Willwood 13.6" BBK with 6 Piston Callipers Arrived - Picture Heavy
Old Oct 8, 2006 | 04:19 PM
xoomer.com's Avatar
I Donate! Why Don't You?
Since only recently Kam posted about the choices we now have with Willwood kits from FastBrakes.com I though I'll post some pictures for you guys to see. This kit was installed on my brothers 2005 maxima se, he is not into forums so I do the research and we apply the mods. This is one crazy kit and stops the car on a dime. It comes with 13.6" drilled and slotted two-piece rotors, 6POT callipers and SS lines. Questions, Comments?
BTW both cars are lowered already.
Old Oct 8, 2006 | 04:49 PM
kamski's Avatar
.org extraordinaire
Who's the scary dude in the last pic
I'm telling you those Wilwoods ROCK!!!
Old Oct 8, 2006 | 05:01 PM
xoomer.com's Avatar
My brother Dominik, These rotors are huge to fit through his round head. HEHE
Old Oct 8, 2006 | 10:41 PM
!PrjctMax!'s Avatar
How was the install? And can you only get the drilled/slotted rotors? Or are there otehr availabilities such as blanks or just slotted etc, etc.
Looks amazing though!
Dan
Old Oct 9, 2006 | 04:04 AM
DTinVA's Avatar
Don't suppose there's any chance those would fit with stock rims?
Old Oct 9, 2006 | 05:55 AM
madmik's Avatar
What was the weight reduction like per wheel?
Old Oct 9, 2006 | 07:25 AM
xoomer.com's Avatar
I believe it can fit stock 18" with a small spacer as Kam has mentioned in previous treads. I will try to put on 18" OEM rim on it either today or next weekend to see how much offset is needed. Will update you guys then
Old Oct 9, 2006 | 07:26 AM
xoomer.com's Avatar
Dan
The guy who installed the springs, shocks, etc did it in one shot so he charged us only $35. I don't think you should pay more then about a $100 for such install thou.
Old Oct 9, 2006 | 04:01 PM
05AltimaSER's Avatar
those are some nasty brakes!!!!
Old Oct 9, 2006 | 04:35 PM
kamski's Avatar
.org extraordinaire
You need 5mm offset spacers for the 18" rims, the spokes touch the willwood letters.
The 13.25" will fit the 17" SL rims idealy the 13.6" will not.
The 12.5" kit will fit the 17" SL rims, but you still will need the 5mm spacer for the 18" rims.
Kam
Old Oct 9, 2006 | 06:25 PM
joebangaa's Avatar
I was wondering... since 6th gen brakes are a direct bolt on to 5th gens... would this kit 5th gens as well?
Old Oct 10, 2006 | 11:59 AM
xoomer.com's Avatar
Kam you'd said that you got your 5mm spacers from a local shop for like $5.00 bucks, Are you serious? Can you still get some or was it one time deal?
Old Oct 10, 2006 | 12:05 PM
kamski's Avatar
.org extraordinaire
http://www.pickeringtire.com/
$6.00 CA
so
$4.50 US
I can swing by there next week when I'm back on the road.
Kamski
Old Oct 10, 2006 | 12:14 PM
xoomer.com's Avatar
$6.00 CA
so
$4.50 US
Kamski
Do me a favor and check what's up. I will try the 18" stock possibly today to see what's up. Will update then.
Old Oct 10, 2006 | 03:37 PM
kamski's Avatar
.org extraordinaire
With the 4POT you'll need spacers, with the 6POT i think you might be ok.
Like the clearance issue was minimal and I mean minimal.
Kamski
Old Oct 10, 2006 | 04:24 PM
xoomer.com's Avatar
Kamski
NOT AT ALL KAM.
I just tried OEMs 18" (they have 40mm offset, so it says on them) with 6POT and it will not fit. Not only it will not fit, 5mm won't do jack. It needs like 8-10mm to clear. I was shocked/disappointed. I will get your the model modem of the calipers later. Post yours too or email me.
Old Oct 10, 2006 | 04:25 PM
xoomer.com's Avatar
... I will get your the model modem of ....
WTF. sorry I am just tired for today,
Old Oct 10, 2006 | 05:25 PM
roro's Avatar
where can i measure to see if these will fit? i have 18" axis reverbs...
Old Oct 10, 2006 | 05:40 PM
!PrjctMax!'s Avatar
Do these rotors only come slotted/drilled?
Old Oct 23, 2006 | 06:00 AM
xoomer.com's Avatar
I finally had the time to try OEM rims with a spacer. I went out and bought one universal spacer that is 5/16“ thick. According my calculations 5/16” is 8mm | (5 / 16) x 2.54 = .79cm
Anyhow, the bad new is that it will not clear the calipers. The rim is a standard 18” stock rim and it says that it has an offset of 40mm. Honestly saying I don’t think 10mm spacer will even do. I am sure 15mm spacer will do the job but would mean changing the studs and possible tire clearance problems. This is for a 13.6” BBK 6POT Kit.
If one was to buy a 6POT caliper for their stock rotors it would be even harder to clear because the spokes on the rim go inward towards the center cap and there is less clearance the closer the caliper sits to the center bore.
Old Oct 23, 2006 | 06:09 AM
kamski's Avatar
.org extraordinaire
THAT BLOWS! My 4 POT wilwoods fit great with that chinsy small azz spacer and the OEM 18".
Frig I dont even need a spacer for the 17" OEM rims but the wheel weights touch the caliper on the 17". Thats cause the 13.6" rotor pushes the caliper out too far forward. But with the 12.5" OEM rotor and 4POT caliper the wheel clearance would be ideal.
Well, whats the offset on the 17" OEM SL rim? Cause you basically need a rim like that but in 18" size to make the BBK fit.
Kamski
Old Oct 23, 2006 | 06:13 AM
kamski's Avatar
.org extraordinaire
..........YES...........
Old Oct 23, 2006 | 08:22 AM
Tek-Niq's Avatar
my rear view mirrors flap like a f-ing bird
Kamski
thats cause the 17's are 35mm offset
the 18's are 40mm...
Old Oct 23, 2006 | 08:34 AM
roro's Avatar
ok... so where can i measure the clearance on my wheels to see if the 4pot calipers will fit (on stock rotors)?
Old Oct 23, 2006 | 08:39 AM
Tek-Niq's Avatar
the fitment issue he's talking about is the 4 pot on a 13.6" rotor, the stock one is 12.6" so a 4 pot will be fine..
Old Oct 23, 2006 | 08:43 AM
roro's Avatar
well what he was saying was that the 6pot with the stock rotor would have even more issues than with 13.6" rotors because the center of the stock wheel goes in...
some simple measurement numbers would be helpful in determining if these will fit properly. i have 18" axis reverb rims so my guess is i'm okay... but better safe than sorry
Old Oct 25, 2006 | 03:54 PM
kamski's Avatar
.org extraordinaire
This is what a review had to say about Brians Wilwood BBK.
NISSAN PERFORMANCE MAG FASTBRAKES BBK REVIEW
Just stumbled upon this today
Kamski
Old Oct 25, 2006 | 04:04 PM
roro's Avatar
uhhh wrong link lol
Old Oct 25, 2006 | 04:26 PM
xoomer.com's Avatar
Kamski
Kamil post the right link man
Old Oct 25, 2006 | 04:31 PM
kamski's Avatar
.org extraordinaire
Kamski
Fixed
Old Dec 5, 2006 | 03:52 PM
xoomer.com's Avatar
bump cause of questions received..
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
MaxiNoob98
Oct 2, 2015 10:13 PM
bigfrank
Oct 1, 2015 12:51 PM
