Rear shock mounts...
Old Sep 30, 2006 | 05:18 AM
!PrjctMax!'s Avatar
...is there a problem with the rear shock mounts by chance? By problem I mean are they like the frront struts that blow out on almost every Maxima? I ask this because after I installed my RSB/endlinks there is an annoying creak while turning over bumps. And I just got KYB shocks and just relubed the mounts/bushings last night and adjusted the endlinks accordingly to the drop. The noise isn't major, but enough for ME to hear and it gets a little frustrating knowing that it's still there after relubing it and making sure everything was alright.
So anyone got any suggestions?
Dan
Old Sep 30, 2006 | 07:02 AM
erasat's Avatar
I had the same sounds for months after mounting the RSB, I made Nissan to changed my Rear Shocks, they adjusted everything related to suspension, and still the noise, so I asked them to relube the RSB bushings, they didn't even notice that it wasn't OEM, they did it, and noise was gone. It has been 3 months and still no sounds.
Note, they did order the bushings, they called me back in July that they got them, they are still waiting for me to go, are they dumb or something?
Old Sep 30, 2006 | 07:39 AM
Tek-Niq's Avatar
my rear view mirrors flap like a f-ing bird
I bet is the rsb bushings also..
Old Sep 30, 2006 | 07:46 AM
!PrjctMax!'s Avatar
What about the bushings? Are they bad?
Also I noticed that the bushings were sliced in one spot so that they could be put on the bar...is that how it's supposed to be done?
Old Sep 30, 2006 | 07:51 AM
erasat's Avatar
I don't think they are bad, mine were the same, I think is related to the amount and quality of the grease. Mine are still installed and they haven't make any sounds for months now.
Old Sep 30, 2006 | 08:49 AM
koyoki's Avatar
Well from my experience, the red poly bushing makes the most noise. The black poly is the better one. As for the red poly you have to keep it contantly lube but make sure you use electrical grease for it. Not regular bearing grease. Good luck
Old Sep 30, 2006 | 10:50 AM
Tek-Niq's Avatar
not bad just grease them some more. that slice is suppose to be there so that you could slide them on the bar.
!PrjctMax!'s Avatar
The lube that I used was 3M Silicone Paste....and I covered the mounts/bushings with a thick layer of it.
matts95max
Apr 23, 2025 10:44 AM
AcuraLegend
Oct 17, 2016 08:47 PM
AcuraLegend
Sep 22, 2015 04:22 PM
Violator
Sep 9, 2015 10:14 AM
