Ok, even after sound dampening was done to the trunk and rear deck, there was still an annoying buzzing rattle in the back.
I decided to fix it once and for all yesterday and the final result will prolly surprise you's. It turns out about 90% of the rear deck rattle is located where the deck insert meets the glass. In the middle... under the 3rd brake light. Even if you have all the factory clips in place, with sound deadener, it will still vibrate, also causing the 3rd brake housing to even hit the rear glass. SOLUTION: 1 big cable tie and a cordless drill.(yes drill puss...you want the sound gone or what?)
What To Do
take off rear floor sills
remove brake light housing
unclip wires to light
fold down seats
take off 6 bolts holding seat to frame
pull seats toward front and take off side pillar covers
lift off rear deck insert and slide onto seat backsupside down ( mine is held down remember-no pic)
It might be a good idea to remove most of the plastic skeleton underneath insert around the area and replace with some 3m foam thingys on the edges. I didnt, but just an after-thought.
If you havent put any sound deadener on your rear deck you can do it now.
Fun part now.... Put the insert back in place without securing it though. In the center of the brake light opening on the insert there will be a "bar" in the middle. You will drill a small hole on either side of this "bar"
but first...
open the trunk and remove the liner. Line up by sight or touch where the holes will come into the trunk part and you will see exactly where holes should be drilled.
If you drill the holes too close to the glass you will not be able to catch the cable tie from inside the trunk, as there will be a metal shroud in the way.
After drilling the holes, insert the cable tie into the hole from the trunk and into the opposite hole from in the car and secure it closed with pliers in the trunk
you might need to push on the deck liner to get a good clamp on a shorter cable tie.
All in all this will keep your rear deck from flapping against the deck(rattle) and keeps the brakelight from hittling against the glass and insert(mucho rattle)
after I put the joint back together ALL rattles are gone!! Can any 6th gen say that? Problem I have now is taillight rattle, but Im being VERY picky since nobody else hears it! My amp is turned up the way it should be, whereas before, I turned it down because of too much rattle. Um also my rear glass now looks like its gonna shatter from SPL. But NO rattle.
Im tired now...just thought Id share my experience. if you need pics let me know and I will go take a couple.
What To Do
fold down seats
but first...open the trunk and remove the liner. Line up by sight or touch where the holes will come into the trunk part and you will see exactly where holes should be drilled.
If you drill the holes too close to the glass you will not be able to catch the cable tie from inside the trunk, as there will be a metal shroud in the way. After drilling the holes, insert the cable tie into the hole from the trunk and into the opposite hole from in the car and secure it closed with pliers in the trunk
Damn I thought this was only a problem on the 02-03. Shame on nissan, shame on nissan.........
If the rattle is in the deck itself, drastic measures (such as swowlinc's) may be necessary.
My only rattle was the third brake light against the rear window. I put two tiny clear round plastic 'tab-cushions' (available at Home Depot, Lowes, WalMart, hardware stores, etc) on the bottom two corners of the brakelight housing, where it was tapping against the glass, and have heard not a peep in the two years since.
As it turns out, that has been the only rattle in the two years I have owned my '04 SL. It is as quiet as a tomb in this car.
Yeah....suction cups might do it. Im pretty sure it depends on what audio setup you have. My sunglasses holder is rattling so crazy even after putting a lil deadener in there,I leave it off. My friggin quarter panels, hood, spoiler and roof heaves in/out with the bass. Its kinda alot of work but most of it is just taking the seats n crap off.
What To Do
fold down seats
Fun part now.... Put the insert back in place without securing it though. In the center of the brake light opening on the insert there will be a "bar" in the middle. You will drill a small hole on either side of this "bar" but first...
open the trunk and remove the liner. Line up by sight or touch where the holes will come into the trunk part and you will see exactly where holes should be drilled. If you drill the holes too close to the glass you will not be able to catch the cable tie from inside the trunk, as there will be a metal shroud in the way.
WOW!! I want to do this but not sure on how to remove the rear seats. If you could photo this procedure step by step I will paypal you $20 and ask for it to be stickied.Originally Posted by swowlinc
Ok, even after sound dampening was done to the trunk and rear deck, there was still an annoying buzzing rattle in the back.I decided to fix it once and for all yesterday and the final result will prolly surprise you's. It turns out about 90% of the rear deck rattle is located where the deck insert meets the glass. In the middle... under the 3rd brake light. Even if you have all the factory clips in place, with sound deadener, it will still vibrate, also causing the 3rd brake housing to even hit the rear glass. SOLUTION: 1 big cable tie and a cordless drill.(yes drill puss...you want the sound gone or what?)
What To Do
fold down seats
Kam
You might want to check with your dealer, there was actually a recall on that. The dealer fixed mine, free of charge and I haven't heard anything since.
Quote:
yea the recall info... and they say to cover the ribs on the underside with some adhesive foam or something. It wouldnt work for me. Do you have subs in your trunk ?Originally Posted by jamaxin97
Quote:
Actually, I do. For some reason I'm now getting a rattle in the front over the glove compartment.Originally Posted by swowlinc
Quote:
Mine as well,sound like something near the windshield. Originally Posted by jamaxin97
Faaaakin car I tell you, oh well at least it aint an Avalon.
Kam
I've done socks, foam around the rear brake light and I was fine until I got my new box and then all whole new group of rattles came on board. As swowlinc said it's where the deck insert meets the glass for me at least...
Thats alot of work. But its a good idea. The only rattle I hear and thats only when I am outside the car is the plate. I put some rubber back there and it helped a little. Any ideas how to fix this.
You really can't blame Nissan. They didn't know that ppl were were going to put all this extra audio equipment in the trunk.
swowlinc how many amps are you pushing?
Originally Posted by ramberg
Thats alot of work. But its a good idea. The only rattle I hear and thats only when I am outside the car is the plate. I put some rubber back there and it helped a little. Any ideas how to fix this. You really can't blame Nissan. They didn't know that ppl were were going to put all this extra audio equipment in the trunk.
I've tried to take off the license plate piece (the whole oval piece) and I couldn't get to all the bolts, a definite rattle culprut.
And as for Nissan not "knowing" that people were going to add systems is BS in my opinion. They have to know this, look at the history of the Maxima, it's defnitely an enthusiast car as well as a 4 door cruiser. If anything they should have taken extra steps just to make the cabin nice an quite either way...
Thats easy, just cut a square of sound deadener the shape of the tag, apply it to the back of tag and youre done.Originally Posted by ramberg
That was a pita to get off. Nissan definately made taking that part off, hard. But with some tools and a McGuyver episode, you'll get it off. I got mine off and deadened that part too but I was all cut up afterwards.Originally Posted by jsmithsole
I've tried to take off the license plate piece (the whole oval piece) and I couldn't get to all the bolts, a definite rattle culprut.And as for Nissan not "knowing" that people were going to add systems is BS in my opinion. They have to know this, look at the history of the Maxima, it's defnitely an enthusiast car as well as a 4 door cruiser. If anything they should have taken extra steps just to make the cabin nice an quite either way...
When I first got my '07 SL, closing the trunk sounded like a death rattle because of the license plate. I bought a plain standard black plastic plate frame, applied small round soft plastic 'bumpers' to both bottom corners (on the side facing the car), and haven't heard the slightest sound since. Tight as a tick.
I bought one of those clear plastic license plate covers. I had to force the plate into the notches, but it holds the plate secure once it's in. I also bought the security bolts for the license plates (really because they look cool with a pointed tip). The thread doesn't match the original screws, but it will screw in. I just tightned down the plastic cover flush against the car and there is absolutely no rattle.
I need to stop buyng mods so I can get a digital camera and take pics of these things...
gec - Yeah! I'm really digging this new '07 Maxima! . . . in my dreams.
That slip-up will teach this senile old geezer with a one-track mind to never post about one model year when his feeble brain is dreaming about another model year.
Speaking of the '07, I realize those 'in the know' say it will be July before we see them on dealer lots, but I would not be surprised to see them begin straggling in next month. We will see . . .
what the hell are you guys running in your trunks? i've got a 15 with a kilowatt going to it and my rear deck doesn't rattle that bad. it's pretty damn solid back there.
but interesting fix non-the-less.
Shoot, mine rattled a bit when it was stock...
I'm running the 10" JL's off a JL 300/1 amp.
the only main rattle i can hear is the license plate. but inside, i don't get much rattles at all. problem is, stuff will start to shake loose over time and become noise-makers
Why would you drill those parts together when you could purchase a barrier loader such as Second Skin Roadkill and use it to fill the gap?
Put 1 - 3 layers of sound deadener on the back of the plate.
Oh, and Warren...I wanna start get things rolling for your LED tails, hit me back.
Led Tails? Mmmm do us proud Metal Maxima!
And dampening is on the list, just haven't had time to get in there a rip all that stuff out to do it!!
1500+ rms 2 L7's...Im gettin all the rattles anyone could have in this max...even the hood vibrates!Originally Posted by AscendantMax
Quote:
I have no idea what you are talking about. What is a barrier loader. Is it like the foam stuff in a can? I can see some suggestions working for those with no system or a small one... but not everyone, so you might as well fix the whole damned thing.Originally Posted by Metal Maxima
Quote:
Those are purple led's...they look blue in all the pics though.Originally Posted by SmokedOutMaxi
what is that blue light in your head lights????
Yeah...I just need a donor tail in order to get this going, though...
Quote:
http://forums.maxima.org/showthread.php?t=414337Originally Posted by swowlinc
OK! I didnt know it was called BARRIER LOADING . - Involves adding an acoustical absorber as to absorb sound waves from ambient noise (road, engine, wind, etc.). Great for ambient noise, somewhat effective in improving midbass. Foams work best for this application.
Miriam Webster is still on the jizzob
Quote:
Junkyard, Ebay, 2 crashed maxima's from the org maybe?Originally Posted by Metal Maxima
post pics when youre done...Senior Member
Just to throw my .02 in.....i put clear double sided sticky tape in betweent the window and break housing...i is kinda ghetto to do, but no one even notices is...but it completely stopped the rattle...
