engine cleaning
Old Oct 25, 2004 | 03:58 AM
cameek's Avatar
engine cleaning
what is the best way to clean the engine (technique/product etc.) What do I have to look out for (covering parts etc.)
Old Oct 25, 2004 | 04:21 AM
SilverBelle04's Avatar
I just use regular car shampoo and washing mitt. I rinse with the hose. I don't cover anything but do not blast water directly into your alternator. Other than that, you should be okay.
I then use 303 Spray to protect rubber.vinyl, etc......
Here's what it looks like when done:
Good luck with yours
Bob
Old Oct 25, 2004 | 04:40 AM
cameek's Avatar
thanks for the info
Old Oct 25, 2004 | 08:05 AM
Monotaur's Avatar
I need to clean mine, but have always been afraid of mixing water in with the engine compartment (ie, not drenching the alternator, shorting battery, etc).
Old Oct 25, 2004 | 11:03 PM
akaxmrxhammer's Avatar
WOW~! silverbelle04, your engine's spotless!
Old Oct 26, 2004 | 01:34 AM
Thanks ! it gets washed every second weekend.
Bob
Old Oct 26, 2004 | 10:44 PM
MaximusX's Avatar
So you just use regular car wash shampoo, hose, and some elbow grease to clean the bay? And you didn't cover anything at all? How long did you wait to turn the engine over after you did this? Stupid questions I guess.....but I'm new......and hella afraid of messing up the engine bay recklessly. Thanks for the tips.
Old Oct 27, 2004 | 05:13 AM
This is to be done on a totally "cold" motor (like sitting overnight). I use regular caqr soap and lcen the body part and the black plasric trim. Stay away from flooding your alternator, but other than that i just spray away. I also place a towel or a plastic bag over my aftermarket air filter.
Then i dry everythnig with a chamois and microfiber cloth.
You can start it up after a few minutes.
Bob
Old Nov 11, 2004 | 07:49 PM
hofb99's Avatar
You know, cleaning the engine bay seems to be a "pain in the a$$"!!! I've asked around and it seems that I get varying opinions... Using "Dawn" was even suggested @ one point, as a degreaser... Please, if there's a very reliable, non-intrusive way of cleaning up your engine, someone chime in!!!
Old Nov 12, 2004 | 03:22 AM
NYC TAR's Avatar
You supposed to turn the car on right away after washing and turn the heat up.
The propose is use the radiator fan to blow dry the engine using heat, wind. To prevent rust spot in tight spot. I would leave the hood 1/2 inch open ( before you push the hood lock). Leave the engine running 15-20 min or when dry/you also can drive around with hood closed.
derekinthez
Nov 13, 2022 04:00 PM
6spd4dsc
Mar 4, 2016 05:19 PM
Maximan190
Dec 16, 2015 06:01 AM
fastcarny
Oct 6, 2015 10:42 AM
03VQMAX
Sep 5, 2015 03:47 PM
