Pics of just the front lowered on Eibach/Konis
I got up Saturday to install all 4 spring/shocks and I only ended up doing 2. I really love the way it looks just like this. I seems perfectly even all around. However the ride is much worse. I figured this pics would be helpful for those thinking about doing just the front.
I'm so jealous. I'm waiting for my struts to come in. I've got the springs and shocks waiting to be installed. I wanted to have it done for the DCMAX meet this weekend but it doesn't look like that is going to happen. At any rate, your car looks good now but it will look even better once you're done.
I think the lowered front makes the car now look even. Looks great as is. How much worse is the ride with just the front lowered. Is it tolerable? This is what I am planning on doing. Looks so much better without the front 4x4 looking gap that mine has.
I think it looks great, but it would be better to do all fours....Why have different spring ratings for the front compared to the stock rear...The ratings of springs work together ( all four having the same rating) , that is why they are not sold in pairs.
do all four Hamy, the ride will get better with the whole set...
I did the same with the coils, I could only do the front two at first and it rode like **** till I got the rears in.. the whole ride got so much better and firm instead of bouncy like it was..
Originally Posted by James_05SE
Ummm.....NO. The springs are not all the same rating and probably aren't even the same dimensions. The springs front and rear should compliment eachother so that they basically have the same frequency when you are driving as to not keep the car oscillating. There are many factors in determining spring rates including motion ratios, desired wheel travel, weight at spring locations, etc.
Put one person in the back of your ride with the OEM spring and your ride will probable drop 1" in the rear. With a .08" drop from the Eibach, and the weight of the same person, it may drop you only an additional half inch because of the increase stiffness of the spring working with the rear struts. It's your ride, this is strictly my opinion. Your car still looks great, but get what you paid for, the whole package...
PS, I have the springs on my car and installed them myself, so I am speaking from experience, not my keyboard...
The picture below is an all Eibach dropped side view of my ride, looks pretty level to me and I have bags of groceries and my daughter sitting in the back seat, and a truck full of American Red Cross rescue gear in my trunk...
Sorry, one last comment, if you really look closely (not that close, back up) at the first picture you posted of your ride, it's not level, the rear is higher than the front but you get a preception that it's straight because now the front and rear wheel gaps look about the same. My Opinion Only... By the way, love the house...
Originally Posted by DeusExMaxima
sharp ride chern
Originally Posted by boone
You should see it in person. The pics just don't do it justice.
".......if you really look closely (not that close, back up) at the first picture you posted of your ride, it's not level, the rear is higher than the front but you get a preception that it's straight because now the front and rear wheel gaps look about the same......"
Agreed, but it looks even SWEETER that way!!
I got a set of Eibachs waiting to go on.
Hamy, let me know how it rides with just the front done. I am really considering doing the same thing.
(for sale.....set of rear Eibachs
I'm getting my Eibachs put on tomorrow. I also have the adjustable Koni struts and adjustable AGX shocks. For any of you are using this setup, what do you recommend I set the adjustments at?
Originally Posted by Tek-Niq
make sure you set the rear were you want, cause once they are in you won't be able to adjust them anymore..
top mounted adjustment struts only
Why is that? I figured I'd just have to jack the car up and pull the wheel to make an adjustment.
if you had the "top mounted" ones you wouldn't be able to get to it cause the top of the strut goes in the well on the rear of the car, making it imposible to get to them for adjustments..
see here:
that sucks. i wonder if the tein electronic damping force controller's compatible with the ksport coilovers. can someone investigate? i would do it myself, but i'm currently deployed to middle east. here's stillen site with the controller
http://www.stillen.com/Sportscars_de...d=47132&page=1
yep on the K-sport you won't be able to adjust them when you want.. you will need to uninstall the whole thing to adjust it..
