New mods
New mods
Was at my best friend chernmax's home this weekend in Maryland with my wife and we had a great time with his family. He installed a few mods for me. kcmaxx thanks for the idea for the short shift. Braided the hoses, installed a Optima red top power cell and custom polished billet aluminum battery bracket with 2- 24K marine battery posts.
Originally Posted by boone
Nice look Ramberg. What does the marine battery do for you versus a regular automotive battery?
Nice choice on the Optima, when my stock one dies, that is what I am going for.
Originally Posted by carcus
He has a red top, the blue top are deep cycle for boat use. Optima make some good stuff. The terminals he has are for better conduction....and keep the corrosion off.
Thanks everyone for the comments. Warren
Originally Posted by ramberg
Thanks for giving out that inform.
http://sprinc.org/ 115 dollars. Its a 6 piece set. bottom, mirrored top and 4 posts. As of now I like my shifter. Later Warren
115 for a set of what, those braided hoses?........ cause that looks good...
please respond to this Q...
Originally Posted by Jayzmax04
Ramberg, did you install a short throw shifter, or just cut your shaft?
I hope you didnt cut your shaft, only an insane idiot would do that....
I quess I must be a insane idiot. about 2"
[QUOTE=Tek-Niq]115 for a set of what, those braided hoses?........ cause that looks good...
The braided kit was 32 dollars. You can buy it at any auto supply shop.
Originally Posted by queenzkid
would a marine battery push too much voltage?? Too much voltage could melt some wires. Not sure if parts in a car engine can handle voltage from a marine battery.
+1 same here...
the cars looking good man
Join the club. What did you use, hacksaw? Nervous?
Originally Posted by maxxoutt
I've Been Real Good My Self.and Yourself?i Got A Couple New Things For My Car For The Next Meet..
Jayzmax04, Warren is correct, for mine I used a mini hack saw (smaller version then a regular), most people don't realize how strong the steel shifter is, however when we were doing Warrens ride, I used my recipricating saw
to cut/modify his old battery posts for the new Marine terminals.
It was getting late and this was the last mod of the day and I was dreading the 30 minute cut, then bingo, since I had my medal blade in, I attached a pair of vice gripes to the top of the handle for Warren to hold the shifter still while cutting. (because me and Warren talked about how much he would bleed all over his interior if I slipped!!!). Anyway, worked like a charm, cut through it like butter in under 30 seconds, Shift **** mod must of taken us 5 minutes total.
to cut/modify his old battery posts for the new Marine terminals. It was getting late and this was the last mod of the day and I was dreading the 30 minute cut, then bingo, since I had my medal blade in, I attached a pair of vice gripes to the top of the handle for Warren to hold the shifter still while cutting. (because me and Warren talked about how much he would bleed all over his interior if I slipped!!!). Anyway, worked like a charm, cut through it like butter in under 30 seconds, Shift **** mod must of taken us 5 minutes total.
zzznightmarezz
Sep 21, 2015 06:32 PM
