My MPG is at 8.8:(
Old Mar 17, 2007 | 11:49 AM
Kashanova's Avatar
My MPG is at 8.8:(
Any ideas why? I went to the dealer they did a diagnostic and found nothing
Old Mar 17, 2007 | 11:53 AM
BadBlackMaxSL's Avatar
Do you have a hole in your gas tank?
Did you reset the trip computer? How many miles are you getting per tank? Don't go by the computer next time. At 9 MPG you would only get 180 miles on a tank of gas, I couldn't imagine that really happening.
Old Mar 17, 2007 | 12:45 PM
Nissan 6's Avatar
wow..........first off are you driving a ferrari? or your maxima?
hehe just pullin your leg.
Old Mar 17, 2007 | 01:03 PM
I VIK I's Avatar
actually I get about 250 per tank. and thats using 93 gas and Cruise control. Im not happy with it....
Old Mar 17, 2007 | 02:01 PM
4MySwee's Avatar
Is it remotely possible that the MAF is going? Even when I punch it, mine doesn't tank like that. I know an MAF would throw a code, but this seems odd. Is your Service Engine Soon light working? I mean, does it light up when you put your ignition to the accessories position?
Old Mar 17, 2007 | 02:15 PM
Kashanova's Avatar
my service engine does work it turned on recently but that was cause i put the intake before that i was still doing horrible mpg numbers, i feel like im driving a hummer i put 30 bucks of gas next thing you know im at half and im like WTF this is from going from a b14 sentra that did 37mpg to this i don't really know whats going on
Old Mar 17, 2007 | 02:19 PM
NmexMAX's Avatar
dot dot dot ...
What is the code associated with the MIL?
Old Mar 17, 2007 | 02:27 PM
Kashanova's Avatar
i have no clue what your asking lol, this is my first max and just got it like 2 weeks ago, so mind me yes im a max noob
Old Mar 17, 2007 | 02:29 PM
NmexMAX's Avatar
dot dot dot ...
What made the engine light come up in the 1st place.
Old Mar 17, 2007 | 02:31 PM
Kashanova's Avatar
The Fujita CAI, but the MPG was horrid before that
Old Mar 17, 2007 | 02:32 PM
NmexMAX's Avatar
dot dot dot ...
what code prompted the light?
Old Mar 17, 2007 | 02:35 PM
Kashanova's Avatar
how do i know what the code is?
Old Mar 17, 2007 | 02:37 PM
NmexMAX's Avatar
dot dot dot ...
Get it checked at autozone, the dealer or buy a scantool.
Old Mar 17, 2007 | 02:42 PM
04BlackMaxx's Avatar
Is it ACTUALLY 8.8 based on the mileage traveled between fill ups divided by the gallons put in the tank for each fill up, or are you getting this number from the computer alone?
Old Mar 17, 2007 | 02:46 PM
4MySwee's Avatar
Kashanova, we will gladly bear with you. Don't sweat it, we have all been newbies before. No sweat.
Gotta take this thing, one step at a time. When you bought the car, was there a carfax report pulled on it? Has your local dealership given you a printout of all that has been done to your car? I'm asking because you say you bought it like this right? If so, there was something wrong beforehand, and this might allow you some recourse.
How many miles are on it? What year....etc....
There are a few things on these cars that are computerized and can cause this. What we would do is basically a process of elimination.
The first step (As suggested already) is to take your car to an Autozone and tell them you need 'codes pulled'. There is no charge for this generally. They will take a device out to your car and read off their computers what codes your car has thrown since it was last cleaned out. Bring those codes back here to us. They will be able to tell us what is happening under the hood. Make sure when you go to Autozone, to have a pen and paper handy for the codes.
Swee
Old Mar 17, 2007 | 02:58 PM
Kashanova's Avatar
i got an 2004 max 5AT
I went to the dealer already and they said they didn't detech anything, i even reseted the mpg calculator and it would be low, im going to try autozone to see whats going on cause the gas is killing me i was expecting 19mpg city or so
Old Mar 17, 2007 | 03:56 PM
kcryan's Avatar
neighbor is stealing your gas, beat his *** up, problem solved
Old Mar 17, 2007 | 04:06 PM
kamski's Avatar
.org extraordinaire
That could only happen in rochester. I would check my o2 sensors and my MAF first and foremost, make sure you have no vacum leaks and that you dont smell a strong odour of gas coming out of the exhaust. It shouldnt smell at all.
Next check your gas cap and make sure your seal is on nice and tight.
If that dont help, go to a shop that does e-testing. Have them check your o2 emissions, this should give them a rough idea of what is causing the gas burn. 8.8mpg is friggin HORRID.
Alos make sure you e-brake isnt frozen in the engaged position, even though the light might not be ont he e-brake wire could still be jammed.
Good Luck amigo,
Kamski
Old Mar 17, 2007 | 05:29 PM
Pronto's Avatar
There's no way you could miss the smell of burning brakes if the ebrake was stuck on...
How are you determining the mileage? Do it manually and compare it to the computer if that's what your using. Find out what code was thrown.
Old Mar 17, 2007 | 05:31 PM
MisterSparkle's Avatar
are you driving crazy??? and plus...i'm getting about 300+ per tank...are you tap shifting...tap shifting i've noticed eats up a lot of gas.
Old Mar 18, 2007 | 09:39 AM
Fastmax05's Avatar
"Ok,Whats next?!?!"
by tap shifting you mean ...tiptronick?
I find that when i want to hear the roar of the fujita i get around 17 mpg ..
wheni drive nice on it i get around 20.5 on the road
Old Mar 18, 2007 | 02:23 PM
Omarvelous's Avatar
wow....I easily go to nyc from dc on half a tank. Cruising at 75ish...good luck with this.
Old Mar 18, 2007 | 05:16 PM
Im sorry, but im still skeptical without more info...
Old Mar 18, 2007 | 05:18 PM
aria's Avatar
i gat around 14 driving mixed driving but some times i wot it.
Old Mar 19, 2007 | 07:13 PM
Banginbeats3's Avatar
I was driving long distance to work every day coasting on back roads getting consistently 290-315 miles per tank. Have since moved back into the city and do all city driving, now only getting 190-215 per tank. I havent checked my miles/gal. yet...anyways point being reconsider your driving habits, conditions, etc..on top of other potential problems
Old Mar 19, 2007 | 07:26 PM
madmik's Avatar
This winter my average was about 12 mpg in the city. I would say that at 9 mpg you must be having quite some fun. If its not your driving, then something is robbing a lot of power from your engine. Are you running the rear defrost a lot, idling a lot to warm up the car, or run the A/C (yes, the A/C has a tendency to kick in on some settings)?
Old Mar 20, 2007 | 12:20 AM
DRU1's Avatar
I actually get 8.9 mpg....but i do live in Alaska and have autostart on the car...and i live in a small town so there isnt much hwy drivin going on....i will really see what its like when i move to Cali. in 2 months
Yea like madmik said when you change your a/c mode from floor to vent or whatever it always kicks the a/c back on...i always have to turn it off
But yea ive been really pissed with the miles that i get, but then again this place is so small that i still dont fill up but every two weeks
Old Mar 20, 2007 | 11:15 AM
Stevied23's Avatar
I just bought an '06 max. yesterday and I live in ND. If i only get 9-10 in town i'll be bringing it back
Old Mar 21, 2007 | 05:15 PM
Kashanova's Avatar
yeah i really dont know whats going on each day i drive to work it gets lower its like 8.3 right now and like i said the dealer did dianogstic and saw nothing
Old Apr 8, 2007 | 03:11 PM
Kashanova's Avatar
just in case no one believed me
Old Apr 8, 2007 | 03:14 PM
NmexMAX's Avatar
dot dot dot ...
It's common sense not to believe that trip computer. What's your actual calculated MPG?
Old Apr 8, 2007 | 03:16 PM
Kashanova's Avatar
well i haven't calculated for myself i just look at the gas meter on the side, and it seems to go down quickly
Old Apr 8, 2007 | 03:18 PM
NmexMAX's Avatar
dot dot dot ...
Calculate and confirm.
Old Apr 8, 2007 | 03:20 PM
Kashanova's Avatar
I wouldn't know how to calcuate that
Old Apr 8, 2007 | 03:21 PM
Hilbe's Avatar
You sure there isn't a leak somewhere?
Old Apr 8, 2007 | 03:22 PM
NmexMAX's Avatar
dot dot dot ...
Miles per gallon.
Miles / gallons used.
Rest your trip computer, go through one tank, fill up, record mileage from trip set at fill-up, divide that over the #'s of gallons you pumped.
Miles / Gallon
Old Apr 8, 2007 | 03:26 PM
Kashanova's Avatar
I don't know. I took it to the dealer and their diagnostics found nothing wrong with it
Old Apr 8, 2007 | 03:31 PM
NmexMAX's Avatar
dot dot dot ...
The trip computer uses feedback from the MAF and o2 sensors, so a leak wouldn't affect it.
Calculate it the way I showed you and then post back.
Old Apr 8, 2007 | 03:36 PM
Old Apr 8, 2007 | 05:17 PM
I VIK I's Avatar
Originally Posted by 04BlackMaxx
Hey, Common thats not funny, The guy is worried has a valid problem, we should all help? not laugh
