will these size rims fit?
Old Jun 11, 2007 | 03:42 AM
usmcbigguns's Avatar
Just went from having a 4th gen max to a 6th gen max so my knowledge on what size rims to get are a little lacking..... Friend of mine has a set of rims that are 18x8.5 from his honda that i am thinking of buying from him. Obviously 18's will fit but will a 8.5 wide be too wide?
Old Jun 11, 2007 | 11:43 AM
KCMAXX's Avatar
KC's FINEST
No...
Use the stickies, their your friend.
Old Jun 11, 2007 | 12:45 PM
Fastmax05's Avatar
"Ok,Whats next?!?!"
i thihk they are a diffrent offset
Old Jun 11, 2007 | 01:06 PM
KCMAXX's Avatar
KC's FINEST
Honda is the same pattern if it's an Accord V6. My answer was no, they are not too wide.
Old Jun 11, 2007 | 01:40 PM
xoomer.com's Avatar
I Donate! Why Don't You?
I have 9" wide rims but it all depends on offset. There is a guy here on the forum that has sickest looking 10.5" in the rear and with proper offset it works.
Old Jun 11, 2007 | 01:43 PM
ouzo99max's Avatar
Originally Posted by KCmaxx
No...
F Stickies.
Use an english book, THEY'RE your friendz
Old Jun 11, 2007 | 01:48 PM
KCMAXX's Avatar
KC's FINEST
Originally Posted by ouzo99max
F Stickies.
An english book huh..? Im sure you have one I could borrow.
Old Jun 11, 2007 | 02:08 PM
Fastmax05's Avatar
"Ok,Whats next?!?!"
hahahaha i love this ....
Old Jun 11, 2007 | 02:47 PM
KCMAXX's Avatar
KC's FINEST
Weak........
What Honda were the wheels from?
Old Jun 11, 2007 | 07:34 PM
spatel8600's Avatar
i dnt think they will fit
Old Jun 12, 2007 | 06:30 AM
Weak........
an accord, think a 2003
Old Jun 12, 2007 | 10:34 AM
04BlackMaxx's Avatar
114.3 bolt pattern is what you need, same on accord? I have18x8.5 w/ 35 offset, looks perfect to me
Old Jun 12, 2007 | 12:26 PM
MDS's Avatar
MDS
These are the statistics for a 2004-2007 Maxima rim:
Bolt Pattern - 114.3 mm
Offset - 35.0 mm
Center bore - 66.0 mm
Width - 7.5 Inches
I don’t know anything about Honda rims, but check the center bore measurement. The center bore measurement is really important. Even if the rims share the same bolt pattern, if the Honda’s center bore measurement is smaller than our Maxima’s center hub, the rim will not fit. If the center bore is larger than the Maxima’s center hub, the rim will fit but be “loose.” The rim may always be slightly off center with respect to the brake assembly. It also means the rim/tire’s weight will rest directly on the lugs, which can lead to bad vibrations and rim damage. (Actually, once the tire is on the ground the car’s weight rests on the rim. That weight needs to be on the rim’s center hub, not the rim’s lug nut holes.)
To ensure a proper fit, the center bore must be exactly 66.0 mm. If the Honda’s center bore is larger than 66.0mm, you may be able to purchase spacers to reduce the hole size to 66.0mm. A great source of info for this kind of stuff is the Tirerack. Good luck.
Old Jun 12, 2007 | 01:38 PM
KCMAXX's Avatar
KC's FINEST
My old 19's came from an Accord. They will fit...
Old Jun 15, 2007 | 01:56 PM
brio_max's Avatar
Learning English...
Anyone running with the Kosei K3? Would those rims fit the 6th gen, since their offset is 36mm 17" 7J...? Thanks in advance!
Old Jun 15, 2007 | 08:51 PM
MAX2DAMAX's Avatar
I just installed, 18x9 with 40/275s and 18x8 in the back, and they fit just fine with some extra space to spare, I think im doing 23ish offset
RIPTIDER
Wheels/Tires
Jan 31, 2016 07:39 AM
Luigi623
Sep 21, 2015 01:42 PM
mikeymouse1995
Sep 18, 2015 06:42 AM
meccanj98
Sep 17, 2015 08:28 AM
0m3nc0w
Sep 11, 2015 05:21 PM
