Automatic Transmission Fluid flush
Guys,
I know this probably may have been covered in the fluid threads but for the most part, they relate to older gens...
I'm planning to do a complete tranny flush at 38k. I've been reading that the dexron/mercons are pretty good. Should I go with these or stick with nissan's factory ATFs?
Are 9 qts suffoce?
Are 9 qts suffoce?
Originally Posted by NiZMo1o1
sigh!........
sounded like a trick question huh?
I went to flush mine last week, hit 30k, and both Nissan Dealerships told me not to Flush/Drain Refill the tranny. They told me that it is not necessary until 100k. I had never heard of that but that is what they said.
I called them when I couldn't find it in the service booklet.
Please tell me you have good news. Should I, like the original poster, be concerned with this?
Also, thanks guys for your info on this matter.
For the **** people it wouldn't hurt to do it at these low miles. I've heard that once you start nearing 100k you SHOULD NOT do anything with the trans fluid because it has already grown attached and accustomed to the particles and metals or what not...this is what many have told me, but you SHOULD do it at lower mileage.
The 6th gen Owner's Manual calls for changing the auto tranny fluid at 105,000 miles if it has not already been changed.
BUT
It also says the fluid should be checked every 15,000 miles, and if discolored, polluted, burnt-smelling, or otherwise questionable, it should be changed.
For normal driving, there should be no problem making the first change at 60,000. But, being semi-****, I plan to change around 45,000. Truly **** folks will change at 30,000. With normal driving, changing before 30,000 is simply throwing money to the wind.
I had no auto tranny problems in 206,000 miles with my 1985 Maxima, and I changed the tranny fluid only twice - at 75,000 and 150,000 miles.
I would suggest those driving under difficult conditions (steep grades, pulling trailer, dusty conditions, extreme heat or cold, lots of city driving, lots of very high speed driving, lots of brisk accelleration, etc) to check more often than every 15,000 miles, and consider changing the fluid at around 20,000 to 30,000 miles.
For everybody else, under normal conditions, the fluid should easily do fine for 60,000 miles, although changing a little sooner may bring many folks peace of mind.
And be careful which fluid you use. The Owner's Manual says the 6th gen tranny cannot use some of the normal fluids. Don't blow your five year power train warranty by putting the wrong fluid in.
BUT
Well im certianly not waiting til I hit that much , im at 55K now and Ive had the TCU reprogram because im having the shift shock problem..
The reprogramming help like the first 2 weeks and from time to time the shifts are getting harder. Im going to flush it out maybe next week.
I cant say stealership cause my friends all work back there and I just buy the oil and a 6 pack of Guiness and they are happy.
Originally Posted by normkit108
i live like 10 blocks away from a nissan service center, i was hoping to avoid them because they always charge an arm and let over there..
The color and smell of auto trannie fluid are key indicators. Look at and smell it now (when your Max is relatively new) so that you can notice a difference when it starts to get either dark or smelly. The only problem with changing your fluid too soon is that it wastes money and resources -- you can have bigger problems if you run the fluid too long. I think light's recommendation of about 60 K miles is about right unless you notice a color or smell problem before that or if your driving is in extremen conditions (see his list).
Remember, if you do a drain and refill you are changing less than half of the trannie fluid. A trannie flush gets more of the old fluid replaced.
Finally, you have to do some searching of the stickies in the Fluids & Lubes section of this site to find info that applies to 6th Gen Maximas, but the good advice there is worth the search -- it was for me and my manual trannie.
I did mine last week at 22k miles; not a full flushed, I just drained a few quarts. The oil was dirty and smelled burnt. So I think I will do a full flushed in a few weeks. Does the 5AT really take 12-14 quarts?
I just had a tranny flush at 30K miles and I took it to a transmission service center, I ensured they used Genuine Nissan 5AT Type "K" (The Nissan Owners Manual has a big warning about using anything other than Genuine Nissan), cost was about $9.50 per qt. The tech dropped the pan, cleaned the screen, pan, replaced the O-ring, and gasket, bolts were still in great condition (drain/pan bolts) so they were reused.
The tech and I agreed that a full flush was not required, actually they recommend leaving some of the old AT Fluid so we only replaced 5 qts. If anything, never get a transmission flush using a power flush machine because they do not properly clean the pan and screen which is where all the particles settle. My cost was $125. and the guy gave me back 3 qts because initially he had ordered 8.
Overall zero problems and smooth shifts, if anything DO NOT skimp on your tranny flush, it is one of the most costliest repairs you can have if not treated right...
Originally Posted by 4MySwee
RH, you're having that with only 22k on your car? That really early is it not? Im at 33k now.
I don't it drive much, but I drive relatively hard.
Originally Posted by chernmax
...The tech dropped the pan, cleaned the screen, pan, replaced the O-ring, and gasket, bolts were still in great condition (drain/pan bolts) so they were reused...
i was actually going to take my car to get the tranny fluid replaced because i checked it the other day and its burnt. i reaplaced it once at 30k and i am at 56k now. i drive my car hard but isn't it too soon to have to replace again. right after they had replaced the tranny fluid i checked it and it was still dirty. i am guessing that it is dirty again because last time they just did a drain and refill and not all the oil comes out. my mechanic said in order to fully flush the max is to drain and refill over and over until clean. is this true? obviuosly this way would be very expensive. what dod you guys think?
I have a friend who says he will take off the pan and then run the engine in gear (with brakes on) to have the trannie pump push out most of the old fluid. He says that this takes two people because you don't want to run the trannie when it is dry. One person watches and when the fluid flow goes way down this person yells to turn off the engine.
With the trannie dipstick you can see some of the fluid on the stick. Smell it too. You should do this when the car is new so you know what new fluid looks and smells like.
I don't have these problems with the 6-speed. I just open the drain and the fill bolts and drain it overnight (I've done it once and with the proper tools it's easy).
Did my tranny flush last month at 17K (city driving). Needed 3 qts for my 5AT. Sent a sample to Blackstone Lab and they said that my timing was correct. It did not have much life left. I change it every two years. Cheap insurance.
I do provide IT services to a local transmission parts wholesaler and while normally just mind my own business, do my thing and get out, today I decided to ask some questions.
Well, the guy told me that doing tranny flush at low mileage will replace the fluid which is just fine. Once you get into high mileage cases changing the fluid he says, will do more damage than good. He says lots of people change their fluid and week later the tranny is dead. (Reminds me of a recent thread on NYCMaximas) He says that there are particles in the used fluid that provide traction to internal parts and once you flush it out the worn parts in the tranny will no longer work as designed. In addition, the new fluid will bring new detergents that are part of the mix that will further clean these parts and they will esentially start sliping. He works in the industry for past 20 years and says if you don't change your fluid at early stage, don't change it at all.
BTW. The whole conversation started when I asked about a tranny cooler and whether it would do anything for the car. He says it will not save the tranny or help it and that our trannies are on the "bad list". He said that they sell whole bunch of parts for these trannies and same parts are used in Volvo trannies. I was in disbelieve untill 5 minutes into the conversation a guy walks in to pickup valve body, gaskets and some other crop I can't even name for the 2004 nissan max (5speed, auto). I was like damn dude, you really made my day. NOT!!!!
So what would be considered low mileage for a tranny flush, 30k, 60k? I had a 96 eclipse that I just sold. I did a flush on it at 90k back in 02 and it had 140k when I sold it last week. I Never had any problems because of the trany flush.
Recently a guy at NYCMaximas went to Jiffy Lube to had a tranny flush. Two weeks later the tranny went dead but the problems started just day(s) after he had it done.
Originally Posted by xoomer.com
Based on my conversation with the guy I assume its good to flush it at around 30K to get rid of the initial deposits from breaking-in. After that it might do more damage then good.
So what would be considered low mileage for a tranny flush, 30k, 60k? .
Do you have the FULL TRANNY FLUSH done at your Nissan dealership, or do you just drain and fill yourself?
Myself. I don't like any type of power flush. That's just me. I take the plug out and flush whatever comes out, even if the converter still holds a few quarts. The tranny operates at such high temperature I prefer to change the oil more often.
The filter is replacable and once you remove the pan you have to replace the gasket too. I can check on wholesale prices if anyone is interested....
