Check Service Engine Light
Old Jun 1, 2007 | 05:15 PM
Elimackman's Avatar
I just finished installing a Fujita Intake. what a pain in the ***! The check engine light appeared. How do I turn it off? I'm sorry if this is a repeat.
Old Jun 1, 2007 | 06:26 PM
!PrjctMax!'s Avatar
I had the same crap! Did you turn the motor on when the intake assembly was off? If so then just drive for a week or so and it'll relearn itself and turn off.
Make sure that your MAF is plugged in correctly as well.
If all of that is fine and your tubing is alright and you don't have any hesitation from the motor then just drive it and in about a week or so it'll turn off by itself (that was a lot of "ands!")
Old Jun 1, 2007 | 06:35 PM
4MySwee's Avatar
Did you disconnect your battery first?
Also, I agree with Prjct.
The light shouldn't have come on if you read and followed all instructions to the 't'. I know it is pretty simple to figure out, but these stinkin' sensors (MAF) are picky as all get out. The directions told how to bypass this directly. (At least the intake for the 04-06 did).
Whatever the cause, driving it around for a bit will turn it off.
Old Jun 1, 2007 | 07:50 PM
Elimackman's Avatar
No didn't unplug the battery nor start the car. I followed the directions to the T. I guess I'll just wait and see if the light turns off. Hopefully the car won't die on me. Thanks.
Old Jun 2, 2007 | 03:40 AM
Ritz's Avatar
any other mods?
I'm guessing the MAF is backwards.
Old Jun 2, 2007 | 04:59 PM
NmexMAX's Avatar
dot dot dot ...
You can reset it yourself.
http://forums.maxima.org/showthread....ight=reset+ECU
Or, take it to AutoZone and have them read the codes for free. This will help pinpoint the 'problem'
Another possibility, yes. Check for the flow arrow and verify it's pointing in the correct direction.
Old Jun 3, 2007 | 03:28 PM
madmik's Avatar
Verify that the clamps are tight between the throttle body and the MAF. Unmetered air getting in after the MAF will create a lean condition.
Unsure if MAF is backward? Check my MAF sensor picture below. This is the side facing the throttle body. It has no opening in the sensor (mine has 3 small holes to modify A/F mix). The side looking at the air filter will have a 1/4" X 1/4" opening and a tiny wire going across.
According to the service manual, for many cases, the engine has to cycle from cold (~ under 150F.) to normal temp. a few times to reset engine light.
Old Jun 3, 2007 | 07:02 PM
Elimackman's Avatar
I'm not sure you can install the MAF opposite... The screws won't match up... HELP, looks weird with the service engine soon light on!!
Old Jun 4, 2007 | 09:01 AM
NmexMAX's Avatar
dot dot dot ...
http://forums.maxima.org/showpost.ph...90&postcount=6
Old Jun 4, 2007 | 09:07 AM
chernmax's Avatar
Nations 1st 6th Gen Turbo
If you know someone with an OBD-II they can erase the code in less than a minute. Not disconnecting your battery is what normally causes this. You can also go to an Advanced Auto, Autobachs, pepboyz, etc and they can also do it for you for free, however I have heard some may not erase the code, last is do nothing and after your ECU relearns, it will go out on it's own within 2-3 days depending on how much you drive daily...
LOL, Oh and this has never happened before to anyone!!!
Old Jun 4, 2007 | 02:54 PM
Elimackman's Avatar
Thanks for the love. I took it to advance auto and they reset it. The codes all referred to sensors.
Old Jun 4, 2007 | 07:31 PM
NmexMAX's Avatar
dot dot dot ...
All codes are related to sensors. By any chance do you know which sensors they were?
Old Jun 4, 2007 | 07:47 PM
Elimackman's Avatar
I want to say 1/2 but I'm not sure if that makes any sense
Old Jun 4, 2007 | 07:48 PM
Elimackman's Avatar
1 and 2 sorry...
Old Jun 4, 2007 | 07:51 PM
NmexMAX's Avatar
dot dot dot ...
Bank 1 and Bank 2? Or bank 1, sensor 2? Do you know the actual code that was pulled?
in any case it's fixed for now.
CorollaULEV
30
Aug 9, 2021 08:11 PM
Justinmc760
Aug 23, 2015 03:10 AM
maxinout93
Aug 20, 2015 02:17 AM
Flores94
Aug 11, 2015 12:53 PM
bassmann
Aug 3, 2015 07:53 PM
