Skunk2 IM Spacer
Old Nov 12, 2006 | 07:24 PM
eK9aT10pSi's Avatar
Skunk2 IM Spacer
Just trying to do some reading up on this. the G and Z guys have had good results with this so i thought about this mod for the max. the install [i think] wont be a problem. would the benefits [more or less] be the same. i talked to JoTech [local shop] and they said that you would prolly have to swap the IM from a g or z. ideas?
Old Nov 12, 2006 | 07:26 PM
!PrjctMax!'s Avatar
all i know is that a buddy of mine with an rsx had one of these spacers installed and had a 5hp gain...or so they say
Old Nov 12, 2006 | 07:30 PM
eK9aT10pSi's Avatar
cool, they state that this gives around 10whp [im thinkin 5-8whp]
Old Nov 12, 2006 | 07:33 PM
!PrjctMax!'s Avatar
This'll be cool but I'd want the FSTB and the spacer w/o rubbing issues
Old Nov 12, 2006 | 07:37 PM
!PrjctMax!'s Avatar
holly s*** $225!? lol didn't notice that before
Old Nov 12, 2006 | 07:41 PM
AllBlackMax's Avatar
aka The Doom Ship
Well! Looks like I have a clone. Good to know there's another 6th Gen in the area.
You need to come out to the car meet Monday nights on the corner of Preston and 121 in the Circuit City parking lot. Probaby approx. 600 cars out there!
Old Nov 12, 2006 | 07:43 PM
aka The Doom Ship
And keep bugging Jotech, let them know us 6th Gen'ers are out there.
Old Nov 12, 2006 | 07:52 PM
Nissan 6's Avatar
Will there be hood clearance problems if you swap a z im onto 6th gen??
Old Nov 12, 2006 | 08:16 PM
aka The Doom Ship
Jotech is right becaue the spacer fits in between the upper and lower portions of the plenum. It's a totally different shape. Now I know someone installed a 350Z IM on to a 4th Gen, could possibly be made to work with ours.
Old Nov 12, 2006 | 08:37 PM
eK9aT10pSi's Avatar
allblackmax, you were the one with the header install @ their shop, right? i would love to see that in person. ive heard about the CC meets. i used to go but stopped because back in my honda days, at one of the meets in plano, some mexicans were doing some **** when i had my hood popped. cant trust anyone these days, thats why i am reluctant to go. i had my first turbo'd civic stolen from collin creek mall by 3 mexicans caught on tape when i worked at sears. i was really cautious about my 2nd one and when i turned 21, said **** it and sold it. and now, nissan power!
Old Nov 12, 2006 | 08:49 PM
aka The Doom Ship
Yeah that's me. You should come out man. Frisco po-po is out there for crowd control. Plus, there's gonna be at least 4 or 5 Maxes out there and we stay close to our cars. I know what you mean though, I don't trust to walk away with my hood open either. I usually pop the hood, maybe rev the engine a couple times then shut it down. I'll be out there this Monday, come check us out.
Old Nov 13, 2006 | 07:01 AM
NmexMAX's Avatar
dot dot dot ...
So who's going to try the ZIM on a 6th gen 1st?
Old Nov 13, 2006 | 09:57 AM
!PrjctMax!'s Avatar
how much are they?
Old Nov 13, 2006 | 12:03 PM
NmexMAX's Avatar
dot dot dot ...
www.car-part.com $200-$600
It will take some modifying though.
Old Feb 10, 2007 | 11:58 PM
!PrjctMax!'s Avatar
old thread, but I was wondering if anyone has done either the IM spacer or the 350z IM...?
Old Feb 11, 2007 | 12:08 AM
steven88's Avatar
Need A Light?
yeah vsamoylov did the 350z install...cehck out his threads
Old Feb 11, 2007 | 07:45 AM
!PrjctMax!'s Avatar
edit: nvm got it!
Old Feb 11, 2007 | 10:37 AM
eK9aT10pSi's Avatar
wow, i havent seen my thread in a while, i am still interested. i searched for a while but ran out of leads...
dan, did u find some useful info?
Old Feb 11, 2007 | 10:39 AM
RidinDirty's Avatar
Can someone tell me what an IM Spacer is and what it does?
Old Feb 11, 2007 | 10:48 AM
NmexMAX's Avatar
dot dot dot ...
Unless you have a Z33 IM, a spacer wont do anything.
Old Feb 11, 2007 | 01:43 PM
CanadianMoFo's Avatar
I heard it was not likely to work as our intakes are different from the 350Z. I asked a couple years back. Maybe things are different now.
CM
Old Feb 11, 2007 | 02:35 PM
!PrjctMax!'s Avatar
main thing is that it would absorb a little more heat and would equal COLDER air going through the manifold...cold=better
Old Feb 11, 2007 | 02:36 PM
!PrjctMax!'s Avatar
http://forums.maxima.org/showthread.php?t=460317 is what I got on it
Old Feb 11, 2007 | 06:38 PM
NmexMAX's Avatar
dot dot dot ...
Phenolic spacer works differently than the Skunk2 piece.
Phenolic absorbs heat
Skunk2 for RWD VQ35 adds space to let more air into the front 2 cyls.
Old Feb 11, 2007 | 06:45 PM
!PrjctMax!'s Avatar
that works too! I just learned one more thing from you
Old Feb 11, 2007 | 10:28 PM
Nissan 6's Avatar
Old Feb 12, 2007 | 08:50 AM
eK9aT10pSi's Avatar
i would think it would dissapate more heat would equal COLDER air going through the manifold
Old Feb 12, 2007 | 10:02 AM
NmexMAX's Avatar
dot dot dot ...
What exactly do you refer to as COLD air?
Old Feb 12, 2007 | 10:42 AM
DeusExMaxima's Avatar
"Cold" means cooler than fully heated air from not using a spacer. Its not cold like air conditioned air. For example, if the air going through the manifold without the spacer is 250 degrees, then the use of a spacer may decrease the temperature to 220 degrees. A 30 degree temperature results in about a 3 hp gain (1 hp for every 10 degrees).
Old Feb 12, 2007 | 11:21 AM
!PrjctMax!'s Avatar
That's pretty much was I was referring to...I guess I just worded it stupidly?
Old Feb 12, 2007 | 12:09 PM
NmexMAX's Avatar
dot dot dot ...
There is a difference between the skunk2 plenum spacer and phenolic spacers(more like thermal gaskets).
There are a handful of members that have thermal gaskets for their FWD VQ35's. But no one will benefit from an actual spacer (as far as what the definition means, adding space) that has a FWD IM.
We may or may not benefit from thermal gaskets. The gains would probably be minimal and non noticeable in a dynoing situation. A TB coolant by-pass tube would probably do/have the same affect as thermal gaskets.
Old Feb 12, 2007 | 01:02 PM
xoomer.com's Avatar
I Donate! Why Don't You?
Thats why I am planning to insulate my fujita this summer or as soon as I find some reflective insulating material in a tape form.
Old Feb 12, 2007 | 06:24 PM
kamski's Avatar
.org extraordinaire
Errrr......... Home Depot insulating pipe wrap. Works like a charm.
Kamski
Old Feb 12, 2007 | 06:26 PM
xoomer.com's Avatar
Kamski
Thanks Kamski, that might be exactly what I am lookin' for
Old Feb 12, 2007 | 07:40 PM
!PrjctMax!'s Avatar
Kamski
"kurwa polak potrawi!!!" -xoomer-
Old Feb 12, 2007 | 11:20 PM
Nissan 6's Avatar
o kurwa tak to kurwa jest,,,,y kurwa tak bedzie.
Old Feb 13, 2007 | 06:27 AM
xoomer.com's Avatar
alez panowie co to za slownictwo ROFL
Old Feb 13, 2007 | 11:44 AM
NmexMAX's Avatar
dot dot dot ...
Last night my IAT was 40*C, while my ECT was 85*C, parked.
The IAT is located in the MAF, so.. I highly doubt you'll be making much difference even with the thermal gaskets.
Old Feb 13, 2007 | 12:01 PM
xoomer.com's Avatar
^^^ IAT ???, ECT ??? How did you measure?
Old Feb 13, 2007 | 04:16 PM
eK9aT10pSi's Avatar
kam, post pix of ur intake with the wrap please!
