Bose stereo question
Old Jul 11, 2005 | 06:58 PM
mroleg's Avatar
I have a 2005 SE with Bose stereo with 6 cd in-dash cnager.
If anybody took a Bose stereo apart, I need to know if there is a way to remove
just the tape deck. I am planning on removing it and making a cutout in a center console for a single din aftermarket gps like Pioneer Avic-N2.
Thanks in advance.
Old Jul 11, 2005 | 07:01 PM
Tek-Niq's Avatar
my rear view mirrors flap like a f-ing bird
the tape deck is one piece with the 6 disc cd player... so if one goes they both go..
Old Jul 11, 2005 | 08:26 PM
luigi'smax's Avatar
10 chars....
Old Jul 12, 2005 | 12:30 PM
driver's Avatar
yep..............
Old Jul 12, 2005 | 05:20 PM
Davidx34's Avatar
does anyone know what type of subs come with the Bose system? If,so where are they located, and the amp for the system also?
Old Jul 13, 2005 | 06:24 AM
pradell's Avatar
the subs are located in the rear deck as well as the amp under the third brake light!!
Old Jul 14, 2005 | 06:31 PM
Tek-Niq's Avatar
yea the amp for the subs are under the rear deck in between the two subs... you will need to take the panel off to get to them.. with the panel on you won't be able to see them..
six clips will drop that panel and its stuck on with velcro.. simple but I recommend a door panel remover tool for this job or you will risk breaking the clips..
Old Jul 15, 2005 | 03:05 AM
ramberg's Avatar
GrandPa
Thanks in advance.
If you are going to install the N2 you won't need the cd player. Are you going to change the speakers and amp? I have the after market console kit and wire harness. If you would like to buy them let me know. I just have to find them in my closet. If you need pictures let me know and I will post them. Later Warren
Old Jul 15, 2005 | 05:24 AM
mroleg's Avatar
I don't think I will change the amp and speakers. I had Avic N-1 in my Infiniti with bose and all I did is bought a pre-amp adapter. Worked out pretty good. The speakers sound much better with the aftermarket system than with original one.
Old Jul 15, 2005 | 09:25 AM
belal242's Avatar
what kind of pre amp and where do i get it? because i want to install the AVIC-N2 as well just dont know where to start with the bose system and all in my car
Old Jul 15, 2005 | 10:02 AM
mroleg's Avatar
This is the one I got when I replaced Infiniti Bose. It will probably work with 6 Gen also. Don't quote me on that though. I haven't double checked yet.
http://www.crutchfield.com/S-0nIpjmA...&display=L#Tab
Old Jul 15, 2005 | 10:14 AM
ramberg's Avatar
GrandPa
A picture of the after market console kit for use for the N2 and other setups. If you are interested PM me. I can't find the harness. Later Warren
Old Jul 15, 2005 | 02:39 PM
boone's Avatar
You gon' pay what you owe
The panels in the 05s have a different finish on the plastic than the 04s. So, using that part would cause a mismatch.
Old Jul 16, 2005 | 08:14 AM
Davidx34's Avatar
Does the non-bose system have subs in the rear? If not what is back there, 6x9s and an amp or just 6x9s no amp at all? How hard would it be to buy the amp from the dealer, along with the subs and install with system that did not come that way?
Old Jul 19, 2005 | 02:47 PM
Retep01's Avatar
First post, just got a almost new 2005 Maxima only 8500 on it. So i was wondering how big are the subs with the bose system? Also what kind of amp is in there and the wattage? I havent been able to find out much about the system except on this site.
Old Jul 20, 2005 | 12:08 AM
boone's Avatar
This thread should help you some. http://forums.maxima.org/showthread.php?t=393004
Be sure to donate. You will be able to search and find info a lot faster.
Old Jul 20, 2005 | 12:17 AM
boone's Avatar
According to Crutchfield, there are a couple of 6x9s back there in the non-Bose ones. Honestly, if I were in your position I would look into redoing the car using completly aftermarket equipment. Trying to do a Bose retrofit would probably be expensive to the point of not being worth it due to the fact that you will be buying specialized equipment. Also, the wiring for the Bose is surely different so that is another obstacle.
Old Jul 20, 2005 | 12:55 AM
FriscoMax's Avatar
I agree whole-heartedly, all or nothing.
Old Jul 20, 2005 | 07:43 AM
sraey8's Avatar
On a '02 Maxima bose system, when adding a aftermarket amp, can I tap into the subwoofer wires to convert to RCA's ( and which wires are those ) or do I have to by an adapter ( where could this be purchased) ?
Old Jul 20, 2005 | 03:05 PM
Tek-Niq's Avatar
they are 8" subs back there... the whole system is about 320 watts, divide that by 8 and you get 40w for each speaker...
this is a usefull thread:
http://forums.maxima.org/showthread.php?t=383900
Old Jul 20, 2005 | 03:07 PM
Tek-Niq's Avatar
you should look into the "PAC-SWIX" adapter or go to your local audio shop and ask for a hi/lo adapter...
the pac is the most expensive at about 50 bucks and the hi/lo goes for under 20..
Mar 12, 2020 12:06 AM
EdRomo86
Sep 12, 2015 07:49 PM
popdedop
Sep 11, 2015 11:17 AM
Violator
Sep 9, 2015 10:14 AM
