Tuned Apex'I safc II on 6th gen max. check it out.
Old Aug 21, 2005 | 08:22 PM
  #41
SR20DEN's Avatar
VQ Wizard
Certainly. But in order to know exactly what your gains are you have to have a run or two on the base settings (or leave it alone as it is right now) then tune it to 13.0-13.5 across the board. And you want the graph to be as flat as possible (at least from 4000 on). The graph being flat is almost as important as it being right.
Or you could wait and bring the car in to the shop and let me tune it for you, after I look at waht I need to know for the headers.
Old Aug 21, 2005 | 08:48 PM
  #42
harmbone2k2's Avatar
6yrs old=36,500 miles :)
I would let SR look at it for you, being that you are that close to him.
Old Aug 21, 2005 | 08:58 PM
  #43
Glude's Avatar
Originally Posted by SR20DEN
Based on the readings from the A/F graph, those gains did not come from the SAFC. Notice the difference in the air fuel occuring only after 4000rpm but the torque difference is mirrored from the very beginning. All I see here is that you had a better day at the dyno.
So they didnt tune the safcII? Im confused, why would the a/f be different on this day than the other?
Old Aug 21, 2005 | 10:13 PM
  #44
SR20DEN's Avatar
VQ Wizard
There WAS some tuning done via the SAFC2, you can see it in the A/F chart. All I was saying was that the gains he showed didn't come from the SAFC. Look at the blue vs. green chart at the air fuel mixtures and you'll notice that they're identical untill about 4000 rpm. But if you look at his torque curves you can see that the graph shapes are near identical however the green line is almost exactly the same difference from the blue line at every RPM point. His gains are consistant with environmental variables, meaning he had a better day on the rollers than the previous tests. But there is still more power to be found in this car once it gets tuned correctly.
Old Aug 22, 2005 | 03:31 AM
  #45
maxmale's Avatar
name a day. and i will be there
Old Aug 22, 2005 | 06:42 AM
  #46
ramberg's Avatar
GrandPa
Originally Posted by maxmale
if your wanting to get it done here well need to schedule and appointment. if you need you can stay here.
I will let you know before the end of the week. Thanks Warren
Old Aug 7, 2006 | 08:06 AM
  #47
SonicDust187's Avatar
Anyone have instructions to install safc into a 6th gen?
Old Aug 7, 2006 | 08:26 AM
  #48
chernmax's Avatar
Nations 1st 6th Gen Turbo
Da-Max "Ada" from RedLineMax installed mine, try calling them and ask him which wiring setup he used from the install guide for our Max...
Old Aug 7, 2006 | 10:12 AM
  #49
madmik's Avatar
http://www.apexi-usa.com/support_installation.asp
Manuals and wiring in PDF's.
Old Aug 7, 2006 | 10:35 AM
  #50
Glude's Avatar
Search Altimas.net for the vafcII wiring diagram, its the same for our cars. If your gonna buy an afc, get the vafcII over the safcII.
Old Aug 7, 2006 | 01:04 PM
  #51
kamski's Avatar
.org extraordinaire
why? what does the vafc do?
Old Aug 7, 2006 | 03:36 PM
  #52
xorbitman's Avatar
I already purchase a APEXI NEO, It comes with everything. We have a guy up here who installs them. I need to finish the piping underneath first though. (Hi FLO Cat, Y-pipe and Nismo Exhausts.)
Old Aug 7, 2006 | 03:40 PM
  #53
chernmax's Avatar
OK, unjuiced I think I passed the 300crank HP barrier...
I just downloaded the latest version of the Dynojet software (WINPEP7 DYNAMOMETER SOFTWARE Current Version 7.1.3)
and with my 3 run files, this is what I got. Damn, this shows my best run was 256 WHP???
Old Aug 7, 2006 | 05:01 PM
  #54
Glude's Avatar
Do a search, its been beaten to death already.
Old Aug 7, 2006 | 05:15 PM
  #55
AllBlackMax's Avatar
aka The Doom Ship
I'm sure those numbers will be even better with cooler air.
Old Aug 7, 2006 | 08:00 PM
  #56
chernmax's Avatar
I'm wondering what it could be like with a 50 or 75 shot???
Old Aug 8, 2006 | 05:10 AM
  #57
savagecat's Avatar
Going Ginsu
Something isn't adding up. A while ago you posted your dyno with like high 240s / low 250s for the HP off a mustang dyno. After the header and exhaust work, the ECU reflash, and a couple other things you're at the mid 250s. Something in the mix isn't playing nice with other parts.
Old Aug 8, 2006 | 06:22 AM
  #58
Tek-Niq's Avatar
my rear view mirrors flap like a f-ing bird
funny, thats his first dyno post, and his last numbers were 253 with the SAFC, and headers, he doest have the ecu flash..
he's just saying that his best numbers that day were 256hp instead of 253, he didn't do another dyno, he just didn't know his best score..
Old Aug 8, 2006 | 01:35 PM
  #59
chernmax's Avatar
I never posted any of my dyno numbers before because this is my first dyno EVER!!! I think you are confusing me with Ramberg, a while back he had a dyno done on a mustang dyno that he posted on the Org...
Old Aug 8, 2006 | 01:37 PM
  #60
chernmax's Avatar
You're correct, thanks for clearing that up bro...
Old Aug 8, 2006 | 01:42 PM
  #61
MAXDOUT04's Avatar
* THIS SPACE FOR RENT *
I say spray that beyotch but only a 50 shot till your comfy and know that shes not gonna come crumbling down with anything bigger
Old Aug 8, 2006 | 01:51 PM
  #62
Tek-Niq's Avatar
this engine is good for over 500hp totally stock, assuming its tuned well.
Old Aug 8, 2006 | 01:54 PM
  #63
Glude's Avatar
People have run 150 shots on 3.5s in maximas without any problems. I know a Z team ran a HUGE shot until they blew the motor which was a while I believe.
Old Aug 8, 2006 | 04:00 PM
  #64
savagecat's Avatar
Going Ginsu
All you white guys look alike.
# savagecat = ;
Old Aug 9, 2006 | 07:44 AM
  #65
jingiko's Avatar
there was actually a black maxima 6th gen with the apexi safc ll but he sold it on ebay. he was located in ny. i guess he didnt like the # after his dyno.
this was a while back tho
Finkle
Sep 27, 2015 09:53 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
spidgeon
Aug 9, 2015 09:26 AM
dauntlessmax
Aug 5, 2015 10:29 AM
Tanvirkamal
Aug 5, 2015 01:32 AM
