Infinity Basslink Installation - need help
Old Oct 10, 2004 | 12:47 PM
G35-Not!'s Avatar
I went to tap the Basslink in to high level speaker wires are there are 4! wires going in to each speaker. If you've successfully installed the Basslink in this manner which wires did you tap?
Old Oct 27, 2004 | 03:56 AM
SilverSixth's Avatar
Just a follow up. I'm getting ready to install a basslink myself. Are you happy with yours? Where did you mount it? Also, I can't decide if I should hook it up to the Speaker level inputs or buy a converter. Any recommendations? Thanks.
-Joe
Old Dec 10, 2004 | 10:49 AM
bump ....................
Old Dec 10, 2004 | 03:58 PM
install30's Avatar
If you look at the installation instructions they recommend using the high level inputs instead of the low level inputs(ie rca's).
Old Dec 12, 2004 | 08:41 AM
Thanks for the info on the high/low level issue. Where did get the turn on power from. Thanks again!
Old Dec 12, 2004 | 06:10 PM
install30's Avatar
If you're pre-wired for satellite radio or have Bose, you can catch turn-on from either of those sources. Just check it with a multi-meter.
9aj9
Apr 5, 2020 12:11 AM
Mar 12, 2020 12:06 AM
RinconI30
Nov 10, 2015 10:55 PM
2kmaximel
Sep 10, 2015 08:13 AM
