Cabin air filter replacement
I didn't find a sticky or instructions on changing a 6th generation cabin air filter.
Has anybody changed it? Any instructions, perhaps pictures on changing this filter?
2 clips on the bottom of your glove compartment-take them out, the left one goes out right and the right one goes out left
let your glove box "hang" gently and now you see the panel to remove for the filter-REMOVE it using common sense and swap the filter out, re-install everything in reverse order and you are done!
dan
dan
and do yourself a favor and pop those two clips to the air filter box with a small, regular screw driver or something similar. I got some good cuts the first time by doing it by hand. Once you've done it once, it takes all of 3 minutes for the complete job.
I think the clips were the easiest part. The bungee cord was the hardest and figuring out which way the ****ty filter went in. I got it from the dealership and it was completely different from the one that was there. So much for stocking OEM parts huh?
Originally Posted by ecksy
i took mine out at 16k just for the heck of it thinking it would be somewhat ok to leave it in. Oddly enough it was as dark as jay's if not darker!
Change every spring for best performance. Lots of dust is collected furing summer/fall months and moisture sets in during fall/winter months sometimes causing a bad smell. If you don't drive much, change two years. If you do 15-20 k, i would change every year. They are less then $10.00 and it takes 10 minutes to change, well less if you don't talk much.
Originally Posted by SuperMario
OK Fastmax, go ahead and post instruction pics, make it a sticky!!!!!
where can i get it online for less??? guys??????
Originally Posted by Fastmax05
word man... but its going to be a few days now... i went to napa autoparts here in so cal and they want 27.94 plus tax for it!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jimbo
Mine is probably bad because of the racing I did in Lone Pine. My car has 55,000 miles on it and never has been changed. I didnt notice any difference this morning when I turned the air on.
Originally Posted by Smoke_Screen
JFK Deus! That's friggin dirty! Anyone got a pic of where the clips are you have to unlatch your glove box?? Thanks
i hope....
I gotta change mine again. You can get em for $10 shipped right here on the .org http://forums.maxima.org/showthread.php?t=518370 I just ordered 3 of them.
hahah mine was close to this hahah not hat bad
