20" wheels....offset questions
Old Jul 18, 2007 | 07:11 PM
JG1's Avatar
JG1
I have an 05' SL, with a set of 20 x 8.5 wheels on the way w/ Nitto 555 245/35/20.
Will be dropping the car w/ a set of Eibach springs.
Are these wheels going to bolt right on w/ no problems or do I have to do something about the wheel offset? I'm a newbie w/ this stuff so please be patient
Old Jul 18, 2007 | 08:17 PM
jsmithsole's Avatar
*moderator*
If the bolt pattern is correct, they will bolt right on 5x114.3 Also what is the offset of the wheels this will make or break your setup...I am running your same setup with 38mm offset and it tucks nicely...
Old Jul 18, 2007 | 10:03 PM
illanoize's Avatar
reply
heyt if i went with 20/10 on the rear and 20/8.5 in the front what kinda drop can i go with? And also what size tires for the 20/10?
Old Jul 19, 2007 | 02:54 AM
KCMAXX's Avatar
KC's FINEST
So you bought wheels and are now asking if they are going to fit?
Dee-Dee-Deeeee
Old Jul 19, 2007 | 05:51 AM
JG1's Avatar
JG1
Dee-Dee-Deeeee
Yep exactly...isn' that how everyone does it?
What the point of your post? How's it supposed to be helpful?
I bought the wheels from an online vendor, told them exactly what kind of car I have what model what year, they matched up the wheel and said they're fine. I'm reading on these boards about people running different offsets and that where my question stems.
Please if you don't have anything helpful to add.....why post??
Old Jul 19, 2007 | 06:11 AM
doublea's Avatar
It all depend on the wheel offset, there is some member that are running 265 in the back without rubbing but they are not running on 20's.
35-38 mm sound like the offset you may want, so 20" x 10" with a drop, it's going to be a close call, the rear fender can be roll to add little more space to tuk in the tire.
Old Jul 19, 2007 | 06:58 AM
MaximusX's Avatar
KCmaxx was probably just wondering why you didn't do ALL of your research before purchasing your wheels. If you weren't sure about the offset you should've posted what rims + tires you were going to get, ask and confirm here THEN made the purchase. Just my 2 cents, but I'm sure you'll be just fine. Good luck bro.
Old Jul 19, 2007 | 09:11 AM
KCMAXX's Avatar
KC's FINEST
Talk about worthless posts...
If you bought them to fit the max why are you here asking if they'll fit?
Whats the backspace? Whats the hub size?
If you have wheel fitment questions check the STICKIES... That's what they're there for.
Old Jul 19, 2007 | 09:20 AM
JG1's Avatar
JG1
Worthless posts?
What have your two post added? Tell me?
Old Jul 19, 2007 | 09:26 AM
Zargon's Avatar
0100011001010101
Worthless posts?
He pointed you to the stickies, which you should have read. Those would be real helpful.
Old Jul 19, 2007 | 09:55 AM
xoomer.com's Avatar
I Donate! Why Don't You?
this should be posted in wheel and tires section. and don't tell me that this post is worthless
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
