What size speakers in the Max?!?!
Does anyone know what size speakers are in the 6th gen max?..i go to sites like sounddomain.com and it sez 5 1/4 and 6 1/4..which one?!?!..i want to change all the speakers in the car..want to know wut sizes..help!
For the premium Audio system (i.e. Bose):
There are 1-1/2" tweeters in the doors behind the mirrors, don't bother changing these.
A 6-1/2" speaker in each of the doors (very easy to change).
Two 8" subwoofers attached to brackets on the rear shelf. The brackets allow them to mount the 8" subwoofers into the 6X9 mounting holes in the rear deck. You must remove the Rear Shelf Trim to access the mounting screws.
The Bose Amp is located on the rear deck between the two subwoofers and you need to remove the rear deck trim to get to its mounting screws.
If you have the Bose system you may just want to consider just adding a subwoofer box in the trunk. Lot's of threads here desribing how to do it quite easily.
For the Base Audio system:
Same tweeters behind the mirrors. 6-1/2" speakers in each doors (4 total). And a pair of 6X9 speakers on the rear deck. The amplification is done thru the head unit. I believe that it is supplied by Clarion, but it isn't one of there better systems so they don't advertise the name on it. If this is what you have I would think that you would want to replace everything, including the head unit.
thanx!!! i'm thinking of putting 2 sets of mb quart 6.25 component sets and a set of 6x9's in the back..i wanna add an amp to power all this..im thinking jl audio 450/4..probably run the front set and the 6x9's off this and the other set off the headunit...speaking of which, anyone know if installing a head unit is difficult?..can someone tell me wut i need and how i do it?!?!
Mar 12, 2020 12:06 AM
popdedop
Sep 11, 2015 11:17 AM
