What octane for '04???
I have been using Citgo. Always. I used Shell in Naperville/oakbrook (Chicago) area recently and the mileage dropped by about 3-4 miles per gallon. Then switched to BP(Amoco). Still it was low compared to the Citgo.
Not much difference in performance. Still got enough power in the wheels.
My other car (Civic) hates Shell too.
Originally Posted by shawndon
I'm sure you spent a nice amount on you max so treat it right.
Your Max was designed to provide maximum performance burning premium and to perform adequately burning regular. The Max is not a person, but a machine. It will perform based on how you ask it to perform. If you don't call for maximum performance (WOT), then you don't need the gasoline grade that costs more but will provide maximum performance when the Max is floored. Regular will work well in most circumstances.
If you abuse you Max by sloppily driving it hard, you can damage it. You can not damage the Max by burning regular (provided you do not get knocking when the engine is under load).
There is so much bad information out there about gasoline octane -- and no one wants to learn the facts -- they know what they know -- don't confuse them with facts. If you do want the facts -- go here:
http://forums.maxima.org/showthread.php?t=396716
So for those of us who just drive our Maxes casually everyday, regular unleaded or 87 octane is fine?
I like to treat my max about every 6 weeks to premium, and 'open it up' just to burn off crap in the engine. Have not had any problems or knocking with the engine.
According to Honda, their 3.5 liter Odyssey motor produces 244 hp on premium fuel and 211 hp on regular fuel. I’m sure Nissan’s technology is similar. The car’s computer will adjust its settings to run on lower octane fuel. You can do it, but you lose power and mileage.
Hmmm, this is interesting. I welcome a difference of opinion. I was under the impression that higher octane fuel released more heat than lower octane fuel. Since our motors are heat transfer engines, more heat generates more power.
To maintain a certain speed, for example 60 mph, let’s assume the engine must produce 15 horsepower. To produce the required heat to generate 15 horsepower, it might take 9 drops of 87 octane fuel (per cylinder, per rpm) and only 8 drops 93 octane fuel. It takes more regular fuel because each drop releases less heat. The only way to generate the required amount of heat (power) with 87 octane fuel is to burn more fuel in the same timeframe. This relationship explains why fuel mileage decreases with lower octane fuel. This is especially true if the car’s computer can adjust its settings to take advantage of the higher octane fuel’s extra power.
Hmmm, this is interesting. I welcome a difference of opinion. I was under the impression that higher octane fuel released more heat than lower octane fuel. Since our motors are heat transfer engines, more heat generates more power..
Now that most gasolines are comingled (stored together in the same storage tank), there are certain minimum specifications that must be met by all suppliers of that grade of gasoline (usually set by a pipeline company). Volitility and octane are among the specs that must be met. Energy content is not.
You are confusing gasoline energy content with gasoline octane level. What premium gasoline does do is burn less easily than regular -- the higher octane is a measure of this resistance to burning. This reduces the possibility of premium pre-igniting before the spark fires in an engine. But the measure of octane is not a measure of energy content. And there are also some high-octane blending components that are lighter and thus contain less energy. A good example of this is ethanol, which has good octane characteristics but has less energy than even the poorest octane grade of pure gasoline.
Bottom line, you can't easily generalize about gasoline energy content.
Oh no, not another octane thread!!! I have put nothing but watered-down 91 Cali gas in my car, except the occasional 100 octane 76 gas. My car has ECU reflash and I noticed that there was some pinging at low end. My car seems to respond well to the splash of 100 although its ungodly expensive. When I turn off my traction control, the spark is not retarded and the car really goes. I have come to the realization that there are 3 topics that should never be discussed among family and friends: politics, religion, and fuel octane.
Originally Posted by DeusExMaxima
Oh no, not another octane thread!!!.
I've said many times that if you have modded the control system in your Max, you should probably stick to premium because you have over-ridden the settings that the Nissan engineers set to allow consumption of regular at less than maximum (but generally acceptable) preformance levels for this car.
The 100 research octane racing fuel you are paying throught the nose for is only about 95 (R+M)/2 octane when compared to the 91 octane you are buying in CA gas stations. I'm told that CA set 91 as the maximum limit for commercial grade premium gasoline -- not certain exacty why they did this, but reportedly for environmental reasons.
I know you are using a phrase, but there is no (or very very little) water in the 91 octane you are buying in CA. Water and gasoline don't easily mix (unless there is something like ethanol present).
its a phrase we use here in Cali because its understood we get different formulas depending on the season and some formulas are reportedly lesser quality.
JoshG
51
Sep 21, 2015 10:41 PM
sdotcarter
Sep 2, 2015 09:53 PM
Team STILLEN
Aug 10, 2015 04:29 PM
