Magnaflows
Magnaflows
Hey everyone I'm new to the org and just want to say that the info here has been a big help to me. My question is how much am I looking at for a shop to custom bend a system to use with two Magnaflow mufflers?
Custom Exhaust System
It cost me about $850.00 . Then I added another MagnaFlow as a resonator for another $150. So I have almost a grand into my system. Here's a few pix:
http://www.cardomain.com/memberpage/636944/2
Hey Red,
How did you compensate for the timing when you changed the underdrive pulley? Why Injen for a CAI? .....and don't Maximas already come with a FSB? How about the cross drilled rotors...I know that they look cool. however if you have either traction control or especially VSC it could affect the performance since there is less contact area under the pads...plus you run the risk of warping the rotors if you have to brake hard during the winter. Otherwise I like what you did with your Max. Did you remove the Trenz logo on the chrome grille and I did not get a good look at what you did with the holes that were left over after you removed the rear NIssan Logo....something about buttons on you web page. Anyway...nice work and happy motoring.
Originally Posted by xorbitman
Hey Red,
The UDP does not effect timing, it just runs the accessory belts.
I chose the Injen because its a true cold air intake, and therefore has the best chance of making the most power because the air cleaner is outside the engine compartment. The other intakes can't call themselves "cold air intakes" if they are sucking up hot air from inside the engine compartment. And no, it will not suck up all the water on the road and ruin your motor.
When you say FSB, I'm assuming you mean "front strut bar" , which is more commonly called "front strut tower bar",or FSTB. The 04' Max does not come with a FSTB. If you are saying FSB meaning "front sway bar", then yes, the car comes with a front (anti) sway bar.
Yes, the cross-drilled rotors look cool and I will be the first to admit that cross-drilling does nothing to improve brake performance. It also does nothing to hinder performance and will not lead to warped rotors. It does not effect ABS and I don't have traction control. I only drilled them because I knew I could do it myself and I thought they would look better.
The Trenz grill comes with or without a place for the logo. It also comes in a polished or brushed finish and it's not chrome (it's polished aluminum).
For the holes in the rear spoiler, I painted two plastic buttons (sometimes called "screw caps") the color of the car, and glued them in with silicone.
Hope this answers your questions.Thanx for the compliments.
Originally Posted by mattlerose
Hey Red, did you install the UDP yourself? I have one coming and seems like it may be a pain in the butt to install. Did you notice and difference?
I noticed a difference after adding the pulley. The motor seems to rev quicker and I think it added a couple ponies. Plus it's a beautifully machined product, well engineered. I have had it on for 8 or 9 months and no worries!
Originally Posted by 04RedOpMax
Yeah, installed it myself. And it is kinda a pain, especially if you have an automatic trans. The motor wants to turn when you are taking off the big bolt that holds the pulley on. I used a huge air ratchet that I normally just use to take off lug nuts (on my other cars, not the 04' Max), and it worked like a charm.
You WILL need to get two smaller belts. Since the pulley is smaller, you will not be able to tension the old belts, there is not enuff adjustment.
As far as it taking 7 - 10 days for the computer to make an adjustment for the pulley, I'll have to take UR's word for it. It's seems to me it would be instant, but I do not claim to be an expert on car computers.
It may be a way of covering their butt if somebody doesn't notice a big difference right away. Some poeple might have greater expectations from a pulley mod.
Originally Posted by Glude
The UDP is awsome, I got the SWA pulley because its cheaper and lighter than the UR pulley. Only thing I didnt install myself and it cost me 35 bucks, well worth it.
Magnaflows
04RedOPMax; I got my Magnaflows installed today. I can't figure out how to post the pics here. I have the pictures saved to my hard drive. When I click on insert image a text box opens up and asks for the link.
[img] (link) [/img]
If there is a better or easier way, I'm sure somebody will speak up. I'm a rookie when it comes to this computer stuff. You can test your posts to see if you got it right in the "Test Posts Here" at the bottom of the first forum page.
Thanks 04Red; I havent taken any of the bottom yet. I took Monday off of work just to get the exhaust put on. The sound is really nice. It has a deep tone but it's not loud at all. No droning and at cruising speed it is as quiet as stock until I punch it you can hear the deep tone. I have also noticed that my intake makes more noise now that the exhaust is hooked up.
Here is my Car Doman Link:
http://members.cardomain.com/djrhouse
Originally Posted by AngryPotato
The magnaflows look much better than my greddy fart can. I'm going to consider replacing mine sometime next year if I catch too much flack.
Go with the Flows!!
Here is what I think:
Stillen: "I want some better looking mufflers". [If a factory option existed it would be this.]
Magnaflows: "I don't want droning, and I want a more aggressive sound. Plus I don't want to spend much and i want a somewhat stock look."
Greddy: "I want a much more aggressive sound and look, little droning doesn't bother me. Neither does a big tip. I want it to sound like a 350z...No...lil louder. Oh yeah and I don't want to weld or work with flanges. I also like to look at myself when I'm under that car admiring the shiny polished full exhuast."
Mudafoka; My Magnaflow part number is 14815. You can get them shipped to your door for a extremely cheap price with no shipping cost for $278 with no Droning (drawback - they must be welded on and it will cost you for the custom job). There is no way I'd pay between $550 and $600 for the Stillen as much I like the company if I can get what I got for half the price and they (Magnaflows) sound twice as good to me and everyone that has heard my car. The box says those mufflers added 14HP on the Dyno and 16ftlbs of torque to a VW Passat. I find that hard to believe with just a rear section. 5 more HP sounds realistic but I am not professional in this department. I can tell a difference in accelleration.
Max'n; I kept my stock resonator and I tell you it sounds really good with those mufflers, especially when I step on the gas with a little pressure. 04RedOp can attest to that.
Glude: I like the Greddy's but I couldn't get a deal with the shipping to the DC area from California. That would have set me back about $800.00. I think they would look better with the Stillen body kit so it can hide the space around the bumper cutout.
Bottom line; Get what you like and can afford and don't change what you have because someone else doesn't like it. Be your own (Man) person and most people will respect you for voicing your opinion but not forcing your views on others.
I dont have anything that records sound. I have to check out my digital camera and see if it does. 04SEElite, those Magnaflows probably wont fit because the tips are too big for the bumper valance cut out in the rear. The cost for installation will vary because as you know everyone charges different prices.
Mudafoka I am sure you can find a lot of places in NY that will do the install. I am from Jamaica Queens originally and they have places all over where you can negotiate. I would say around $150 because they have to do welding and they will charge you to take off the factory mufflers which are easy because they are bolt ons. They have to make money somewhere.
I can tell you that it sounds almost exactly like a G35 Coupe now. At least from the inside of the car it does. Today I am going to let a buddy of mine who has a 350Z drive my car and I will drive his Z so I can see how it sounds.
Looks like I am going to invest in a digital camcorder so I can do some recording. I will ask someone here how to post the sound clips and video.
Magnaflows
Sure;
www.justmagnaflow.com
The customer service is excellent and they will send you a UPS tracking number if you request it. They have a few warehouses on each coast so you can get it in about 3 business days or less.
I made my order over the phone. I am sure if they are open on Saturday but you can check the website.
Good Luck!
Good Luck!
Bryan from Berk installed my Maganflows today. (he just installed the muffler's for now, he's working on completing the kit) Sounds awesome like as 3,5 lover said above, "It has a deep tone but it's not loud at all. No droning and at cruising speed it is as quiet as stock until I punch it you can hear the deep tone. I have also noticed that my intake makes more noise now that the exhaust is hooked up. " ditto for me.
I only drove home from the shop I'll get a better feel tomorrow. I'll post some pics as well....
The guy at Stillen (won't mention his name) was pissed when I told him the great price for the Magnaflows and that they sound better and have a longer warrantee than Stillen has. Competition is great and brings prices down. We benefit from that as everyone knows.
How is the sound? Have you got any pix showing underneath the car?
