Sirius Question???
Old Jan 4, 2005 | 08:18 PM
joe_mo1971's Avatar
Sirius Question???
I just installed my Sirius SAT Tuner I picked up from Grubbs.
Sound quality and music choices are great. One thing I am disappointed with is the fact that only the channel is showing up on my display screen (no navigation). Example: CH 020
Everything I see from Sirius shows the artist and song title showing on their screens.
Question to all that have installed SAT Tuner: Do you see Artist and song title on your display screen as we do with the RDS for radio stations?
Old Jan 5, 2005 | 03:07 AM
install30's Avatar
You should be able to go to the select button{ie Bass,Treble,Fade....),there should be an option for you to display channel number, artist name, song tiitle......Try that....
Old Jan 5, 2005 | 04:35 AM
mattlerose's Avatar
Try pressing your right ****
Old Jan 5, 2005 | 04:53 AM
Phil75070's Avatar
"You should be able to go to the select button{ie Bass,Treble,Fade....),there should be an option for you to display channel number, artist name, song tiitle......Try that.... ". It is referred to as "Display Mode" and turning the "Tune" button cycles through the options.
This will determine what shows on the one line display. This changes to SR CH020 if you "Try pressing your right ****" momentarily. You will get a three line display under that which will give the channel name, artist name and song title in that order. It does not scroll, but if the text extends beyond the size of the scree, turn the "Tune" button to the right to see the rest of the text, and turn it to the left to return to the first screen.
Old Jan 5, 2005 | 08:04 AM
mattlerose's Avatar
When I press the right **** it does not change to channel 20, it simply brings up the station number, artist and song. I may have misunderstood what you were saying.
Old Jan 5, 2005 | 11:39 AM
Phil75070's Avatar
I was just using the example of channel 020 used by the OP. If you press the "Tune" button you can toggle between the three line display or not. Depending on the Display Mode you have chosen, the single line above will either disply the chosen option if the three line is off, and will show SR CH XXX (for the channel you have tuned to) if the three line display showing station name, artist and title is "on".
Old Jan 5, 2005 | 11:42 AM
Tek-Niq's Avatar
my rear view mirrors flap like a f-ing bird
if it doesn't come up try it on cd....... press the button in and it should come up "bass and tremble, display, song tittle ect"
Old Jan 5, 2005 | 05:06 PM
install30's Avatar
I WAS JUST TRYING TO HELP THE GUY.....
Old Jan 6, 2005 | 12:59 PM
joe_mo1971's Avatar
Thanks for all the replies. Pushing the right **** worked. Appreciate it.
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
