radiator cap
Old Oct 26, 2006 | 08:05 AM
eK9aT10pSi's Avatar
radiator cap
which one would be the best and cost effective to get a 1.3 bar cap over the stock 0.9bar one? im thinking of the greddy one possibly, TIA
Old Oct 26, 2006 | 08:25 AM
chernmax's Avatar
Nations 1st 6th Gen Turbo
I've had the Greddy radiator cap for almost 3 years now on my ride and mine still looks and works flawlessly...
Old Oct 26, 2006 | 09:23 AM
JoesRedMax's Avatar
I have the NISMO one and also have had no issues.
Old Oct 26, 2006 | 10:48 AM
2LEET4U's Avatar
i second on the Nismo...
http://www.courtesyparts.com/Merchan...de=21430-RS012
Old Oct 26, 2006 | 11:32 AM
Glude's Avatar
What do u need a new one for?
Old Oct 26, 2006 | 08:46 PM
eK9aT10pSi's Avatar
just to increase the cooling in the radiator system. i plan on flushing out the coolant and use toyota red 40/60 with 1 bottle of redline water wetter, texas heat, here i come, lol.
Old Oct 27, 2006 | 05:00 AM
FrostMaxima's Avatar
I suggest not using the water wetter, as i used it in my max and it thins the anti-freeze which can inturn cause leaks, I could never find a leak but i could always smell burning antifreeze whenever i would drive.
Old Oct 27, 2006 | 05:21 AM
!PrjctMax!'s Avatar
So yoo're telling me that the NISMO radiator cap is actually worth the $50 price tag? Since it cools the radiator a little bit more?
Dan
Old Oct 27, 2006 | 06:51 AM
Glude's Avatar
Dan
prolly not but people like blowing money on worthless stuff.
Old Oct 27, 2006 | 07:53 AM
xoomer.com's Avatar
I Donate! Why Don't You?
Raidator cap has nothing to do with the cooling. Its just a cap. Changing the thermostat makes the difference.
Old Oct 27, 2006 | 11:40 AM
!PrjctMax!'s Avatar
ya that's what i thought too
Old Oct 27, 2006 | 01:33 PM
NmexMAX's Avatar
dot dot dot ...
Or modifying it can provide lower temps.
Old Oct 28, 2006 | 05:46 PM
madmik's Avatar
A radiator cap with 18.5 lbs of pressure:
A) Will "Increase the performance of your radiator" by raising the boiling point.
Std cap 14 lbs.,GReddy 18.5 lbs => +4.5 lbs X 3 => 13.5 F. higher boiling point. It cheaper to run a 70/30 antifreeze mixture but that actually lowers the cooling performance of the radiator. Catch 22.
B) Will increase the possibility of a leak around a clip, pop a hose, or worst, crack the aluminum radiator. The system is tested for 11-14 lbs. Its only as good as its weakest part.
I installed a 170 F. 350Z thermostat (fitting required), which lowers the temp by ~10 degrees. I run 30/70 antifreeze & Water Wetter. You could also get a Nismo 155 F. for $120.
I tried tweaking my thermostat so it could open sooner. No luck. Its rivetted into the housing. Shortening the spring made it unstable.
Old Oct 28, 2006 | 08:29 PM
Rusty Nutz's Avatar
My 280 Z won best of show at a Z car show and one of the prizes I got was a Nismo 350Z Rad. cap. Put it on my Max it fits and works just fine.
Old Oct 30, 2006 | 05:34 PM
xoomer.com's Avatar
10 degrees difference is like spending $2.68 instead of $2.69 for a gallon of gas. It ain't doing you sheet.
Old Oct 30, 2006 | 06:29 PM
NmexMAX's Avatar
dot dot dot ...
I'd rather be at 190*F vs 200*F
Old Oct 31, 2006 | 02:58 PM
xoomer.com's Avatar
Between $2.68 and $2.69 per gallon I'd rather pay $2.68 per gallon! Would it make a difference?
ABSOLUTELY NOT!
Old Nov 1, 2006 | 12:13 PM
I VIK I's Avatar
well over a 20 gallon tank you would be saving 20 cents :-)
Old Nov 1, 2006 | 12:24 PM
eK9aT10pSi's Avatar
^^^^ and thats per week [for me at least, fill up once a week]. the nismo thermostat i thought was only for the g/z. if installed on the max, the hose has to be modified.
with modifying stock thermostats, a lot of the honda ppl drilled a 3/16" hole at3,9,12 o clock which let the coolant flow [obviously]
Old Nov 1, 2006 | 12:31 PM
eK9aT10pSi's Avatar
actually, isnt the stock 0.9kg/cm which would be 12.6lb instead of 14lb? the nismo one is 18.2lb [1.3kg/cm] so:
18.2-12.6 = 5.6*3 = 16.8 deg F higher. [i got curious]
+/- 35$ isnt too bad. [courtesy is less than a mile from my work]
Old Nov 1, 2006 | 01:13 PM
xoomer.com's Avatar
You nailed it!.
If that was my goal I would take out my CAI and stop floring the car. That would proly save me more than $5.00 per fill up.
I bought my max to enjoy it. >>
Old Nov 1, 2006 | 03:02 PM
NmexMAX's Avatar
dot dot dot ...
10 -12* F could meanthe difference between timing retard and advance. You missed the point..
Old Nov 2, 2006 | 03:06 PM
madmik's Avatar
Correct 12.6 lbs. Was looking at pressure range. For me, running a cooler engine is as important as having good/clean engine oil. That's just me.
Re timing: That's what I was hoping for. With the cooler engine the ECU would run a tad richer and more advance.
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
05RLS2
Apr 14, 2016 11:49 AM
Unclejunebug
Apr 2, 2016 05:42 AM
