What type of Brake Pads do you have?
Old Nov 7, 2006 | 05:50 AM
vir420's Avatar
What type of Brake Pads do you have? Need Suggestions!
Need new brake pads for the Max, might get new Rotors also. Just wondering which Brake Pads everyones using and how they are (durability, noise, stopping power, etc.)
My top two choices so far were to either go with the Hawk HPS Pads or Axxis.
Anyone have a better suggestion or tell me why I might not want to get either?
Old Nov 7, 2006 | 06:05 AM
04BlackMaxx's Avatar
OEM baby...no noise, no problems...served me well for 64,000mi on thee front so I replaced it with the same thing.
Old Nov 7, 2006 | 06:13 AM
!PrjctMax!'s Avatar
Go with hawk pads.........have heard NO BAD REVIEWS about them, and the Axxis ones will start squeaking pre-maturely. I'm also going to get the hawk pads soon.
Dan
Old Nov 7, 2006 | 07:23 AM
mroleg's Avatar
I've had HAWK HPS on all 4 wheels for about 3 months now. Great pads.
Old Nov 7, 2006 | 09:40 AM
vir420's Avatar
I'm leaning on the Hawk HPS right now, I think there is a GD on it, not sure
Still waiting on more feedback / review from the ORG.
Old Nov 7, 2006 | 01:45 PM
HADA 11's Avatar
Hawk HPS and Brembo blanks
Old Nov 7, 2006 | 06:12 PM
Longhorn101's Avatar
Question for those doing 6th Gen brake pad replacement. Do the OEM front brakes have the pad shims or not? Do the aftermarket pads have the shims? Reason I'm asking is that I have a persistent squeek from new front OEM pads without shims. They were just replaced before I bought the car. I noticed the rear pads have shims and have no noise problems with them.
Old Nov 8, 2006 | 05:38 AM
4MySwee's Avatar
OEM still, I'll have to get back to you! Oh yeah, no squeak here!
Old Nov 8, 2006 | 12:56 PM
savagecat's Avatar
Going Ginsu
Brembo blanks w/Hawk HPS pads. No noise.
Old Nov 8, 2006 | 04:04 PM
willysmooo's Avatar
OEM as well, they were 65 bucks for all 4 wheels and no noise, no vibration and they laster 54k. No reason to spend more $$$
Old Nov 8, 2006 | 05:31 PM
jsmithsole's Avatar
*moderator*
I have the Axxis/PBR Ultimate pads from the GD. I put them on in Sept. of last year and still running strong.
Here's the thread:
http://forums.maxima.org/showthread.php?t=396095
Zinc plated RTP Cross drilled, slotted rotors, front and rear $200
Axxis/PBR Ultimate pads $100 F/R
F/R techna-FIT Stainless steel brake lines $85
$385, not bad for a full setup...
Old Nov 8, 2006 | 05:39 PM
akaxmrxhammer's Avatar
i have a set of axxis/pbr ultimate pads F/R and ss brake lines available if interested.. pm me...
Old Nov 8, 2006 | 05:49 PM
I VIK I's Avatar
OEM and you wont have a single problem...
Old Nov 9, 2006 | 01:21 PM
vir420's Avatar
JSmith, you got any squeak, and how much do you drive, and also...do alot of high speed breaking or not? And the part that says Nissan on it, how'd you get that done?
Hammer...hit me on the PM with a price, only if both are new...
Old Nov 9, 2006 | 01:31 PM
jsmithsole's Avatar
*moderator*
No squeaks ever. I drive 50 miles a day at least...yes I would say a ot of high speed braking as I tend to drive like a tard most of the time!
Those are decals, I painted the stock calipers and ordered the stickers through a link on this site, I'll have to track it down again...
Old Nov 9, 2006 | 03:31 PM
erasat's Avatar
My Axxis Deluxe are squeaking since day 2, I was having some heavy noise with OEM in the morning, just when rotors were cold, so I decided to replace them prematurely, now with the Axxis, the noise was gone.
BUT I'm really getting tired of the annoying noise, I always replace Pads long before they need to be replace (First one at 15,000) so I still have my OEM in there and I have been thinking on putting back them. Still don't know what to do.
Old Nov 9, 2006 | 07:36 PM
JohnnyBlaze's Avatar
STAY AWAY FROM AXXIS CERAMIC-PRO, I've had them for about 18k miles. They have good stopping power but the squeal at low speeds ,25 is ridiculous. I'm going back to OEM next week. BTW OEM pads are made by Akebono, but you won't find them in on-line part stores under Akebono. Apparently they make the pads for Nissan/Infiniti models as Nissan OEM. Just like Boge/sachs makes the struts. But you will never find the struts sold as such. Hope this helps.
Old Nov 9, 2006 | 07:53 PM
MaxFan's Avatar
I got Akebono ceramic pads on my Max and Pathfinder currently. You can buy as many as you wish from tirerack.com. It's very quiet and virtually no dust. After 21Kmiles on my Max, I still got about 3/4 left. Yeah, this is the longest without warped rotors for me (OEM pads did that with 19Kmiles, Axxis pads+drilled-slotted rotors lasted 2Kmiles). The OEM rotors are in now with the Akebono.
Old Nov 9, 2006 | 09:27 PM
pm sent......
Old Nov 13, 2006 | 05:54 PM
pirates's Avatar
I'm looking at buying a used 2004 Max. What should I look for when inspecting the car?
I have already test driven it and there is no vibration when braking, even at highway speeds (perhaps in the meantime, but who knows down the road).
Would replacing the pads/rotors be a good idea to prevent the common problems?
Old Nov 13, 2006 | 06:08 PM
I just bought my '04 used about 7 months ago. I'd check the CV boots for any leaks - look for any grease spewed around that area. I would check the brakes to see if they are low, but wouldn't replace them unless needed. It might be a good idea to have a professional of your choice look at the car. Worst case you might have some negotiating points for lowering the price. Good luck.
Old Nov 13, 2006 | 06:26 PM
!PrjctMax!'s Avatar
Tire wear/CRACKS in the SIDEWALLS
Brakes
Shimmys at around 40-60mph
CVT boots
Thudding from front left/right when going over bumps (struts)
Leaks in the trunk
Proper functionality of all center console buttons
ALL fluid levels
and that's all that I could think of
Old Nov 13, 2006 | 06:34 PM
Brakes
CVT boots
Leaks in the trunk
ALL fluid levels
Good points. My ATF was kind of low, so definitely check that too.
Old Nov 13, 2006 | 06:35 PM
!PrjctMax!'s Avatar
ATF for 5spd=Matic D !ONLY! just wanna put that out there
Apr 16, 2020 05:15 AM
NmexMAX
May 23, 2016 07:38 PM
trsandrew
Oct 25, 2015 02:47 PM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
