Nissan emblem for Grille.
Old Jul 19, 2006 | 05:31 PM
silvermouse5150's Avatar
I just recently got the Street Scene Speed Grille.
I plan on putting the nissan emblem on it.
I purchased one from ActiveTuning, but it doesnt sit flat its made to fit into a slot.
Where i can purchase an emblem that is flat in the back?
Would be even better if it had adhesive backing.
-Thanks, hope you guys can help
Old Jul 19, 2006 | 05:54 PM
KUBLKMAX's Avatar
sand it down and get some double sided tape.
Old Jul 19, 2006 | 08:04 PM
Glude's Avatar
That could possibly work. How much was the emblem from AT?
Old Jul 19, 2006 | 08:18 PM
jdmaxima89's Avatar
On the pedobear bandwagon
I've got a stock emblem brand new adhesive backing still on it for the 04-06 grilles... if anyone needs it pm me.
Old Jul 19, 2006 | 08:19 PM
MisterSparkle's Avatar
keep the emeblem represent your nissans...lolxz
Old Jul 20, 2006 | 01:36 AM
MAXDOUT04's Avatar
* THIS SPACE FOR RENT *
That emblem is HUGE...... for a street scene grille
Old Jul 20, 2006 | 07:23 AM
PENROSE2006's Avatar
I took the emblem off of my stock grille, sanded the back a little, pulled off the original 3M double faced tape, replaced it with some fresh new 3M tape and put that sucker on my new grille. I think it looks good, but the new grille looked good without it also. Someday I may take it off along with all the other badges/emblems, but for now I think it looks alright.
Old Jul 20, 2006 | 11:07 AM
I bought the emblem for $10.
Its going to be a tough sanding job though.
the half circles, top and bottom extrude out in the back about 1/2 an inch, i think it fills in a slot or something.
Didnt want to use the emblem from the original grille, so i could possibly sell it.
Old Jul 20, 2006 | 02:57 PM
MAXDOUT04's Avatar
Hey penrose do you have the chrome door handles? if so can you take a side shot so i can see what it really looks like im thinking about this mod but wanna see it up close thanks
Old Jul 22, 2006 | 05:50 AM
Wakkus_Maximus's Avatar
Ok silvermouse, here's what I did:
1. take black electrical tape (I used it because that's what I had) and make a cross in the grille, so that you mark where the center is.
2. Put the emblem on top of the grille and mark the 2 half circles or gaps from the logo into the grille, using a magic marker or carpenter's pencil.
3. With a dremel tool, cut the divisions on the grille in order to fit the 2 half circles inside the grille, using the marks you just did as a guide on where to cut. Take your time, and you'll have a good support on the emblem, the double-sided tape will touch the grille, it will look flush on the grille, and the fact that the half circles are shown on the grille will give you an OEM look.
4. Just to make sure everything stays in place, get some epoxy paste and put it behind the emblem after installing it, under the line that divides the circle. That way you're applying it to the grille, and it will be rock solid later.
Here are some pics of how it looks after you finish. I love it...
Old Jul 22, 2006 | 02:27 PM
No close-ups but here is a side view
Old Jul 23, 2006 | 02:51 PM
Max Trunk Emblem question
Anyone know if the emblem is flat on the back side?
Im planning on putting it on my new street scene grille.
I dont want to do any type of sanding, drilling, or cutting.
I would like to have the Nissan emblem no smaller than the trunk emblem, and no larger than the grille OEM emblem. And have the same type of bevel.
Anyone know if the emblem is flat, or where i can get one similar to this description??
Old Jul 23, 2006 | 02:58 PM
well i think i've seen people say its not flat that you have to sand the emblem just a lil bit though...buh don't take my adivce. i achually just wanted to kno where some of you guys got those rear nissan emblems that has wings...i think i've seen it on some of the maxs...lik chern i think you have one, or ramberg. one of you two...or both?
Old Jul 23, 2006 | 03:11 PM
Whats the best way to sand down these emblems?
With Sandpaper?
Old Jul 23, 2006 | 03:53 PM
PapaL's Avatar
I think the trunk one is flat. I have it in the garage. I'll go look.
Old Jul 23, 2006 | 03:56 PM
PapaL's Avatar
Its not one solid flat piece all around, but it is flat with a circular groove along the middle of the outside ring (I'm guessing where they pack the glue in). Hope that helps.
Old Jul 24, 2006 | 06:32 AM
Hey IcIrod,
Thanx, this does help - 1 other quick question.
Does it sit flat? like would i be able to put it on the grille w/out sanding any of it down?
Thanx again
Old Jul 24, 2006 | 06:44 AM
chernmax's Avatar
Nations 1st 6th Gen Turbo
Both the front and rear emblems have two small posts for alignment in the grill and trunk, when I had my Trenz grill, I just bought a new emblem off Ebay for about 6 bucks and left my old on on my OEM grill.
I never had to sand the emblems either, not sure what that's about?
Old Jul 24, 2006 | 07:38 AM
the street scene grille doesnt have any slots to place the emblem.
The OEM emblem that i got at the dealership, has these extrusions behind it, so the emblem doesnt sit flat. There are 2 notches on it that are easy to sand, but the extrusions look like it may take some time.
Was really just being lazy, and wanted to know if there was something that sat flat, in case i screw the sanding down up somehow (like sanding too much off)
Old Jul 24, 2006 | 07:42 AM
chernmax's Avatar
Since the extrusions are plastic, I just uses a wire cutter and clipped them off...
Old Jul 24, 2006 | 10:52 AM
Oh im sorry man, i dont think i described it correctly.
The two notches that extrude, i clipped those off.
But the top and lower half circles outline are extruded about 1/2 inch on the back.
I sanded those down, but the emblem still doesnt sit exactly flat on the grille,
I dont think anyone will really notice. The sides are about 2-3 mm off the grille, but the top and bottom sit flush - I know im being ****.
i wanted to know if maybe the trunk emblem would fit better.
Old Jul 24, 2006 | 11:16 AM
chernmax's Avatar
To get the grill emblem to sit flush, you actually have to bend ever so slightly the new grill itself. Then the emblem will sit flat. Trunk emblem should be easier...
Old Jul 24, 2006 | 01:34 PM
Really?
Would this make the grille not fit anymore?
Hmmmmm, makes me nervous to try this - but i might try.
I might go w/ just letting the sides not sit flush, - think this would look bad?
We'll see this weekend if ive got the nerves to try bending the grille
Do you know of anyone that has done this?
Old Jul 24, 2006 | 01:37 PM
ended up getting the OEM front emblem.
I sanded the back down but the sides doesnt sit flush. About 2-3mm off grille.
ChernMax, recommended that i bend the grille gently to make the emblem fit.
Old Jul 24, 2006 | 05:44 PM
PapaL's Avatar
Hey IcIrod,
Thanx again
My rear emblem sits flat when I lay it down. No rear protusions, I could take pics if anyone wants.
Old Jul 24, 2006 | 08:26 PM
chernmax's Avatar
The trick is to lay the grill on a towel or blanket face down and gently push down on both ends to flatten the middle. It worked perfect on my old Trenz grill and the emblem was flush with no sanding...
Old Jul 24, 2006 | 08:34 PM
Glude's Avatar
damn, your car is VERY shiny in that pic. My front bumper looks like poo and the hood is rockchipped like a ****. I might have to consider a repaint on a couple things.
Old Jul 25, 2006 | 11:40 AM
Yeah, pics would be great.
I have the same grille as you, but in brushed aluminum.
Street Scene Speed Grille right?
Dont want to "jimmy" the emblem on.
If i could just get the rear trunk emblem to sit flush, i would go w/ that.
But i dont want to spend more money and time sanding the new emblem than i already have just to have the same problem
Pics would be heavily appreciated.
Old Jul 25, 2006 | 07:46 PM
Heyy just cut it like I said... the fit will be flush and tight like all of us like it....
Old Jul 25, 2006 | 08:23 PM
Keep sanding!! I clipped the tabs off of mine, then held it flat on my palm sander (oscilating) and eventually it was flat and flush around the whole emblem.
I would rather do a little sanding to the emblem than to try and bend my grille! But, whatever works for you.
Old Aug 4, 2006 | 02:14 PM
willysmooo's Avatar
For those with lots of miles and grille problems dont give up hope. My first grille started peeling with about 32k on it, so nissan replaced it. I now have 68k on m car and called nissan to tell them another grille is peeling, and i didnt hear anything and whooallah 4 weeks later the dealer calls me today, and said they have a new grille for me again, so I got anew grille and they did the subframe thing,...and the car actually donsnt make as much noise from the back end anymore either...
adamgalazka
Feb 5, 2023 08:24 AM
Mar 12, 2020 12:06 AM
Bernhard
Sep 14, 2015 12:49 PM
coasterswim
Sep 2, 2015 07:43 AM
