when you want the air cold? Goofy question, I'm just curious.
Defrost especially, but when cold and you set high temps the AC may / will come on to remove moisture from the interior air. Heats better that way and helps from fogging up the windows. The AC system whether cold or hot is a de-humidifier..
Smitty
Old Oct 23, 2003 | 10:10 PM
RDM's Avatar
RDM
good question
That is a good question, I also was wondering that. We all know the the A/C robs HP so does anyone know that if the A/C light is one it is spinning the compressor?
Old Oct 24, 2003 | 09:41 AM
chrisaust's Avatar
Ive also noticed that when its cold and you turn the temp up on Auto, the heat wont come on right away, which i realized is kind of a nice feature, it wont start blowing air until the engine's warmed up as well, so its not just blowing really cold air at first and then heat after that.
Old Oct 24, 2003 | 11:46 AM
hanzar's Avatar
Have you noticed that there is no button "Heat" or "Cool", only temperature settings and A/C on/off? Air conditioning is on for heat and for cool. I guess they are using the true meaning of the term "air conditioning", which isn't simply cool but is the conditioning of the air to your preference. So whether you want heat or cool, you must turn on the "air conditioning system".
Old Oct 24, 2003 | 03:10 PM
bluemaxx's Avatar
Moderator GT-R
Power is cut to the a/c clutch at WFO throttle.
Old Oct 24, 2003 | 04:28 PM
MaxPilot's Avatar
Maybe the Max has a Heatpump!
Old Nov 30, 2003 | 03:13 PM
kosd's Avatar
What is "WFO" throttle??
Old Nov 30, 2003 | 04:11 PM
Quicksilver's Avatar
OT n00bs FTMFCSL
That should be "wide open throttle"
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
