Radio not working in EXTREME COLD
Old Jan 17, 2005 | 03:20 PM
seige25's Avatar
I woke up today in Chicago and headed to work in my 04 Max, cranked her over and took off. I noticed the Control center LED's were a bit slow to react in the cold and thought I had turned the radio off last I left her. But apparently the stock radio does not like temps below 6-7 degrees F. I don't know what it was with the wind chill BUT it kinda scares me a bit. After 10 minutes and a warmed up engine the heat kicked in and the radio came a blaring, forgot to turn it down. So anyone else find any issues with their radios in EXTREME COLD. I will post a reply or edit as today all day it has been single digit and is supposed to go SUB zero tonight! So just wondering if anyone else has come across this issue as well. I thought the radio caught wind of my plot to install an after market Sirius radio and was rebelling.......
Old Jan 18, 2005 | 08:21 PM
MaXiMaGrIp's Avatar
same here
i kind of have the same problem in the cold i notice that my cd's skip alot i have even got to the point that i copied all of my cd's over thinking it was my cd's but it is not it is the weather in warm weather it plays awesom i hat listening to the radio!!!
Old Jan 18, 2005 | 09:37 PM
dopestar129's Avatar
My info screen is slow moving at first in extreme cold also. The radio works fine, however. My CDs have a little trouble playing too. They skip just a bit until after 5 minutes or so when the car is warmed up. I've never had it not work at all, though.
Old Jan 19, 2005 | 12:40 AM
STACK BUNDLES's Avatar
yea my info screen numbers/letters react slow when in the cold, here in ny it's been like below 20 degrees for the past two days, plus my cd started skipping in the cold but after the car warmed up it was fine
Old Jan 19, 2005 | 03:25 AM
SilverBelle04's Avatar
It was -40F up here yesterday with windchill......radio played fine but the info screen was slow.... (i was too ! ).
CD played on and off until the car warmed up. This used to happen on my previous cars as well in the extreme cold. I have no problem with the CD player when it is normal temps outside.
Bob
Old Jan 19, 2005 | 05:44 AM
bigcozz's Avatar
Screen will definately be slow since its LCD (liquid Crystal) the liquid inside slows down alot in the cold. As far as the raido i have never had that problem but my car doesnt ever get too cold since it stays in the garage. I have had a problem with some after market products that i have installed not working due to sever cold. I would let my car warm up a bit before speeding off in the morning.
Old Jan 19, 2005 | 09:47 AM
nemo's Avatar
ditto, it happens with anything that is LCD. it's normal.
Old Jan 19, 2005 | 10:12 AM
prymal's Avatar
i haven't had any issues with my radio in cold temperatures. a few weeks ago it was -3 F surface temperature and car started normally, nav screen came on (though a bit slow and dim at first) and radio (bose) worked fine.
mornings my car is garaged, so i never have a problem. on weekday evenings it sits outside in my company's lot for at least 8-10 hours, and still no unexpected results thus far.
Old Jan 19, 2005 | 12:20 PM
ceehan's Avatar
yesterday in nyc, it was like 10 F, i was listening to a cd and then all of a sudden the changer changed cds on me in the middle of a song. weird...
Old Jan 19, 2005 | 12:54 PM
Mystery's Avatar
I hate this problem. Sometimes the skipping doesnt last long other times it doesn't stop for even an hour into the ride. Usually i end up listening to the radio for much of the winter season.
Old Jan 19, 2005 | 02:06 PM
mine has done that a couple of times too. like it's possessed or something
Old Jan 26, 2005 | 02:40 PM
sdwilly's Avatar
Noticed that my CD will skip a lot and suddenly change CD's when it drops below about 20. Always thought that was odd, thought it was my CD's for the longest time.
Old Jan 26, 2005 | 04:50 PM
unclemax's Avatar
Hey, my radio volume started going up a few clicks all by itself when it was about 11 F.
Old Jan 26, 2005 | 05:27 PM
Jeffs04SE's Avatar
ive noticed that in the real cold mornings when i go to leave for work my CD will read as an error, so i just eject it and then put it back in. other than that i dont have any problems with it
Old Jan 26, 2005 | 07:31 PM
HammerDown's Avatar
I had this problem
Not a CD issue, I can understand those. I didn't even notice the radio wasn't on it was -17 in New Hamshire that day. My heat was on and a little while later my radio came to life like it had unthawed!
jerrod99_se-l
Aug 27, 2015 08:27 PM
maxinout93
Aug 16, 2015 07:25 PM
kirkhilles
Aug 8, 2015 10:53 AM
kenc15
Aug 5, 2015 08:29 AM
