Anyone knows what goes HERE?
Old Jun 28, 2005 | 08:01 PM
SoufSidah09's Avatar
This is the fuse box under the hood...
I'm thinking I'm missing a relay...
Ohh..and what is it for..
Old Jun 28, 2005 | 08:08 PM
Ohh..also this one..
It's the driver side fog lights I believe (the orange and black)..I need the plug but there looks to be 2 black cables below it, I'm not sure what it goes too..Any ideas? maybe a sensor?
Old Jun 28, 2005 | 08:16 PM
Roshan
try making the pix in a better resolution
Old Jun 28, 2005 | 08:28 PM
sorry was taken with my camera phone..
Old Jun 28, 2005 | 08:52 PM
pae1215's Avatar
i will try to look at my fuse box tomorrow morning.
as for the second pic, that looks like the cornering lights? is that at the bottom, front end of the car? The fog lights are attached to the headlights.
Old Jun 29, 2005 | 05:20 AM
Thanks but as far as I know the 04 maxima don't have corner lights...what corner lights are you talking about? The headlight has one plug that activates all headlight functions the cable continues down and connects to the fog lights, then it continues and plugs so somthing else...but what? you can kind of see it on this pic someone took at the drivers side...looks at the cable coming from the fog light..
Old Jun 29, 2005 | 05:29 AM
pae1215's Avatar
Old Jun 29, 2005 | 05:40 AM
Wow I got it all wrong then..I thought what you marked as fogs were the high beams/DRL and on the bumper cover was fogs as the bulbs seem to be clear...
Old Jun 29, 2005 | 06:13 AM
jc53's Avatar
The '04 Max does have cornering lights!
Old Jun 29, 2005 | 08:41 AM
Tek-Niq's Avatar
my rear view mirrors flap like a f-ing bird
nope.. our high and low beam are in the same assembly.. one bulb two functions..
Old Jun 29, 2005 | 08:44 AM
Tek-Niq's Avatar
I don't have that relay either, must be an option we don't have..
Old Jun 29, 2005 | 08:46 AM
CanadianMoFo's Avatar
DRL relay perhaps.
Old Jun 29, 2005 | 09:14 AM
Great, I have on 04 SL with HID, is that your same setup?
Old Jun 29, 2005 | 09:16 AM
I have the HID setup, so does the Xenon bulb operate at low & high beam?
As far as I knew you needed a sperate bulb/projector for high...
Old Jun 29, 2005 | 09:24 AM
pae1215's Avatar
nope. the projector is dual beam. click on the high beam and stick your head out the window, you should hear a click. its the shutter thats opening to allow more light(the high beam) to happen.
theres only 1 hid bulb and its a single filament.
Old Jun 29, 2005 | 09:26 AM
Tek-Niq's Avatar
what PAL said... look below
Old Jun 29, 2005 | 09:47 AM
Great! Thanks
Old Jun 29, 2005 | 07:16 PM
BTW what color are your bulbs in the turn signals in your front bumper cover? just checking if I have the correct ones, cause the bulbs that came with mine are clear...
Old Jun 29, 2005 | 08:07 PM
pae1215's Avatar
yes, the bulbs are clear ones.
i have the stock corner lights, as you can see, clear!
Old Jun 30, 2005 | 01:29 AM
VTmaximaVT's Avatar
HID bulbs don't have filament.
Old Jun 30, 2005 | 04:38 AM
pae1215's Avatar
well what I meant to say is that the light only burns one color, not like a 3157 bulb that switches from low to high...yes I stand corrected, hid bulbs do not have filaments, sorry for the confusion!
Old Jun 30, 2005 | 05:44 AM
I'm glad I have the Max guru's in this thread! Thanks PaL
I've got another question...04SL; I'm not sure where this wire goes...it's behind the drivers side headlight, looks like a horn maybe? I'm not sure if the Max has a horn on the drivers side? I followed the black cable to the wire bundle and it's actually a green wire... any ideas?
