Anyone running a 350Z Boomslang Emanage Ultimate harness?
Old Jun 15, 2007 | 03:36 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
http://www.boomslang.us/ultimate.htm
You 6Gs are really lucky to share similar ECU connectors even wiring with the 350Z.
A buddy with a 6G wants an ECU, so I'm trying to talk him into a EU+Vmanage.
Old Jun 15, 2007 | 03:43 PM
IceY2K1's Avatar
Damn...looks like Greddy even makes one:
http://greddy.com/products/display/?...SubCategory=47
NIS 350Z (Z33) VQ35DE
02-+ N-13 Plug and Play Harness for the E-manage Ultimate.
Ignition Adapter 1 include, Diodes included on Ignition Harness. 15921505 190.00
Old Jun 15, 2007 | 03:49 PM
Jeff92se's Avatar
I'm needing a caw
I don't know how similar the newer maxima ecus are to the Z. I know the EARLY 2003 Gs had more in common to the maxima vs the 2003.5+ Gs and Zs.
I have an early version so if I want to run one, I have to be careful. I'm liking the UTEC but the EU can be had much cheaper
Old Jun 15, 2007 | 03:53 PM
SR20DEN's Avatar
VQ Wizard
I would now consider this
http://www.uprev.com/products/osiris_NI.html
Old Jun 15, 2007 | 03:58 PM
Jeff92se's Avatar
I'm needing a caw
I saw that too Matt. It's reflash type. Not sure if it suits your DIY tuner needs. But at least reflashes are no charge according to them. Nice not to have to send in the ecu everytime though. Cobb Tuning was supposed to offer something like this also. But I don't believe a releash date is soon. Also it only covers basic Nissan obdII vs Cipher's Nissan specific obdII diagnostics.
Old Jun 15, 2007 | 04:07 PM
IceY2K1's Avatar
Comparing 2003 350Z and 2005 Maxima FSMs, they are virtually the same as far as ECU pins.
Old Jun 15, 2007 | 04:08 PM
IceY2K1's Avatar
WOW...thanks.
Originally Posted by SR20DEN
Old Jun 15, 2007 | 04:14 PM
Jeff92se's Avatar
I'm needing a caw
I know for a fact that at least the early G ecu is diff than the rest. But I don't know if the early Z ecus are diff
Old Jun 15, 2007 | 04:16 PM
IceY2K1's Avatar
I know, but if the BS harness works on 03-06 350Z, it should work or be very very close for my buddies 2005 Maxima.
Guess I'm missing the point...
Old Jun 15, 2007 | 04:18 PM
IceY2K1's Avatar
Man we need someone to hack this, so we can modify maps ourselves.
Old Jun 15, 2007 | 04:34 PM
SR20DEN's Avatar
VQ Wizard
I haven't read enough into it but I was under the impression that was the point.
I would rather have access to program a Nissan ECU than to have a EU and a VM. I suppose $700 doesn't get you that ability.
Old Jun 15, 2007 | 04:37 PM
Jeff92se's Avatar
I'm needing a caw
Well they DO email the program to upload. So I guess there must be a way to look at it / maybe alter it.
Old Jun 15, 2007 | 04:39 PM
IceY2K1's Avatar
Exactly........
Old Jun 15, 2007 | 04:41 PM
IceY2K1's Avatar
If it did, it would cost $5K or more easy.
Technosquare has a programmer they sell. Al Friedman uses something somewhat similar at Dynoflash.com for EVOs.
Old Jun 15, 2007 | 04:46 PM
IceY2K1's Avatar
http://technosquareinc.com/mitelite.htm
http://technosquareinc.com/flashecu.htm
Just not worth the cost unless you start up something like Dynoflash.com.
Old Jun 15, 2007 | 04:51 PM
SR20DEN's Avatar
VQ Wizard
Anything can be edited with a Hex Editor. However if the bins are encrypted or compressed somehow, that would be useless and dangerous to the ECU.
You guys be on the lookout on the G forums for people getting these things. I want to take a peak at one of their bins.
Old Jun 15, 2007 | 04:57 PM
SR20DEN's Avatar
VQ Wizard
I also assume you've seen these too.
http://www.autosportwiring.com/
Old Jun 15, 2007 | 04:59 PM
Jeff92se's Avatar
I'm needing a caw
Personally, I'd search the Z forums. I think those guys move alot faster than the G forums I frequent
Old Jul 26, 2007 | 10:37 AM
Jeff92se's Avatar
I'm needing a caw
Ugh.............
Jeff,
Thank you for your inquiry.
You are correct about the early 03 G35 sedans having a different set of
ecu
connectors. We do not carry those connector parts.
If you would like to email a picture of your ecu connector, I can take
a
look to verify which parts you have on your car.
Regards,
Richard Welch
AutoSport Wiring
P.O. Box 93141
Southlake, Texas 76092
817-707-9371 Phone
Old Jul 26, 2007 | 11:03 AM
Puppetmaster's Avatar
Ugh.............
I hope you won't have to do it the hard way, like I have to on my 2002. Still haven't found the motivation to start the soldering....
Old Jul 26, 2007 | 11:07 AM
Jeff92se's Avatar
I'm needing a caw
You have a pic of the ecu connector straight on? Because from what I see, the gray connector is what I "think" I have. Pic from the G forum:
Gray is G35 early sedan ecu.
Black is for the Unichip that didn't fit. But looks like all the other harness adaptors I've seen for Emanage/UTEC etc...
Old Jul 26, 2007 | 11:29 AM
The gray one in your picture looks about right, ie. it at least looks close to what I have unlike the black one, but I'll take a straight on picture when I get home this evening.
You're trying to get your own patch harness?
Old Jul 26, 2007 | 11:32 AM
Jeff92se's Avatar
I'm needing a caw
Well idealy, I'd like to find out if a straight patch harness is available. Plug and play.
Did you buy an extra ecu connector from a bone yard? and you are taking those wires and soldering them into a back of an emanage harness connector?
I'd imagine I would have to buy another G35 ecu connector and a patch harness. Then hack the harness to ecu connector off and splice the harnes wires into the G35 connector?
Old Jul 26, 2007 | 12:01 PM
SR20DEN's Avatar
VQ Wizard
I still need the motivation to get the connector off the PCB which I have had for over a year.
Old Jul 26, 2007 | 12:31 PM
I got the ECU harness from a yard for the female side (right piece, with the wires), and a fried ECU from another Org member for the male side (left piece).
The problem is the male side because it is on the circuit board, so I had to hack apart the ECU to get that part, the left piece in my picture. You can also do it the right way with a solder sucker, but a tapered head wire cutter is as advanced a tool as I have.
I'm trying to do what Ice did here:
http://forums.maxima.org/showpost.ph...6&postcount=78
That is, create an intermediate patch harness to wire the Emanage harness into, so that I can (1) not mess with my stock harness (2) easily pull the unit on and off and go back to stock if necessary.
It doesn't seem like you can even use a prefabbed patch harness because the connectors on either side will not match anything on your car.
If the piggyback is already attached to the patch, you'll have to chop off both connectors of the patch harness and reattach the correct G35 male and female connector to be able to connect the patch to the car. You'd have to match the pins to the wires, so this would actually be a nightmare on an existing patch harness.
Unless I misunderstood the question....
Old Jul 26, 2007 | 12:43 PM
You need to forego one of your Charlotte Maxima dinners and get this done then. It took me less than an hour to cut the connector off the PCB, but then, I was pretty reckless with it.
At least you already have the Emanage on the car. I want to finish the harness first.
Old Jul 26, 2007 | 12:55 PM
Jeff92se's Avatar
I'm needing a caw
Yeah it's me, not you. I don't understand.
OEM ecu -> (ok)your patch ->(ok) emanage ->(confused) oem harness? Wouldn't the emange existing harness be incorrect?
Old Jul 26, 2007 | 02:06 PM
Okay, I see where the confusion is. The Emanage harness is spliced into the patch itself. The patch just creates a "bridge" between the ECU and OEM wire harness that you can tap into. The Emanage harness doesn't touch either connector on the car, but is only connected via the patch harness.
The order is:
OEM ECU -> Patch Harness -> OEM Harness
With the Greddy harness tapped into the patch.
Here's a crude diagram I drew that might help:
Let me know if this makes sense, or if someone else can explain it a different way, please go ahead.
Old Jul 26, 2007 | 02:10 PM
Jeff92se's Avatar
I'm needing a caw
Ah I got it. So once you make that harness, you aren't done. You have to tap the emanage harness into the harness you just made. Yikes!
Old Jul 26, 2007 | 02:39 PM
SR20DEN's Avatar
VQ Wizard
I've spent over an hour or so on it trying to desolder everything. That is a complete waste of time. Cutting seems to be the way to go.
Old Jul 26, 2007 | 02:43 PM
Jeff92se's Avatar
I'm needing a caw
Matt, how did you do yours? Happen to have a pic?
Old Jul 26, 2007 | 02:54 PM
SR20DEN's Avatar
VQ Wizard
I haven't done it. I just tried to desolder it when I got it. But I am going to use a cutoff wheel which should cut through everything cleanly and quickly.
And I still have no main harness to connect to it.
Old Jul 26, 2007 | 03:01 PM
Jeff92se's Avatar
I'm needing a caw
Oh. Puppet alluded to you already having the EU hooked up to your ecu. If that's true, I was just curious as how you did that w/o this harness.
Old Jul 26, 2007 | 04:02 PM
SR20DEN's Avatar
VQ Wizard
I have a EB installed already which replaced my SAFC2. What I was was tap into the main harness (solder and heat shrink). I used 12 pin and a 9 pin harnesses I got from Radio Shack so I can remove the EB main harness a any time.
http://www.radioshack.com/family/ind...032058.2032231
A good alternative to that is what Dandymax did and use some DB25 connectors which are easy to get, just be sure to double pin most of those because of current draw.
Old Jul 26, 2007 | 04:26 PM
IceY2K1's Avatar
Que?
2003 G35 ECU is similar to 2000-2003 Maxima ECU, therefore YOU must make your own like I did.
2005(2004?) Maxima is similar to 2003-2004 350Z, so my buddy could use the BoomSlang/AutoSport/etc..
Ugh.............
Old Jul 26, 2007 | 04:28 PM
IceY2K1's Avatar
One piece of advice to anyone making their own...
Make sure you test the extension harness FIRST, THEN solder on the EU wires.
Old Jul 26, 2007 | 05:39 PM
Jeff92se's Avatar
I'm needing a caw
Pics? As I understand it. Only the later Gs and Zs have harness kits available. Maxima guys and early Gs are out.
Unless the newer maximas (maybe 04+) went to the later G/Z type ecu connector (ie.. black)
Que?
Old Jul 26, 2007 | 05:49 PM
SR20DEN's Avatar
VQ Wizard
All A33s and your early V35 have the same connector, as you originally brought to our attention Jeff. But the A34s do have the same connector as the Z33 and later V35s.
However the pinouts for the A33, A33B and early V35 are all different as far as I know. But I haven't exactly confirmed the latter (between A33B and V35).
Old Jul 26, 2007 | 06:31 PM
IceY2K1's Avatar
I'm not sure what you'd like pics of Jeff.
In short, you're in the same boat as 5/5.5 Gens that have to make their own vs. 6Gs that can buy a 350Z boomslang or similar extension or P-N-P EU harness.
Old Jul 27, 2007 | 06:55 AM
Here you go Jeffy... looks a lot like yours (its just flipped).
