20"s...Unsafe or Not a Good Idea?
Old Feb 25, 2004 | 04:26 PM
clayman88's Avatar
Like most people in the forum, I'm trying to find some bling to roll around on and at first I was thinkin' 20" is the way to go. Until..I was shopping around on tirerack.com. I couldn't find any 20"s available for the 04 max. I called their CS & asked why. The answer I got was that (in a nutshell & terms I understand) 20's would not leave enough room for tires that would be safe. The rep on the phone explained, tires, (small enough to fit) would break or be ruined far too easily.
Any thoughts on this?
Old Feb 25, 2004 | 05:03 PM
white m3 guy's Avatar
thats bs 20's will be fine on a 04 maxima you shouldnt go any lower on a 04 max
Old Feb 25, 2004 | 05:31 PM
imxelite's Avatar
Well I had 20's on my last car and they can be driven on but you will be replacing flats often if you live near rough roads. Oh and don't even think your going to be racing anyone
Old Feb 25, 2004 | 08:02 PM
clayman88's Avatar
Are you saying 20's aren't good for speed?
Old Feb 25, 2004 | 08:27 PM
imxelite's Avatar
Yes, they want perform well at all. Plus we are talking about cars here it's not like your putting it on a Jag a car that can come factory with 20's and perform well with them too. You could probably perform at high speeds but you won't get there as quick as you would with 18's. Or you could invest in some high performance tires that would probably run you about 1500 or more to get the ride your looking for.
Old Feb 25, 2004 | 09:32 PM
lightonthehill's Avatar
20" wheels are for show, not for driving.
With 20" wheels, in order to leave room for the struts and springs to fully compress and expand (as in real driving), you would probably need to go with no higher than a 35 profile. A 35 profile tire is fine if you don't mind a harsh ride, and don't plan on driving on anything but very level surfaces. It puts the tread just two or three inches from the wheel, so you don't want to hit any irregularity in the road, as a 35 profile tire has very little sidewall height (distance between tread and wheel) in which to flex.
Also be aware that the load capacity of a 35 profile tire is much less than a higher profile tire of the same width.
edit - But if you have your heart set on 'looks' rather than performance, there is another thread on this board started by RayRey21 that discusses 20" wheel/tire options in detail.
Old Feb 25, 2004 | 11:24 PM
jsmithsole's Avatar
*moderator*
When I was looking for my 20" wheels I found many different options available, I was going into actual shops more than online. I am running 245/35/20's and the ride isn't that "harsh" actually. My car rides pretty good even with the Eibach kit installed (I do plan on replacing the struts as soon as they come out though) The roads out here in Ca. are pretty smooth for the most part so I luckily haven't had any problems with potholes or rough surfaces. Unsafe, I'd say no, I went about twenty different wheel places (some sketchy and some reputable) and got a lot of feedback before my purchase. I've been throughly pleased.
Old Feb 26, 2004 | 08:53 AM
mikenatas's Avatar
i haven't made my car squeal on corners since i got my 20s...with
stock 17s the car would squeal all the time...you can argue
that the tires are better...so be it.
roads down here (hawaii) are probably as bad as paved roads can
be...with 20s you're gonna feel the irregularities.
bending the rim and 'bruising' the tire are definate possiblilities.
i have read that wheel weight is a bigger problem...upgrading the
brakes would solve this problem...but you can find 20s that weigh
less than the stock...
Old Feb 26, 2004 | 06:52 PM
jsmithsole's Avatar
*moderator*
Does anybody know how much the stock wheels weigh????
Old Feb 26, 2004 | 07:22 PM
mikenatas's Avatar
somebody posted it before...44 or 47 lbs...don't get mad if i am totally off...
can anybody find how much 20" lexani VP one piece weigh?
i can't...
Old Feb 26, 2004 | 08:35 PM
Ammi's Avatar
350 Detroit Muscle
dammm 44 lbs for stock wheel?
Old Feb 26, 2004 | 09:41 PM
KLOOGY's Avatar
L33t BMW Drivah
Lexani wheels are heavier than shiznit. If I had a 6th gen, I would roll 20 inches strong....at least. I would personally step up to 22's.....but its your choice. Just make sure you dont get some ghetto chrome wheel.....chrome is a hit or miss adventure.
Old Feb 26, 2004 | 10:11 PM
Glude's Avatar
I got some 19" axis spiders ready to put on whenever I convince myself to spend 1000 bucks on the tires even though I have stock 18s and the crappy azz RSAs still got a TON of tread left after 23,000 miles. I went 19s because I wanted to go bigger but be able to run a 40 series tire without rubbing. Speed is still a factor to me too. But if your stricly looks the 20s or up would be sweet on the 04.
Old Feb 28, 2004 | 11:46 PM
usmanasif's Avatar
Any of you guys selling your stock 17-18" wheels? Please PM me! Thanks!
P.S: This is my 100th post so I have not changed from a Max Enthusiast to a Max Fanatic! Yippeeee!
Old Feb 28, 2004 | 11:53 PM
KLOOGY's Avatar
L33t BMW Drivah
19 inch tires are a lot more expensive than 20's........thats something you guys should remember. If you're into looks, and dont care about speed, I would say once again go 20 +......My 19 inch tires cost a grip !
Old Mar 2, 2004 | 06:21 AM
MrHpsn's Avatar
Thanks for all the input I'm torn myself between which size to use, I'm looking at 20" Lowenhart BR5's, but love my speed !!!!!
Old Mar 2, 2004 | 08:15 AM
mikenatas's Avatar
20" Lowenhart BR5's should be lighter than the stock rims...i think?
my friend has those on a TL and he loves 'em...
maxprivate
Forced Induction
21
Jul 8, 2017 09:48 AM
pkfinn
Jan 3, 2016 02:55 PM
follyburr
Aug 7, 2015 09:50 PM
13Maximasv
Aug 7, 2015 10:56 AM
