MONROE Brake Info sheet.
Old Jun 25, 2006 | 07:40 PM
kamski's Avatar
.org extraordinaire
http://www.canadiantire.ca/affiliate...ing_FAQ_EN.pdf
Thank you Canadian Tire for the great info.
MONROE PREMIUM BRAKES FAQ
1. Do I need to follow a break-in procedure when I install new brake pads?
Yes...a proper break-in of rotors and pads is crucial to ensure proper braking performance and wear
characteristics of your new pads. Pads and rotors that are not properly broken in may end up creating
other symptoms such as vibration or noise or the pads may end up "glazing" which could dramatically
affect stopping performance. Always follow the break-in procedure described in the break in instruction
document.
BREAK IN INSTRUCTIONS
As brakes are safety items that affect the safe operation of your vehicle, we strongly suggest that a
licensed technician or highly experienced person familiar with brake pad performance and braking
systems install these pads (and associated brake system components) on your vehicle.
Once installation has been completed, a test drive should be done to ensure proper brake system operation
and to “break in” or “burnish” the pads to the rotors. The “break-in” is a required process, which must not
be overlooked, in order to achieve optimum performance of your new GranSport pads. To perform the
“break-in”, follow the steps listed below:
Step 1: Make 10 stops from 30 mph (50 kph) down to about 10 mph (15 kph) using moderate braking
pressure and allowing approximately 30 seconds between stops for cooling. Do not drag your pads during
these stops. After the 10th stop, allow 15 minutes for your braking system to cool down.
Step 2: Make 5 consecutive stops from 50 mph (80 kph) down to 10 mph (15 kph). After the 5th stop, allow
your braking system to cool for approximately 30 minutes. This completes the “break-in” of your pads to the
rotor surface. During Steps 1 & 2, a de-gassing process occurs which may produce an odor coming from
your pads as they complete the “break-in” cycle. This odor is normal and is part of the process your pads
must go through to achieve their ultimate level of performance. The odor will go away after allowing your
braking system to cool for approximately 30 minutes. As with any new set of pads, do not tow a trailer or do
any hauling during the “break-in” period. Full seating of your new brake pads normally occurs within 1000
miles. Your new pads are now ready for use. Drive Safely.
2. Do I need to resurface existing rotors when I am installing a new set of pads?
In order to ensure a uniform mating surface between the new brake pad and existing rotor, it is optimal to
resurface the rotor prior to installing and bedding-in new brake pads. Resurfacing the rotor will also help
ensure maximum pad life and braking torque (i.e. stopping power). Further, when changing from one
brake compound to another, especially when switching from semi-metallic brake pad to a ceramic-based
brake compound, it is necessary to turn your rotors to remove any existing friction material deposits on
the rotor. These friction material deposits (called "film transfer") can often interfere with the proper
"bedding" of new brake pads and, additionally, can cause a notable shudder during the initial stages of
new pad use.
Keep in mind, however, that when resurfacing the rotor, make sure you are within 20% of the factory
specified rotor thickness after resurfacing, or else your rotor will be more prone to warping and cracking,
or otherwise present a condition where catastrophic failure may occur (e.g. a rotor may crack severely
and then shatter under hard braking).
3. I am experiencing a brake shudder - what is causing this?
There are three main causes of "brake shudder", which is generally felt as a brake pedal or steering
wheel pulsation or vibration. Having verified that your rotors are not warped (i.e. warped rotors are
another, more obvious, cause of the brake shudder phenomenon), the following are possible, commonly
overlooked, explanations for an experienced brake shudder:
a. An improperly seated or mounted rotor (i.e. the rotor does not turn perfectly parallel to the brake pad
surfaces). This can be due to:
debris trapped between the backside mating surface of the rotor and the wheel hub
improperly tightened lug nuts/bolts
pads that are not properly re-aligning themselves after releasing the brake pedal, due to a very
rough or dry (i.e. non-lubricated) brake pad to mounting clip interface.
b. Heavy friction material film transfers on the rotors. Very heavy use of the brake pads, especially use
that exceeds the manufacturer's recommended heat range, can result in uneven friction material deposits
on the rotors. This results in a "grab-release" effect when the brakes are applied. While this will generally
even itself out over time, in extreme cases, the rotors may need to be resurfaced/turned/cut.
c. Worn suspension parts (i.e. springs, shocks/dampers, bushings, etc.). "Old timers" call this type of
suspension shift under torque load "tramp". In this situation, the car's alignment is slightly changing due to
brake torque upon brake pedal application. Severe cases of this result in a very notable pull in the
steering, and can become evident as a shudder. If this is the cause of your brake shudder, the suspect
suspension components should be replaced.
4. What is brake fade and why does it occur?
Pad fade occurs for several reasons. All friction materials have a coefficient of friction curve over
temperature. Friction materials have an optimal working temperature where the coefficient of friction is the
highest. Sometimes you can use the brakes so hard that you get the temperature over the point of
maximum friction to where the coefficient of friction curve starts to decline.
The mechanics of this decline in the coefficient of friction are varied. At a certain temperature, certain
elements of the pad can melt or smear causing a lubrication effect, this is the classic glazed pad. Usually
the organic binder resin starts to go first, then even the metallic elements of the friction material can start
to melt. At really high temperatures the friction material starts to vaporize and the pad can sort of
hydroplane on a boundary layer of vaporized metal and friction material which acts like a lubricant. Pad
fade is felt as a car that still has a decent, non mushy feeling brake pedal that won't stop even if you are
pushing as hard as you can. Usually it builds somewhat slowly giving you time to compensate for it, but
some friction materials have a sudden drop off of friction when the heat is put on them resulting in sudden
dangerous fade.
Green Fade Green fade is a type of fade that manifests itself on brand new brake pads. Brake pads are
usually made of different types of heat resistant materials bound together with a phenolic resin binder.
These are thermosetting plastic resins with a high heat resistance. On a new brake pad, these resins will
out-gas or cure when used hard on their first few heat cycles. The new pad can hydroplane on this layer
of excreted gas. Green fade is dangerous because many people assume that new brakes are perfect and
can be used hard right off the bat. Green fade typically will occur much earlier than normal fade so it can
catch a driver that is used to a certain car's characteristics unaware. Typically the onset of green fade is
rather sudden, further increasing the danger factor. Green fade can occur if you change the pads and
drive on the street for a few hundred or even thousand miles, never braking hard, then suddenly start
using the brakes hard.
5. What do edge codes mean?
An edge code is a means of identification that may be used to describe the initial frictional characteristic
of any brake lining.
Typically, a two-character code (e.g. EE, FF, GG, HH, etc) is used on specific friction formulation. These
characters represent the coefficient of friction when a 1" square piece of friction material is subjected to
varying conditions of load, temperature, pressure and rubbing speed on a test apparatus known as the
Chase machine.
The coefficient of friction measured by the Chase test describes the relationship between the two forces
acting on the friction material. A clamping force is exerted on the friction material, resulting in a frictional
or resistance force. A low coefficient of friction means that very little of the clamping force is transferred
into resistance force. On the other hand, a high coefficient of friction means that given the same level of
clamping force, a higher resistance force is generated by the brake pad.
For example, a pad that carries an HH code has a normal coefficient of friction of 0.55 or higher, and a
hot coefficient of friction of 0.55 or higher.
The first letter of the code represents the normal friction coefficient. This is defined as the average of four
test data points measured at 200, 250, 300 and 400 degrees Farenheit.
The second letter of the code represents the hot friction coefficient based on a fade and recovery test. We
all should know what brake fade is. If you've ever had to use the front brake extensively and found that its
effectiveness quickly diminished, that's fade. Recovery is basically the period where the brakes are
gradually cooling off.
The hot friction coefficient is defined as the average of 10 data points located at 400 and 300F. On the
first recovery cycle of the pad; 450, 500, 550, 600 and 650F. On the second fade cycle; and 500, 400,
and 300F on the second recovery cycle.
The range of friction coefficients assigned to each code letter are as follows: C = less than 0.15. D= 0.15
to 0.25. E= 0.25 to 0.35. F= 0.35 to 0.45. G= 0.45 to 0.55, and H= over 0.55.
6. What types of brake fluids are available for my vehicle?
There are three main components or considerations that must be addressed when selecting the proper
brake fluid for your braking system. The first is the DOT-specified compliance of your brake system: DOT
3, DOT 4, DOT 5, or DOT 5.1. You can find this information in your owner's manual. In general, DOT 3
and DOT 4 fluids and systems are compatible with each other, and are differentiated by their dry and wet
boiling points (more on this later). Some synthetic DOT 5.1 fluids are also compatible with DOT 3 and
DOT 4 fluids/systems. DOT 5 fluids are silicone based, and must NEVER be mixed with a DOT 3 or DOT
4 fluid/system, and vice-versa.
The second consideration is the boiling point of the brake fluid. For brake fluids, there are two key
temperature points that you should be aware of: the dry boiling point and the wet boiling point. The dry
boiling point is the temperature at which the brake fluid will boil when freshly installed. The wet boiling
point is the temperature at which the brake fluid will boil after it has absorbed moisture from the
environment; i.e. after being used in the brake system for a while. The most important of the two is
arguably the wet boiling point, especially for those who do not change their brake fluid often.
The third point to consider is the hydroscopic nature of the fluid, often termed "hydroscopicity". Quite
simply, a brake fluid's hydroscopicity is its propensity to absorb moisture: a brake fluid that is very
hydroscopic will absorb moisture at a faster rate than a brake fluid with a low(er) hydroscopicity. In
general, high-performance brake fluids which are designed for use on the street (where the vehicle owner
is assumed to change the brake fluid on an annual basis, on average) have a low hydroscopicity (along
with lower dry and wet boiling points), while brake fluids designed for use In a performance environment
will have a higher hydroscopicity (along with a higher dry and wet boiling points). There are exceptions to
this general rule-of-thumb, of course, but "in general" these statements are correct.
7. What is the proper method for bleeding brakes?
When bleeding brakes it is best to manually bleed them as pressure bleeders can cause cavitation and
bubbles inside the system. Empty the brake reservoir with a turkey baster then fill the reservoir with a
high quality brake fluid. Start bleeding at the furthest wheel away from the Master Cylinder and progress
to the closest. So that would go right-rear, left-rear, right-front and left-front. Attach a length of clear Tigon
tubing to the bleeder nipple, put the other end of the line into some sort of container so the other end will
be submerged in brake fluid and open the nipple. Have someone in the car to pump the brakes. Slowly
pump all of the old fluid out of the line until new clear fluid comes out and then have the person in the car
hold the pedal down while you close the bleeder. Have the person lift the pedal up slowly and then push
down slowly while you open the nipple. You have to communicate with the pumper because the bleeder
should only be open on the down stroke of the brake pedal. It is important to pump slowly to avoid
bubble-forming cavitation. Continue to pump until you cannot observe any bubbles in the clear Tigon
tube.
Get a rubber mallet and tap the caliper to dislodge any bubbles that may be stuck inside the caliper and
bleed some more until no more bubbles come out. Do this at all the wheels and you are done. Be careful
not to let the reservoir run dry or you will have to start all over. On ABS equipped cars you want to be
extra careful about this because it takes forever and a lot of fluid to bleed a completely dry ABS system.
Some ABS cars require bleeding from nipples on the ABS modulator so check your manual.
Old Jun 25, 2006 | 07:52 PM
Monotaur's Avatar
Hey Kam,
I tried to PM you but your inbox is full... can you clear something out?
Thanks!
Old Jul 9, 2006 | 09:57 AM
guimar98's Avatar
Those brake pads ate my rotor in 30000KM
Old Jul 9, 2006 | 10:11 AM
kamski's Avatar
.org extraordinaire
Nice!!! My Axxis ate mine in 4000 kilometers.
Junk, im putting my Monroe back in when new shocks arrive.
Kamski
Old Jul 9, 2006 | 10:27 AM
Glude's Avatar
Kamski
Are we talking about stock rotors here? If so the pads had nothing to do with the rotors warping, them oem rotors just suck ***!
Old Jul 9, 2006 | 11:32 AM
kamski's Avatar
.org extraordinaire
No, the axxis ultimate ate my brand new rears REAR slotted rotors from automax95, either thats or they are sheety rotors. Even the friggin "zinc plating" BS came right off....... its all rusty and sheet.
Faq, no more buying brake parts on line....
Kamski
Old Jul 9, 2006 | 11:37 AM
NismoMax80's Avatar
SuPeRmOd
Kam, you do understand that any brake surface will become rusty right?? no matter what you coat them with the pads of course will wipe it off. the zinc is meant to coat the non-pad surfaces. now if those became rusted, then i suppose it was a poor zinc process or they became extremely overheated which would cause excessive wear all around.
you can still buy brake parts online, just choose a different manufacturer. those same ones are available "offline".
Old Jul 9, 2006 | 12:05 PM
Glude's Avatar
My rotors from automax also rust but I believe its normal. It doesnt effect stopping at all.
Old Jul 9, 2006 | 12:40 PM
kamski's Avatar
.org extraordinaire
The stopping area is fine, but all the zinc coating is flaking off......
Maybe i got a bad batch :S maybe its the aggressive bite of teh axis pads..
I dunno, i will contact automax with pics cause i didnt want it to rust.
Kamski
Old Jul 9, 2006 | 04:38 PM
MisterSparkle's Avatar
i think sticky...lolxz
Old Jul 14, 2006 | 02:50 PM
kamski's Avatar
.org extraordinaire
I would be great, but the damn formatting keeps getting mangled.
Kam
Old Jul 14, 2006 | 04:30 PM
well i just think its deservant to be one...its very helpful especailly for those who have done braking upgrades!
Old Jul 14, 2006 | 04:43 PM
kamski's Avatar
.org extraordinaire
Unless a mod can hack the info off the Canadian Tire website and make it look proper it would be cool.
Kamski
Apr 16, 2020 05:15 AM
BobTX10
Oct 7, 2015 08:43 AM
fx4five
Oct 1, 2015 04:58 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
