Short Throw Shifter (STS) problem solved!!!
Old May 24, 2006 | 06:40 PM
DeusExMaxima's Avatar
I have been in touch with someone regarding the short throw shifter problem for 6 speed maximas and I took my car there for measurements. Some 6th gen maximas have a 67 mm shift linkage and some have 55 mm linkage. The theory is that 2004 models have 67 mm and Nissan shortened the shifter thereafter -2005-2006 models. The mystery man I have been in touch with will design a STS for the 55mm models. The question is how do u know if urs is 67mm or 55mm. The answer lies in the color of the pivoting arm on the car. I took a pic of each to show u the difference. The dark grayish arm in the first pic is a 55mm arm, and the gold colored arm is a 67 mm arm. The arms are centered in the pic and have cylinder shaped ***** on them
If you have a 6 speed Maxima, please let me know which pivot arm you have - 55mm or 67 mm based on the pics. Mystery man wants to know of there is a demand for STS for 55mm equiped cars.
Old May 24, 2006 | 07:16 PM
BlurryVizion's Avatar
Awesome!
Way to be on point Deus! I have an 06 and i was bummed when I heard that the original STS didn't fit (and dismayed that Nissan had alread shortened the throw, I still think it is a bit longish). I am so in as soon as the revised STS is completed.
I will let you know which arm I have. I will look in tomorrow.
MJ
Old May 25, 2006 | 05:10 AM
kamski's Avatar
.org extraordinaire
Deus!! Me Me Me Me Me Me Me Want One!!!
55mm maybe our shifts will be even shorter then the 67mm with STS.
Now if they only made a shortened shifter shaft.
Kamski.
Old May 25, 2006 | 01:02 PM
05AltimaSER's Avatar
I have a 05 Altima SER 6spd and have the 55mm. I have found this out and i also talked to the "mystery" man also. Hopefully the product will be done soon.
Old May 25, 2006 | 10:10 PM
Mystery man told me 2-3 weeks. Ill keep everyone posted. Interesting to note that the Alti SE-R is the same as ours. Im going to assume, all Alti and MAxima 6 speeds from 2005-2006 have 55mm shifter.
Kam: I asked extensively regarding shortening the shaft. It would be prohibitive to do so. If u removed the reverse lock out, then u probably could do it. Any way u slice it, its gonna be tough.
Old May 26, 2006 | 04:29 PM
I found an easy way to shorten the shifter by half an inch, which makes more of a difference than you would imagine. I have an Evo MR shift **** which is shorter than the stock ****. What I did was cut the top part of the reverse lock out off with a hack saw and sanded the top smooth. That top is about half an inch high, or so. Then I threaded my **** so it sits lower on the shaft. It looks waaaaaaay better and it shortens the throw slightly, and noticably.
Old Jun 3, 2006 | 01:29 AM
Anyone interested in this?
Old Jun 3, 2006 | 01:32 PM
kamski's Avatar
.org extraordinaire
I IZ!! sloppy long shifts suck.
Just got my endlinks too. Got to get them installed.
KAm
Old Jun 7, 2006 | 10:03 AM
kamski's Avatar
.org extraordinaire
BUMP!!!!!!!!!!!!!!!!!!! MORE INFO ON THE STS KIT FOR THE 55MM Bell housing part!!!
BUMP BUMP BUMP!!!
Old Jun 7, 2006 | 10:56 AM
Waiting to hear from my guy on the 55mm STS.
Old Oct 2, 2006 | 09:38 PM
suicidalspd99
Curious. What ahppen with this thread. Wanted to see if it went some place
Old Oct 2, 2006 | 10:12 PM
I havent heard back from the guy who was to make them . .so . . . who knows?
Old Oct 3, 2006 | 09:47 PM
suicidalspd99
Yeah looked that way, but figured I would ask. Thanks
Old Oct 3, 2006 | 10:34 PM
kamski's Avatar
.org extraordinaire
So..... ring him up or ring his neck, either way we'll get something out of it.
Kamksi
Old Oct 4, 2006 | 08:38 AM
suicidalspd99
Hop to it. I need a STS!!
Old Oct 4, 2006 | 08:59 AM
The sts is just about finished...just waiting on a bracket to bring the shift pattern back to stock and fix the angle on the cable....Should be within the next 2 weeks i hope. I have the STS on the car now without the bracket for cable...and its works great....ill let everyone know ASAP when its done
Old Nov 15, 2010 | 04:01 PM
04max6spd's Avatar
WHats up with the STS!? I need one
let me know!!!
Old Nov 15, 2010 | 05:33 PM
Pfc Woody's Avatar
dude four year old thread...
matts95max
Apr 23, 2025 10:44 AM
Mar 12, 2020 12:06 AM
ef9
Sep 10, 2015 10:35 PM
jwright36
Sep 8, 2015 11:45 AM
