20x10 rims?
20x10 rims?
i'm thinking of getting a set of rims that are available in 20x8.5 and 20x10...i was thinking of getting 2x 8.5 in the front and 2x 10 in the back...will they fit in the back? what size tires should i be looking at for that? thanks!
I have 20x8.5's and I needed to roll my fenders to fit them, I had it lowered about an inch in a half, but i just put the factory springs on and it does fine now. It would SLIGHTLY cut my tire each time I would hit a bump, it was just taking Toyo 555 off of the tire. I couldn't imagine bottoming out on a 10 inch wide wheel. But good luck. I am not sure about the 6th gen's, but I could run 20x10's on mine without lowering it, no problems, no need for rolled fenders, but if you are going to lower it at all, you will have too. Good luck. Post up pictures.
One thing to consider is that if you go with a staggered look, you will only be able to rotate your tires left to right. And with tires nowadays being more and more directional, you will probably NOT be able to rotate your tires at all. Just a consideration. Plus going staggered is only for looks IMO. No real benefits on the maxima to go 20x10 in the back.
0m3nc0w
Sep 11, 2015 05:21 PM
